pqIntegrationModelSurfaceHelperWidgetPWIImplementation.h
4 // Generated file. Do not edit.
5
6 #ifndef pqIntegrationModelSurfaceHelperWidgetPWIImplementation_h
7 #define pqIntegrationModelSurfaceHelperWidgetPWIImplementation_h
10 #include <QObject>
11
13 {
14  Q_OBJECT
15  Q_INTERFACES(pqPropertyWidgetInterface)
16 public:
24  vtkSMProperty *property, QWidget* parentWidget) override;
25
30  vtkSMPropertyGroup *group, QWidget* parentWidget) override;
31
35  //without / raising any errors (or messages).
37  const QString& type, vtkPVXMLElement* config, pqPropertyWidget* widget) override;
38
39 private:
41 };
42
43 #endif
pqPropertyWidget represents a widget created for each property of a proxy on the pqPropertiesPanel (f...
type
pqPropertyWidgetInterface is part of the ParaView Plugin infrastructure that enables support for plug...
pqPropertyWidget * createWidgetForPropertyGroup(vtkSMProxy *proxy, vtkSMPropertyGroup *group, QWidget *parentWidget) override
Given a proxy and its property group, create a widget for the same, of possible.
pqPropertyWidgetDecorator * createWidgetDecorator(const QString &type, vtkPVXMLElement *config, pqPropertyWidget *widget) override
Given the type of the decorator and the pqPropertyWidget that needs to be decorated, create the pqPropertyWidgetDecorator instance, if possible.
pqPropertyWidget * createWidgetForProperty(vtkSMProxy *proxy, vtkSMProperty *property, QWidget *parentWidget) override
Given a proxy and its property, create a widget for the same, of possible.
Definition: vtkSMProxy.h:140
pqPropertyWidgetDecorator provides a mechanism to decorate pqPropertyWidget instances to add logic to...
