pqPropertyWidget.h
4 #ifndef pqPropertyWidget_h
5 #define pqPropertyWidget_h
6
7 #include "pqComponentsModule.h"
9 #include "pqPropertyLinks.h"
10 #include <QFrame>
11 #include <QPointer>
12 #include <QScopedPointer>
13
15 class pqTimer;
16 class pqView;
17 class vtkPVXMLElement;
18 class vtkSMDomain;
19 class vtkSMProperty;
20 class vtkSMProxy;
25 class PQCOMPONENTS_EXPORT pqPropertyWidget : public QFrame
26 {
27  Q_OBJECT
28  typedef QWidget Superclass;
30 public:
31  pqPropertyWidget(vtkSMProxy* proxy, QWidget* parent = nullptr);
32  ~pqPropertyWidget() override;
33
34  virtual void apply();
35  virtual void reset();
36
38
48  virtual void select() { this->Selected = true; }
49  virtual void selectPort(int portIndex) { Q_UNUSED(portIndex); }
50  virtual void deselect() { this->Selected = false; }
51  bool isSelected() const { return this->Selected; }
53
54  // This method is called on pqPropertyWidget instances that pqProxyWidget
55  // deems that should be shown in current configuration. Subclasses can
56  // override this method to change the appearance of the widget based on
57  // whether advanced properties are currently being shown by the pqProxyWidget
58  // or not.
59  virtual void updateWidget(bool showing_advanced_properties)
60  {
61  Q_UNUSED(showing_advanced_properties);
62  }
63
64  pqView* view() const;
65  vtkSMProxy* proxy() const;
66  vtkSMProperty* property() const;
67  using Superclass::property; // Don't hide superclass method
68
73  virtual char* panelVisibility() const;
74  virtual void setPanelVisibility(const char* vis);
75
86  virtual bool isSingleRowItem() const;
87
88  bool showLabel() const;
89
103  template <class T>
104  static QString getXMLName(T* object)
105  {
106  return QString(object->GetXMLName());
107  }
108
112  const QList<QPointer<pqPropertyWidgetDecorator>>& decorators() const { return this->Decorators; }
113
118  using Superclass::setProperty;
119
123  static QString getTooltip(vtkSMProperty* property);
124
129  static int hintsWidgetHeightNumberOfRows(vtkPVXMLElement* hints, int defaultValue = 10);
130
137  static std::vector<std::string> parseComponentLabels(
138  vtkPVXMLElement* hints, unsigned int elemCount = 0);
139
144  virtual void setReadOnly(bool readOnly);
145
146 Q_SIGNALS:
150  void viewChanged(pqView* view);
151
156  void changeAvailable();
157
162  void changeFinished();
163
168  void restartRequired();
169
170 public Q_SLOTS:
174  virtual void setView(pqView*);
175
176 protected:
177  void addPropertyLink(QObject* qobject, const char* qproperty, const char* qsignal,
178  vtkSMProperty* smproperty, int smindex = -1);
179  void addPropertyLink(QObject* qobject, const char* qproperty, const char* qsignal,
180  vtkSMProxy* smproxy, vtkSMProperty* smproperty, int smindex = -1);
181  void removePropertyLink(QObject* qobject, const char* qproperty, const char* qsignal,
182  vtkSMProperty* smproperty, int smindex = -1);
183  void removePropertyLink(QObject* qobject, const char* qproperty, const char* qsignal,
184  vtkSMProxy* smproxy, vtkSMProperty* smproperty, int smindex = -1);
185  void setShowLabel(bool show);
186
196  {
197  this->ChangeAvailableAsChangeFinished = status;
198  }
199
205  void addDecorator(pqPropertyWidgetDecorator*);
206
210  void removeDecorator(pqPropertyWidgetDecorator*);
211
215  pqPropertyLinks& links() { return this->Links; }
216
217 public:
218  void setProperty(vtkSMProperty* property);
219
220 private:
223  friend class pqProxyWidget;
224
225 private Q_SLOTS: // NOLINT(readability-redundant-access-specifiers)
229  void onChangeAvailable();
230
231 private: // NOLINT(readability-redundant-access-specifiers)
232  vtkSMProxy* Proxy;
233  vtkSMProperty* Property;
234  QPointer<pqView> View;
235  QList<QPointer<pqPropertyWidgetDecorator>> Decorators;
236
237  pqPropertyLinks Links;
238  bool ShowLabel;
239  bool ChangeAvailableAsChangeFinished;
240  bool Selected;
241
242  const QScopedPointer<pqTimer> Timer;
243
248  void modified();
249  void editingFinished();
250 };
251
252 #endif // pqPropertyWidget_h
These methods are called by pqPropertiesPanel when the panel for proxy becomes active/deactive.
pqPropertyWidget represents a widget created for each property of a proxy on the pqPropertiesPanel (f...
pqPropertyWidgetDecorator subclass that can combine multiple decorators using boolean operations...
const QList< QPointer< pqPropertyWidgetDecorator > > & decorators() const
Provides access to the decorators for this widget.
void setChangeAvailableAsChangeFinished(bool status)
For most pqPropertyWidget subclasses a changeAvailable() signal, corresponds to a changeFinished() si...
This is a PQ abstraction of a generic view module.
Definition: pqView.h:26
pqPropertyLinks & links()
Provides access to the pqPropertyLinks instance.
represents the possible values a property can have
Definition: vtkSMDomain.h:37
static QString getXMLName(T *object)
Description: This static utility method returns the XML name for an object as a QString.
Definition: vtkSMProxy.h:140
pqProxyWidget represents a panel for a vtkSMProxy.
Definition: pqProxyWidget.h:31
pqPropertyWidgetDecorator provides a mechanism to decorate pqPropertyWidget instances to add logic to...
