pqStandardPropertyWidgetInterface.h
4 #ifndef pqStandardPropertyWidgetInterface_h
5 #define pqStandardPropertyWidgetInterface_h
6
7 #include "pqApplicationComponentsModule.h"
9
15 class PQAPPLICATIONCOMPONENTS_EXPORT pqStandardPropertyWidgetInterface
16  : public QObject
18 {
19  Q_OBJECT
20  Q_INTERFACES(pqPropertyWidgetInterface)
21 public:
22  pqStandardPropertyWidgetInterface(QObject* p = nullptr);
24
58  vtkSMProxy* proxy, vtkSMProperty* property, QWidget* parentWidget) override;
59
94  vtkSMProxy* proxy, vtkSMPropertyGroup* group, QWidget* parentWidget) override;
95
113  const QString& type, vtkPVXMLElement* config, pqPropertyWidget* widget) override;
114
120  void createDefaultWidgetDecorators(pqPropertyWidget* widget) override;
121 };
122
123 #endif // pqStandardPropertyWidgetInterface_h
virtual pqPropertyWidget * createWidgetForPropertyGroup(vtkSMProxy *proxy, vtkSMPropertyGroup *group, QWidget *parentWidget)
Given a proxy and its property group, create a widget for the same, of possible.
pqPropertyWidget represents a widget created for each property of a proxy on the pqPropertiesPanel (f...
virtual pqPropertyWidgetDecorator * createWidgetDecorator(const QString &type, vtkPVXMLElement *config, pqPropertyWidget *widget)
Given the type of the decorator and the pqPropertyWidget that needs to be decorated, create the pqPropertyWidgetDecorator instance, if possible.
virtual pqPropertyWidget * createWidgetForProperty(vtkSMProxy *proxy, vtkSMProperty *property, QWidget *parentWidget)
Given a proxy and its property, create a widget for the same, of possible.
type
pqStandardPropertyWidgetInterface provides a concrete implementation of pqPropertyWidget used by Para...
pqPropertyWidgetInterface is part of the ParaView Plugin infrastructure that enables support for plug...
Definition: vtkSMProxy.h:140
virtual void createDefaultWidgetDecorators(pqPropertyWidget *widget)
Create all default decorators for a specific widget.
pqPropertyWidgetDecorator provides a mechanism to decorate pqPropertyWidget instances to add logic to...
