ApplicationComponents
pqGenericPropertyWidgetDecorator.h
1
// SPDX-FileCopyrightText: Copyright (c) Kitware Inc.
// SPDX-FileCopyrightText: Copyright (c) Sandia Corporation
3
// SPDX-License-Identifier: BSD-3-Clause
4
#ifndef pqGenericPropertyWidgetDecorator_h
5
#define pqGenericPropertyWidgetDecorator_h
6
7
pqPropertyWidgetDecorator.h
9
10
vtkGenericPropertyDecorator.h
11
PQAPPLICATIONCOMPONENTS_EXPORT
20
public
21
22
Q_OBJECT
23
typedef
Superclass
24
25
public
26
vtkPVXMLElement
* config,
pqPropertyWidget
* parent);
27
override
28
32
bool
canShowWidget
bool
show_advanced)
const override
33
bool
enableWidget
const override
35
private
// NOLINT(readability-redundant-access-specifiers)
36
Q_DISABLE_COPY(
37
vtkNew<vtkGenericPropertyDecorator>
decoratorLogic;
38
40
#endif
pqPropertyWidget
pqPropertyWidget represents a widget created for each property of a proxy on the pqPropertiesPanel (f...
Definition:
pqPropertyWidget.h:25
pqGenericPropertyWidgetDecorator is a pqPropertyWidgetDecorator that supports multiple common use cas...
Definition:
pqGenericPropertyWidgetDecorator.h:19
pqPropertyWidgetDecorator::enableWidget
virtual bool enableWidget() const
Override this method to override the enable state of the widget in the panel.
vtkNew< vtkGenericPropertyDecorator >
pqPropertyWidgetDecorator::canShowWidget
virtual bool canShowWidget(bool show_advanced) const
Override this method to override the visibility of the widget in the panel.
vtkPVXMLElement
Definition:
vtkPVXMLElement.h:23
pqPropertyWidgetDecorator provides a mechanism to decorate pqPropertyWidget instances to add logic to...
Definition:
pqPropertyWidgetDecorator.h:20
1.8.13 on Sat Dec 13 2025
