23 #ifndef vtkPEnSightGoldReader_h 24 #define vtkPEnSightGoldReader_h 29 class UndefPartialInternal;
64 int component = 0)
override;
121 int CreateRectilinearGridOutput(
128 int CreateImageDataOutput(
134 int ReadOrSkipCoordinates(
135 vtkPoints* points,
long offset,
int partId,
int* lineRead,
char* line,
bool skip);
141 int InjectCoordinatesAtEnd(
vtkUnstructuredGrid* output,
long coordinatesOffset,
int partId);
147 int CheckForUndefOrPartial(
const char* line);
virtual int ReadScalarsPerElement(const char *fileName, const char *description, int timeStep, vtkMultiBlockDataSet *output, int numberOfComponents=1, int component=0)=0
Read scalars per element for this dataset.
virtual int CreateStructuredGridOutput(int partId, char line[80], const char *name, vtkMultiBlockDataSet *output)=0
Read a structured part from the geometry file and create a vtkStructuredGridOutput.
Superclass for EnSight file parallel readers.
Parallel version of vtkEnSightGoldReader.
virtual int ReadScalarsPerNode(const char *fileName, const char *description, int timeStep, vtkMultiBlockDataSet *output, int measured=0, int numberOfComponents=1, int component=0)=0
Read scalars per node for this dataset.
UndefPartialInternal * UndefPartial
Handle the undef / partial support for EnSight gold.
virtual int ReadMeasuredGeometryFile(const char *fileName, int timeStep, vtkMultiBlockDataSet *output)=0
Read the measured geometry file.
virtual int ReadVectorsPerElement(const char *fileName, const char *description, int timeStep, vtkMultiBlockDataSet *output)=0
Read vectors per element for this dataset.
static vtkPGenericEnSightReader * New()
virtual int ReadTensorsPerNode(const char *fileName, const char *description, int timeStep, vtkMultiBlockDataSet *output)=0
Read tensors per node for this dataset.
virtual int CreateUnstructuredGridOutput(int partId, char line[80], const char *name, vtkMultiBlockDataSet *output)=0
Read an unstructured part (partId) from the geometry file and create a vtkUnstructuredGrid output...
virtual int ReadVectorsPerNode(const char *fileName, const char *description, int timeStep, vtkMultiBlockDataSet *output, int measured=0)=0
Read vectors per node for this dataset.
virtual int ReadGeometryFile(const char *fileName, int timeStep, vtkMultiBlockDataSet *output)=0
Read the geometry file.
#define VTKPVVTKEXTENSIONSIOENSIGHT_EXPORT
virtual int ReadTensorsPerElement(const char *fileName, const char *description, int timeStep, vtkMultiBlockDataSet *output)=0
Read tensors per element for this dataset.
