void | Update (vtkSMProperty *prop) override |
| Recovers timesteps from a required property "Input" and store them into the internal Values. More...
const std::vector< double > & | GetValues () |
| Returns the vector of values containing the timesteps after Update. More...
double | GetValue (unsigned int i) |
| Returns the value at index from the timesteps after Update. More...
unsigned int | GetNumberOfValues () |
| Returns the number of values containing the timesteps after Update. More...
| Is the (unchecked) value of the property in the domain? Overwritten by sub-classes. More...
| Set the value of an element of a property from the animation editor. More...
| A vtkSMProperty is often defined with a default value in the XML itself. More...
| Provides access to the vtkSMProperty on which this domain is hooked up. More...
| Helper method to get the number of input connections hence the number of available vtkPVDataInformation from input proxy connected to the required property with the given function. More...
| Returns a given required property of the given function. More...
| When the IsOptional flag is set, IsInDomain() always returns true. More...
| Helper methods to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More...
virtual vtkPVDataInformation * | GetInputSubsetDataInformation (const char *selector, const char *assemblyName, const char *function, unsigned int index=0) |
virtual void | Modified () |
