void | SetNumberOfComponents (unsigned int components) |
| Sets the number of components. More...
unsigned int | GetNumberOfComponents () |
| Returns the number of components. More...
void | SetElement (vtkIdType index, double value) |
| Sets the element at index to value. More...
void | SetElements (vtkIdType index, const double *values) |
| Sets the elements at index to values. More...
void | SetElements (vtkIdType index, const double *values, unsigned int numValues) |
void | SetElementComponent (vtkIdType index, unsigned int component, double value) |
| Sets the component at index to value. More...
double | GetElement (vtkIdType index) |
| Returns the element at index. More...
double * | GetElements (vtkIdType index) |
| Returns the elements at index. More...
double | GetElementComponent (vtkIdType index, vtkIdType component) |
| Returns the element component at index. More...
void | RemoveElement (vtkIdType index) |
| Removes the element at index. More...
vtkIdType | GetNumberOfElements () override |
| Returns the number of elements. More...
bool | HasElement (vtkIdType index) |
| Returns true if the property has an element with the given index. More...
void | ClearElements () |
| Clears all of the elements from the property. More...
VTK_NEWINSTANCE vtkSMDoubleMapPropertyIterator * | NewIterator () |
| Returns a new iterator for the map. More...
void * | GetMapPointer () |
void | Copy (vtkSMProperty *src) override |
| Copy all property values. More...
void | ResetToXMLDefaults () override |
| For properties that support specifying defaults in XML configuration, this method will reset the property value to the default values specified in the XML. More...
bool | IsValueDefault () override |
| Returns true if the current value is the same as the default value. More...
int | IsInDomains () |
| Returns true if all values are in all domains, false otherwise. More...
int | IsInDomains (vtkSMDomain **domain) |
| Overload of IsInDomains() that provides a mechanism to return the first domain that fails the check. More...
void | UnRegister (vtkObjectBase *obj) override |
| Overloaded to break the reference loop caused by the internal domain iterator. More...
vtkSMDomainIterator * | NewDomainIterator () |
| Creates, initializes and returns a new domain iterator. More...
vtkSMDomain * | GetDomain (const char *name) |
| Returns a domain give a name. More...
vtkSMDomain * | FindDomain (const char *classname) |
| Returns the first domain which is of the specified type. More...
template<class DomainType > |
DomainType * | FindDomain () |
| Same as FindDomain(classname), except the classname is deduced from the type. More...
unsigned int | GetNumberOfDomains () |
| Returns the number of domains this property has. More...
void | AddDomain (const char *name, vtkSMDomain *dom) |
| Properties can have one or more domains. More...
virtual void | AddLinkedProperty (vtkSMProperty *targetProperty) |
| Add a link to a property whose value should be synchronized with this property value. More...
virtual void | RemoveLinkedProperty (vtkSMProperty *targetProperty) |
| Remove a link to a property added with AddLinkedProperty() More...
virtual void | RemoveFromSourceLink () |
| Remove a link from the source property. More...
void | ResetToDefault () |
| Simply calls this->ResetToDomainDefaults() and if that returns false, calls this->ResetToXMLDefaults(). More...
virtual bool | ResetToDomainDefaults (bool use_unchecked_values=false) |
| Iterates over all domains and call SetDefaultValues() on each domain until the first one returns true i.e. More...
bool | ResetToSettings (double priority) |
| Reset property value with settings. More...
vtkSMProxy * | GetParent () |
| Get the proxy to which this property belongs. More...
virtual bool | IsStateIgnored () |
bool | HasDomainsWithRequiredProperties () |
| Returns true if the property has a domain with required properties. More...
virtual void | ClearUncheckedElements () |
| Use this method to clear unchecked values set of this property. More...
virtual void | SetCommand (const char *) |
| The command name used to set the value on the server object. More...
virtual char * | GetCommand () |
virtual void | SetImmediateUpdate (int) |
| If ImmediateUpdate is true, the value of the property will be pushed to the server as soon as it is modified. More...
virtual int | GetImmediateUpdate () |
virtual int | GetInformationOnly () |
| Is InformationOnly is set to true, this property is used to get information from server instead of setting values. More...
virtual int | GetIgnoreSynchronization () |
| If IgnoreSynchronization is set to true, this property is used to prevent that property from being updated when changed remotely by another collaborative client. More...
virtual vtkSMProperty * | GetInformationProperty () |
| Get the associated information property. More...
virtual void | SetAnimateable (int) |
| Get/Set if the property is animateable. More...
virtual int | GetAnimateable () |
virtual void | SetIsInternal (int) |
| Get/Set if the property is internal to server manager. More...
virtual int | GetIsInternal () |
virtual void | SetNoCustomDefault (int) |
| Set/Get whether the property should ignore custom default settings. More...
virtual int | GetNoCustomDefault () |
virtual void | SetPanelVisibility (const char *) |
| Set/Get the panel visibility for the property. More...
virtual char * | GetPanelVisibility () |
virtual void | SetPanelVisibilityDefaultForRepresentation (const char *) |
| Set/Get the panel visibility to default if the current representation type matches representation . More...
virtual char * | GetPanelVisibilityDefaultForRepresentation () |
virtual void | SetPanelWidget (const char *) |
| Set/Get the name of the custom panel widget to use for the property. More...
virtual char * | GetPanelWidget () |
virtual void | SetDisableSubTrace (const char *) |
| Set/Get the tracing of sub property of this property. More...
virtual char * | GetDisableSubTrace () |
| The label assigned by the xml parser. More...
| The name assigned by the xml parser. More...
virtual int | GetRepeatable () |
| If repeatable, a property can have 1 or more values of the same kind. More...
| The server manager configuration XML may define <Hints/> element for a property. More...
void | SetHints (vtkPVXMLElement *hints) |
void | Modified () override |
| Overridden to support blocking of modified events. More...
