pqProxyGroupMenuManager.h
4 #ifndef pqProxyGroupMenuManager_h
5 #define pqProxyGroupMenuManager_h
6
7 #include "pqApplicationComponentsModule.h"
9 #include <QMenu>
10
11 #include "vtkParaViewDeprecation.h" // for deprecation macro
12
13 #include <memory> // for unique_ptr
14
15 class pqProxyCategory;
16 class pqProxyInfo;
17 class vtkPVXMLElement;
18 class vtkSMProxy;
25 class PQAPPLICATIONCOMPONENTS_EXPORT pqProxyGroupMenuManager : public QObject
26 {
27  Q_OBJECT
28  typedef QObject Superclass;
30 public:
39  pqProxyGroupMenuManager(QMenu* menu, const QString& resourceTagName,
40  bool supportsQuickLaunch = true, bool enableFavorites = false);
41  ~pqProxyGroupMenuManager() override;
42
46  QMenu* menu() const { return static_cast<QMenu*>(this->parent()); }
47
51  QWidget* widgetActionsHolder() const;
52  QMenu* getFavoritesMenu();
53
58  void setRecentlyUsedMenuSize(unsigned int val) { this->RecentlyUsedMenuSize = val; }
59  unsigned int recentlyUsedMenuSize() const { return this->RecentlyUsedMenuSize; }
64  bool supportsQuickLaunch() const { return this->SupportsQuickLaunch; }
65  void setEnableFavorites(bool enable) { this->EnableFavorites = enable; }
66
70  PARAVIEW_DEPRECATED_IN_5_13_0("Use pqProxyAction::GetProxyPrototype instead.")
71  vtkSMProxy* getPrototype(QAction* action) const;
72
76  void addProxy(const QString& xmlgroup, const QString& xmlname);
77
81  void removeProxy(const QString& xmlgroup, const QString& xmlname);
82
86
91  QStringList getToolbarCategories() const;
95  QString getToolbarName(pqProxyCategory* category);
99  QString categoryLabel(const QString& category);
104  "This was mostly unused. Also it is better to avoid test-dedicated code paths.")
105  bool hideForTests(const QString&) const { return false; };
107
111
115  QList<QAction*> actions() const;
120  QList<QAction*> categoryActions(const QString& category);
124  QList<QAction*> categoryActions(pqProxyCategory* category);
128  QList<QAction*> actionsInToolbars();
132  QAction* getAction(pqProxyInfo* proxy);
136  void updateActionIcon(pqProxyInfo* proxy);
138
147  void addProxyDefinitionUpdateListener(const QString& proxyGroupName);
148  void removeProxyDefinitionUpdateListener(const QString& proxyGroupName);
149
153
158  pqProxyCategory* getApplicationCategory();
163  pqProxyCategory* getMenuCategory();
167  pqProxyCategory* getFavoritesCategory();
172  bool isFavorites(pqProxyCategory* category);
174
175 public Q_SLOTS: // NOLINT(readability-redundant-access-specifiers)
179
186  void loadConfiguration(vtkPVXMLElement*);
191  void lookForNewDefinitions();
195  void removeProxyDefinitionUpdateObservers();
199  void addProxyDefinitionUpdateObservers();
201
202  PARAVIEW_DEPRECATED_IN_5_13_0("Inner member is not used")
203  void setEnabled(bool){};
204
212  virtual void populateMenu();
213
217  void writeCategoryToSettings();
218
219 Q_SIGNALS:
220  void triggered(const QString& group, const QString& name);
221
226  void menuPopulated();
227
231  void categoriesUpdated();
232
233 protected Q_SLOTS:
234  void triggered();
235  void quickLaunch();
236  void switchActiveServer();
237  void updateMenuStyle();
238  void updateActionsStyle();
239
241  void populateRecentlyUsedMenu();
242
248  "Favorites are now a specific category, configurable as the others.")
249  void populateFavoritesMenu();
250
251 protected: // NOLINT(readability-redundant-access-specifiers)
253  vtkPVXMLElement* MenuRoot = nullptr;
254  int RecentlyUsedMenuSize = 0;
255  PARAVIEW_DEPRECATED_IN_5_13_0("Inner member is not used")
256  bool Enabled;
257  bool EnableFavorites = false;
258
259  void loadRecentlyUsedItems();
260  void saveRecentlyUsedItems();
261
266  "Favorites are now a specific category, configurable as the others.")
267  void loadFavoritesItems();
268
270  "Favorites are now a specific category, configurable as the others.")
271  QAction* getAddToFavoritesAction(const QString& path);
272
276  QAction* getAction(const QString& pgroup, const QString& proxyname);
277
278 private Q_SLOTS:
283  void populateAlphabeticalMenu();
287  void populateMiscMenu();
289  void populateCategoriesMenus();
291
292 private: // NOLINT(readability-redundant-access-specifiers)
293  Q_DISABLE_COPY(pqProxyGroupMenuManager)
294
299  QAction* createAction(pqProxyInfo* proxy);
300
304  QAction* createAddToFavoritesAction();
305
309  void clearMenu();
313  void clearCategoriesMenus();
315  void populateSubCategoriesMenus(QMenu* parent, pqProxyCategory* category);
317  void populateCategoryMenu(QMenu* parent, pqProxyCategory* category);
319
323  void loadCategorySettings();
324
325  struct pqInternal;
326  std::unique_ptr<pqInternal> Internal;
327  bool SupportsQuickLaunch = true;
328 };
329
330 #endif
When size>0 a recently used category will be added to the menu.
pqProxyGroupMenuManager is a menu-populator that fills up a menu with proxies defined in an XML confi...
Returns true if the pqProxyGroupMenuManager has been registered with quick-launch mechanism maintaine...
Proxy meta data structure for the User Interface.
Definition: pqProxyInfo.h:20
name
#define PARAVIEW_DEPRECATED_IN_5_13_0(reason)
Definition: vtkSMProxy.h:140
The pqProxyCategory class reads and writes XML that describes the proxies organisation into categorie...
#define const
Definition: zconf.h:238
QMenu * menu() const
Access the menu.
