vtkSMDoubleMapProperty.h
10 #ifndef vtkSMDoubleMapProperty_h
11 #define vtkSMDoubleMapProperty_h
12
13 #include "vtkRemotingServerManagerModule.h" //needed for exports
14 #include "vtkSMMapProperty.h"
15
16 class vtkSMDoubleMapPropertyPrivate;
18
20 {
21 public:
22  static vtkSMDoubleMapProperty* New();
24  void PrintSelf(ostream& os, vtkIndent indent) override;
25
29  void SetNumberOfComponents(unsigned int components);
30
34  unsigned int GetNumberOfComponents();
35
39  void SetElement(vtkIdType index, double value);
40
44  void SetElements(vtkIdType index, const double* values);
45
49  void SetElements(vtkIdType index, const double* values, unsigned int numValues);
50
54  void SetElementComponent(vtkIdType index, unsigned int component, double value);
55
59  double GetElement(vtkIdType index);
60
64  double* GetElements(vtkIdType index);
65
69  double GetElementComponent(vtkIdType index, vtkIdType component);
70
74  void RemoveElement(vtkIdType index);
75
79  vtkIdType GetNumberOfElements() override;
80
84  bool HasElement(vtkIdType index);
85
89  void ClearElements();
90
95  vtkSMDoubleMapPropertyIterator* NewIterator();
96
97  void* GetMapPointer();
98
102  void Copy(vtkSMProperty* src) override;
103
109  void ResetToXMLDefaults() override;
110
111 protected:
113  ~vtkSMDoubleMapProperty() override;
114
115  void WriteTo(vtkSMMessage* msg) override;
116
117  void ReadFrom(
118  const vtkSMMessage* message, int message_offset, vtkSMProxyLocator* locator) override;
119
120  int ReadXMLAttributes(vtkSMProxy* parent, vtkPVXMLElement* element) override;
121
122  void SaveStateValues(vtkPVXMLElement* propertyElement) override;
123  int LoadState(vtkPVXMLElement* element, vtkSMProxyLocator* loader) override;
124
125 private:
127  void operator=(const vtkSMDoubleMapProperty&) = delete;
128
129  vtkSMDoubleMapPropertyPrivate* Private;
130 };
131
132 #endif // vtkSMDoubleMapProperty_h
virtual void SaveStateValues(vtkPVXMLElement *propertyElement)
This method must be overridden by concrete class in order to save the real property data...
virtual void WriteTo(vtkSMMessage *msg)
Let the property write its content into the stream.
int ReadXMLAttributes(vtkSMProxy *parent, vtkPVXMLElement *element) override
int vtkIdType
a map property storing double values
virtual vtkIdType GetNumberOfElements()
Returns the number of elements for the value type.
int LoadState(vtkPVXMLElement *element, vtkSMProxyLocator *loader) override
Updates state from an XML element.
void Copy(vtkSMProperty *src) override
Copy all property values.
static vtkSMProperty * New()
#define VTK_NEWINSTANCE
virtual void ReadFrom(const vtkSMMessage *, int vtkNotUsed(message_offset), vtkSMProxyLocator *)
Definition: vtkSMProxy.h:140
virtual void ResetToXMLDefaults()
For properties that support specifying defaults in XML configuration, this method will reset the prop...
abstract superclass for all map properties
