vtkSMParaViewPipelineControllerWithRendering Class Reference
vtkSMParaViewPipelineControllerWithRendering overrides vtkSMParaViewPipelineController to add support for initializing rendering proxies appropriately. More...
#include <vtkSMParaViewPipelineControllerWithRendering.h>
Inheritance diagram for vtkSMParaViewPipelineControllerWithRendering:
Collaboration diagram for vtkSMParaViewPipelineControllerWithRendering:
typedef vtkSMParaViewPipelineController Superclass
- Public Types inherited from vtkSMParaViewPipelineController
virtual vtkSMProxyShow (vtkSMSourceProxy *producer, int outputPort, vtkSMViewProxy *view)
 Show the output data in the view. More...
virtual vtkSMProxyShow (vtkSMSourceProxy *producer, int outputPort, vtkSMViewProxy *view, const char *representationType)
void ShowAll (vtkSMViewProxy *view)
 Show all source output ports in provided view. More...
virtual vtkSMProxyHide (vtkSMSourceProxy *producer, int outputPort, vtkSMViewProxy *view)
 Opposite of Show(). More...
virtual void Hide (vtkSMProxy *repr, vtkSMViewProxy *view)
 Same as above, except that when we already have the representation located. More...
virtual void HideAll (vtkSMViewProxy *view)
 Hide all visible sources output ports in provided view. More...
vtkSMProxySetVisibility (vtkSMSourceProxy *producer, int outputPort, vtkSMViewProxy *view, bool visible)
 Alternative method to call Show and Hide using a visibility flag. More...
virtual bool GetVisibility (vtkSMSourceProxy *producer, int outputPort, vtkSMViewProxy *view)
 Returns whether the producer/port are shown in the given view. More...
virtual vtkSMViewProxyShowInPreferredView (vtkSMSourceProxy *producer, int outputPort, vtkSMViewProxy *view)
 Same as Show() except that if the view is nullptr or not the preferred view for the producer's output, this method will create a new view and show the data in that new view. More...
virtual const char * GetPreferredViewType (vtkSMSourceProxy *producer, int outputPort)
 Returns the name for the preferred view type, if there is any. More...
virtual const char * GetPipelineIcon (vtkSMSourceProxy *producer, int outputPort)
 Return the pipeline icon to use with the provided producer. More...
bool RegisterRepresentationProxy (vtkSMProxy *proxy) override
 Overridden to create color and opacity transfer functions if applicable. More...
 PARAVIEW_DEPRECATED_IN_5_14_0 ("Use vtkPVGeneralSettings::SetScalarBarMode(AUTOMATICALLY_HIDE_SCALAR_BARS) instead") static void SetHideScalarBarOnHide(bool)
 Control how scalar bar visibility is updated by the Hide call. More...
bool PostInitializeProxy (vtkSMProxy *proxy) override
 Overridden to handle default ColorArrayName for representations correctly. More...
virtual bool RegisterLayoutProxy (vtkSMProxy *proxy, const char *proxyname=nullptr)
 Register layout proxy. More...
virtual void AssignViewToLayout (vtkSMViewProxy *view, vtkSMViewLayoutProxy *layout=nullptr, int hint=0)
 Assigns the view to any cell in the layout. More...
 PARAVIEW_DEPRECATED_IN_5_14_0 ("Use vtkPVGeneralSettings::SetInheritRepresentationProperties() instead") static void SetInheritRepresentationProperties(bool)
 Control whether representations try to maintain properties from an input representation, if present. More...
 PARAVIEW_DEPRECATED_IN_5_14_0 ("Use vtkPVGeneralSettings::GetInheritRepresentationProperties() instead") static bool GetInheritRepresentationProperties()
- Public Member Functions inherited from vtkSMParaViewPipelineController
virtual bool InitializeSession (vtkSMSession *session)
 Call this method to setup a branch new session with state considered essential for ParaView session. More...
virtual vtkSMProxyFindTimeKeeper (vtkSMSession *session)
 Returns the TimeKeeper proxy associated with the session. More...
virtual vtkSMProxyFindMaterialLibrary (vtkSMSession *session)
 Returns the MaterialLibrary proxy associated with the session. More...
virtual bool PreInitializeProxy (vtkSMProxy *proxy)
 Pre-initializes a proxy i.e. More...
bool InitializeProxy (vtkSMProxy *proxy)
 Convenience method to call PreInitializeProxy and PostInitializeProxy. More...
virtual bool FinalizeProxy (vtkSMProxy *proxy)
 Cleans up any helper proxies registered for the proxy in PreInitializeProxy/PostInitializeProxy. More...
virtual bool RegisterPipelineProxy (vtkSMProxy *proxy, const char *proxyname)
 Use this method after PreInitializeProxy() and PostInitializeProxy() to register a pipeline proxy with the proxy manager. More...
virtual bool RegisterPipelineProxy (vtkSMProxy *proxy)
virtual bool UnRegisterPipelineProxy (vtkSMProxy *proxy)
 Unregisters a pipeline proxy. More...
virtual bool RegisterViewProxy (vtkSMProxy *proxy)
 Use this method after PreInitializeProxy() and PostInitializeProxy() to register a view proxy with the proxy manager. More...
virtual bool RegisterViewProxy (vtkSMProxy *proxy, const char *proxyname)
virtual bool UnRegisterViewProxy (vtkSMProxy *proxy, bool unregister_representations=true)
 Inverse of RegisterViewProxy. More...
virtual bool UnRegisterRepresentationProxy (vtkSMProxy *proxy)
 Unregisters a representation proxy. More...
virtual bool RegisterColorTransferFunctionProxy (vtkSMProxy *proxy, const char *proxyname)
 Registration method for color transfer function proxies to be used after PreInitializeProxy() and PostInitializeProxy() calls. More...
virtual bool RegisterColorTransferFunctionProxy (vtkSMProxy *proxy)
virtual bool RegisterOpacityTransferFunction (vtkSMProxy *proxy, const char *proxyname)
 Registration method for opacity transfer function proxies. More...
virtual bool RegisterOpacityTransferFunction (vtkSMProxy *proxy)
virtual bool RegisterTransferFunction2D (vtkSMProxy *proxy, const char *proxyname)
 Registration method for 2D transfer function proxies. More...
virtual bool RegisterTransferFunction2D (vtkSMProxy *proxy)
virtual bool RegisterLightProxy (vtkSMProxy *proxy, vtkSMProxy *view, const char *proxyname)
 Use this method after PreInitializeProxy() and PostInitializeProxy() to register a light proxy with the proxy manager. More...
virtual bool RegisterLightProxy (vtkSMProxy *proxy, vtkSMProxy *view)
virtual bool RegisterTextureProxy (vtkSMProxy *proxy, const char *filename)
 Use this method after PreInitializeProxy() and PostInitializeProxy() to register a texture proxy with the proxy manager. More...
virtual bool RegisterTextureProxy (vtkSMProxy *proxy, const char *trivialProducerKeyName, const char *proxyname)
virtual bool RegisterExtractorProxy (vtkSMProxy *proxy, const char *proxyname)
 Registers an extractor. More...
virtual bool RegisterExtractorProxy (vtkSMProxy *proxy)
virtual vtkSMProxyFindAnimationScene (vtkSMSession *session)
 Returns the animation scene, if any. More...
virtual vtkSMProxyGetAnimationScene (vtkSMSession *session)
 Returns the animation scene for the session. More...
virtual vtkSMProxyFindTimeAnimationTrack (vtkSMProxy *scene)
 Return the animation track for time, if any. More...
virtual vtkSMProxyGetTimeAnimationTrack (vtkSMProxy *scene)
 Return the animation track for time. More...
virtual bool RegisterAnimationProxy (vtkSMProxy *proxy)
 Use this method after PreInitializeProxy() and PostInitializeProxy() to register an animation proxy with the proxy manager. More...
virtual bool UnRegisterAnimationProxy (vtkSMProxy *proxy)
 Inverse of RegisterAnimationProxy. More...
virtual void UpdateSettingsProxies (vtkSMSession *session)
 Initializes and registers proxies in the "settings" group that haven't been already. More...
virtual bool UnRegisterProxy (vtkSMProxy *proxy)
 A catch-all method do cleanup and unregister any proxies that were registered using Register..Proxy() APIs on this class. More...
virtual bool RegisterRepresentationProxy (vtkSMProxy *proxy, const char *proxyname)
 Registration method for representations to be used after PreInitializeProxy() and PostInitializeProxy(). More...
static vtkSMParaViewPipelineControllerWithRenderingNew ()
static vtkSMParaViewPipelineControllerWithRenderingSafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMParaViewPipelineController
static vtkSMParaViewPipelineControllerNew ()
static vtkSMParaViewPipelineControllerSafeDownCast (vtkObject *o)
static std::string GetHelperProxyGroupName (vtkSMProxy *)
 For a given proxy returns the name of the group used for helper proxies. More...
static vtkSMObjectNew ()
static vtkObjectNew ()
static vtkObjectBaseNew ()
 vtkSMParaViewPipelineControllerWithRendering ()
 ~vtkSMParaViewPipelineControllerWithRendering () override
virtual void UpdatePipelineBeforeDisplay (vtkSMSourceProxy *producer, int outputPort, vtkSMViewProxy *view)
virtual bool AlsoShowInCurrentView (vtkSMSourceProxy *producer, int outputPort, vtkSMViewProxy *currentView)
 Checks if the output from producer needs to be shown in the current view also. More...
- Protected Member Functions inherited from vtkSMParaViewPipelineController
 vtkSMParaViewPipelineController ()
 ~vtkSMParaViewPipelineController () override
vtkSMProxyFindProxy (vtkSMSessionProxyManager *pxm, const char *reggroup, const char *xmlgroup, const char *xmltype)
 Find proxy of the group type (xmlgroup, xmltype) registered under a particular group (reggroup). More...
virtual bool SetupGlobalPropertiesLinks (vtkSMProxy *proxy)
 Setup global properties links based on hints for properties in the XML. More...
virtual bool CreateAnimationHelpers (vtkSMProxy *proxy)
 To help animation representation properties such as visibility, opacity, we create animation helpers. More...
virtual bool UnRegisterDependencies (vtkSMProxy *proxy)
 Unregisters know proxy dependencies that must be removed when the proxy is to be deleted e.g animation cues, representations, etc. More...
vtkMTimeType GetInitializationTime (vtkSMProxy *)
 Returns the initialization timestamp for the proxy, if available. More...
void ProcessInitializationHelperRegistration (vtkSMProxy *)
 If the proxy has initialization helpers, let those classes also handle registration tasks, if any. More...
virtual bool CreateProxiesForProxyListDomains (vtkSMProxy *proxy)
 Creates new proxies for proxies referred in vtkSMProxyListDomain for any of the properties for the given proxy. More...
virtual void RegisterProxiesForProxyListDomains (vtkSMProxy *proxy)
void ProcessInitializationHelper (vtkSMProxy *, vtkMTimeType initializationTimeStamp)
 Proxies can specify custom initialization using XML hints. More...
 vtkSMObject ()
 ~vtkSMObject () override
vtkSMParaViewPipelineControllerWithRendering uses vtkObjectFactory mechanisms to override vtkSMParaViewPipelineController's creation. One should not need to create or use this class directly (excepting when needing to subclass). Simply create vtkSMParaViewPipelineController. If the application is linked with the rendering module, then this class will be instantiated instead of vtkSMParaViewPipelineController automatically.
vtkSMParaViewPipelineControllerWithRendering also adds new API to control representation visibility and manage creation of views. To use that API clients can instantiate vtkSMParaViewPipelineControllerWithRendering. Just like vtkSMParaViewPipelineController, this class also uses vtkObjectFactory mechanisms to enable overriding by clients at compile time.
Definition at line 33 of file vtkSMParaViewPipelineControllerWithRendering.h.
◆ vtkSMParaViewPipelineControllerWithRendering()
vtkSMParaViewPipelineControllerWithRendering::vtkSMParaViewPipelineControllerWithRendering ( )
◆ ~vtkSMParaViewPipelineControllerWithRendering()
vtkSMParaViewPipelineControllerWithRendering::~vtkSMParaViewPipelineControllerWithRendering ( )
static vtkSMParaViewPipelineControllerWithRendering* vtkSMParaViewPipelineControllerWithRendering::New ( )
virtual const char* vtkSMParaViewPipelineControllerWithRendering::GetClassName ( )
Reimplemented from vtkSMParaViewPipelineController.
static int vtkSMParaViewPipelineControllerWithRendering::IsTypeOf ( const char *  type)
virtual int vtkSMParaViewPipelineControllerWithRendering::IsA ( const char *  type)
static vtkSMParaViewPipelineControllerWithRendering* vtkSMParaViewPipelineControllerWithRendering::SafeDownCast ( vtkObject o)
void vtkSMParaViewPipelineControllerWithRendering::PrintSelf ( ostream &  os,
◆ Show() [1/2]
virtual vtkSMProxy* vtkSMParaViewPipelineControllerWithRendering::Show ( vtkSMSourceProxy producer,
int  outputPort,
vtkSMViewProxy view
If data cannot be shown in the view, returns nullptr. If view is nullptr, this simply calls ShowInPreferredView().
◆ Show() [2/2]
int  outputPort,
vtkSMViewProxy view,
const char *  representationType
If data cannot be shown in the view, returns nullptr. If view is nullptr, this simply calls ShowInPreferredView(). representationName specifies which representation should be instantiated - if nullptr, a default representation will be created based on hints in the XML.
◆ ShowAll()
void vtkSMParaViewPipelineControllerWithRendering::ShowAll ( vtkSMViewProxy view)
◆ Hide() [1/2]
virtual vtkSMProxy* vtkSMParaViewPipelineControllerWithRendering::Hide ( vtkSMSourceProxy producer,
int  outputPort,
vtkSMViewProxy view
Opposite of Show().
Locates the representation for the producer and then hides it, if found. Returns that representation, if found.
◆ Hide() [2/2]
virtual void vtkSMParaViewPipelineControllerWithRendering::Hide ( vtkSMProxy repr,
vtkSMViewProxy view
◆ HideAll()
virtual void vtkSMParaViewPipelineControllerWithRendering::HideAll ( vtkSMViewProxy view)
◆ SetVisibility()
vtkSMProxy* vtkSMParaViewPipelineControllerWithRendering::SetVisibility ( vtkSMSourceProxy producer,
int  outputPort,
bool  visible
inline
Definition at line 80 of file vtkSMParaViewPipelineControllerWithRendering.h.
◆ GetVisibility()
virtual bool vtkSMParaViewPipelineControllerWithRendering::GetVisibility ( vtkSMSourceProxy producer,
int  outputPort,
vtkSMViewProxy view
◆ ShowInPreferredView()
virtual vtkSMViewProxy* vtkSMParaViewPipelineControllerWithRendering::ShowInPreferredView ( vtkSMSourceProxy producer,
int  outputPort,
vtkSMViewProxy view
There are several different strategies employed to determine the preferred view for the producer's output. See vtkSMParaViewPipelineControllerWithRendering::GetPreferredViewType() for details.
Note
if the source's hint indicates so, the data may also be shown in the view passed in, in addition to the preferred view. This is done by using the also_show_in_current_view attribute to the <View /> hint.
Returns
the view in which the data ends up being shown, if any. It may return nullptr if the view is not the preferred type or the preferred cannot be determined or created.
◆ GetPreferredViewType()
virtual const char* vtkSMParaViewPipelineControllerWithRendering::GetPreferredViewType ( vtkSMSourceProxy producer,
int  outputPort
There are several strategies employed by the default implementation to determine the preferred view type.
  1. Using XML hints.
    A producer proxy can provide XML hints to define the preferred view type of each (or all) of its output ports. This is done as follows:
<SourceProxy>
<Hints>
<View type="<view name>" port="<output port number" />
</Hints>
</SourceProxy>
Attribute port is optional and only needed to explicitly specify different view types for different output ports.
  1. Using data type.
    If the data type for the generated data is vtkTable, then the preferred view (if none provided) is assumed to be SpreadSheetView.
Returns
XML name for the preferred view proxy. It is assumed to be defined in the "views" group.
◆ GetPipelineIcon()
virtual const char* vtkSMParaViewPipelineControllerWithRendering::GetPipelineIcon ( vtkSMSourceProxy producer,
int  outputPort
It can be either a view type name, an existing icon resource or nullptr. Here is the strategy to determine the pipeline icon.
Using XML hints.
A producer proxy can provide XML hints to define the pipeline icon to use of each (or all) of its output ports. This is done as follows:
<SourceProxy>
<Hints>
<PipelineIcon name="<view name or icon resource>" port="<output port number>" />
</Hints>
</SourceProxy>
Using GetPreferredViewType
If no PipelineIcon as been provided, we fall back to using GetPreferredViewType.
◆ RegisterRepresentationProxy()
bool vtkSMParaViewPipelineControllerWithRendering::RegisterRepresentationProxy ( vtkSMProxy proxy)
While it is tempting to add any default property setup logic in such overrides, we must keep such overrides to a minimal and opting for domains that set appropriate defaults where as much as possible.
◆ PARAVIEW_DEPRECATED_IN_5_14_0() [1/3]
vtkSMParaViewPipelineControllerWithRendering::PARAVIEW_DEPRECATED_IN_5_14_0 ( "Use vtkPVGeneralSettings::SetScalarBarMode(AUTOMATICALLY_HIDE_SCALAR_BARS) instead"  )
◆ PARAVIEW_DEPRECATED_IN_5_14_0() [2/3]
vtkSMParaViewPipelineControllerWithRendering::PARAVIEW_DEPRECATED_IN_5_14_0 ( "Use vtkPVGeneralSettings::SetInheritRepresentationProperties() instead"  )
e.g. if you "Transform" the representation for a source, then any filter that you connect to it should be transformed as well.
◆ PARAVIEW_DEPRECATED_IN_5_14_0() [3/3]
vtkSMParaViewPipelineControllerWithRendering::PARAVIEW_DEPRECATED_IN_5_14_0 ( "Use vtkPVGeneralSettings::GetInheritRepresentationProperties() instead"  )
◆ PostInitializeProxy()
bool vtkSMParaViewPipelineControllerWithRendering::PostInitializeProxy ( vtkSMProxy proxy)
◆ RegisterLayoutProxy()
virtual bool vtkSMParaViewPipelineControllerWithRendering::RegisterLayoutProxy ( vtkSMProxy proxy,
const char *  proxyname = nullptr
If proxyname is nullptr, a new name will be assigned.
◆ AssignViewToLayout()
virtual void vtkSMParaViewPipelineControllerWithRendering::AssignViewToLayout ( vtkSMViewProxy view,
vtkSMViewLayoutProxy layout = nullptr,
int  hint = 0
If the layout is nullptr, then this will locate a layout on the same session and use it. If no layout is present on the session, a new layout will be created (and registered) before assigning the view to it.
If the view is already assigned to a layout then this method is a no-op.
See also
vtkSMViewProxy::AssignViewToAnyCell
◆ UpdatePipelineBeforeDisplay()
virtual void vtkSMParaViewPipelineControllerWithRendering::UpdatePipelineBeforeDisplay ( vtkSMSourceProxy producer,
int  outputPort,
vtkSMViewProxy view
protectedvirtual
◆ AlsoShowInCurrentView()
virtual bool vtkSMParaViewPipelineControllerWithRendering::AlsoShowInCurrentView ( vtkSMSourceProxy producer,
int  outputPort,
vtkSMViewProxy currentView
protectedvirtual
