pqScalarsToColors.h
4 #ifndef pqScalarsToColors_h
5 #define pqScalarsToColors_h
6
7 #include "pqProxy.h"
8 #include <QList>
9 #include <QPair>
10 #include <QVariant>
11
12 class pqRenderViewBase;
14 class pqScalarsToColorsInternal;
15
19 class PQCORE_EXPORT pqScalarsToColors : public pqProxy
20 {
21  Q_OBJECT
22 public:
23  pqScalarsToColors(const QString& group, const QString& name, vtkSMProxy* proxy, pqServer* server,
24  QObject* parent = nullptr);
25  ~pqScalarsToColors() override;
26
30  pqScalarBarRepresentation* getScalarBar(pqRenderViewBase* ren) const;
31
35  bool getScalarRangeLock() const;
36
42  void setScalarRange(double min, double max);
43
48  QPair<double, double> getScalarRange() const;
49
53  bool getUseLogScale() const;
54
55  enum Mode
56  {
57  MAGNITUDE = 0,
58  COMPONENT = 1
59  };
60
61  // Set the color mode (component/magnitude) and
62  // component to color by. When mode is magnitude, component is ignored.
63  void setVectorMode(Mode mode, int component);
64
65  // Returns the vector mode and component used by the Lookup table.
66  // When vector mode is MAGNITUDE, value returned by
67  // getVectorComponent() is indeterminate.
68  Mode getVectorMode() const;
69  int getVectorComponent() const;
70
75  void updateScalarBarTitles(const QString& component);
76
78  {
79  GROW_ON_MODIFIED, /* only when a pipeline object is explicitly modified */
80  GROW_ON_UPDATED /* any time the pipeline updates */
81  };
82
95  static void setColorRangeScalingMode(int);
96  static int colorRangeScalingMode(int default_value = GROW_ON_MODIFIED);
97
98 Q_SIGNALS:
103  void componentOrModeChanged();
104
105 public Q_SLOTS:
106  // This method checks if this LUT is used by any display,
107  // if not, it hides all the scalars bar showing this LUT.
108  void hideUnusedScalarBars();
109
113  void setScalarRangeLock(bool lock);
114
118  void build();
119
120 protected Q_SLOTS:
125  void checkRange();
126
127 private:
128  pqScalarsToColorsInternal* Internal;
129 };
130
131 #endif
pqScalarsToColors is a represents a vtkScalarsToColors proxy.
name
pqScalarBarRepresentation is created for "ScalarBarWidgetRepresentation" proxies. ...
This class represents any registered Server Manager proxy.
Definition: pqProxy.h:28
pqRenderViewBase is an abstract base class for all render-view based views.
Definition: vtkSMProxy.h:140
#define max(a, b)
pqServer (should be renamed to pqSession) is a pqServerManagerModelItem subclass that represents a vt...
Definition: pqServer.h:35
