#include <pqBlockProxyWidget.h>
Public Slots | |
void | apply () const override |
bool | filterWidgets (bool show_advanced=false, const QString &filterText=QString()) |
Updates the property widgets shown based on the filterText or show_advanced flag. More... | |
void | showLinkedInteractiveWidget (int portIndex, bool show, bool changeFocus) |
Show any interactive widget linked to a specific output port this proxyWdiget has. More... | |
virtual void | apply () const |
Accepts the property widget changes changes. More... | |
void | reset () const |
Cleans the property widget changes and resets the widgets. More... | |
void | setView (pqView *) |
Set the current view to use to show 3D widgets, if any for the panel. More... | |
void | updatePanel () |
Same as calling filterWidgets() with the arguments specified to the most recent call to filterWidgets(). More... | |
virtual bool | restoreDefaults () |
Restores application default proxy settings. More... | |
void | saveAsDefaults () |
Saves settings as defaults for proxy. More... | |
static pqPropertyWidget * | createWidgetForProperty (vtkSMProperty *property, vtkSMProxy *proxy, QWidget *parentObj) |
create a widget for a property. More... | |
pqBlockProxyWidget (vtkSMProxy *proxy, QString selector, QWidget *parent, Qt::WindowFlags flags=Qt::WindowFlags{}) | |
~pqBlockProxyWidget () override | |
pqProxyWidget (vtkSMProxy *proxy, const QStringList &properties, std::initializer_list< QString > defaultLabels, std::initializer_list< QString > advancedLabels, bool showHeadersFooters=true, QWidget *parent=nullptr, Qt::WindowFlags flags=Qt::WindowFlags{}) | |
pqProxyWidget (vtkSMProxy *proxy, std::initializer_list< QString > defaultLabels, std::initializer_list< QString > advancedLabels, QWidget *parent=nullptr, Qt::WindowFlags flags=Qt::WindowFlags{}) | |
pqProxyWidget (vtkSMProxy *proxy, const QStringList &properties, bool showHeadersFooters=true, QWidget *parent=nullptr, Qt::WindowFlags flags=Qt::WindowFlags{}) | |
pqProxyWidget (vtkSMProxy *proxy, QWidget *parent, Qt::WindowFlags flags=Qt::WindowFlags{}) | |
pqProxyWidget (vtkSMProxy *proxy) | |
~pqProxyWidget () override | |
vtkSMProxy * | proxy () const |
Returns the proxy this panel shows. More... | |
void | setApplyChangesImmediately (bool value) |
When set to true, whenever the widget changes, the values are immediately pushed to the ServerManager property without having to wait for apply(). More... | |
bool | applyChangesImmediately () const |
bool | useDocumentationForLabels () const |
When this is true, the panel uses a descriptive layout where the documentation for properties is used instead of their labels. More... | |
void | showContextMenu (const QPoint &pt, pqPropertyWidget *propWidget) |
const QSet< QString > & | defaultVisibilityLabels () const |
pqProxyWidget shows widgets for properties in two configurations: basic and advanced. More... | |
const QSet< QString > & | advancedVisibilityLabels () const |
Protected Slots | |
void | onChangeFinished () override |
virtual void | onChangeFinished () |
Called when a pqPropertyWidget fires changeFinished() signal. More... | |
enum | DocumentationType { NONE, USE_DESCRIPTION, USE_SHORT_HELP, USE_LONG_HELP } |
void | changeAvailable () |
This signal is fired as soon as the user starts editing in the widget. More... | |
void | changeFinished () |
This signal is fired as soon as the user is done with making an atomic change. More... | |
void | restartRequired () |
Indicates that a restart of the program is required for the setting to take effect. More... | |
static QWidget * | newGroupLabelWidget (const QString &label, QWidget *parentWidget, const QList< QWidget *> &buttons=QList< QWidget *>()) |
Returns a new widget that has the label and a h-line separator. More... | |
static bool | useDocumentationForLabels (vtkSMProxy *proxy) |
Returns true of the proxy provided has XML hints indicating that labels should use documentation instead of the XML label for the widgets in the UI. More... | |
static QString | documentationText (vtkSMProperty *property, DocumentationType type=USE_DESCRIPTION) |
Returns formatted (HTML or plainText) documentation for the property. More... | |
static QString | documentationText (vtkSMProxy *property, DocumentationType type=USE_DESCRIPTION) |
Returns formatted (HTML or plainText) documentation for the proxy. More... | |
static DocumentationType | showProxyDocumentationInPanel (vtkSMProxy *proxy) |
Returns true if the proxy has XML hints indicating that the panel should show a header label for the documentation. More... | |
void | showEvent (QShowEvent *event) override |
void | hideEvent (QHideEvent *event) override |
void | applyInternal () const |
Definition at line 12 of file pqBlockProxyWidget.h.
pqBlockProxyWidget::pqBlockProxyWidget | ( | vtkSMProxy * | proxy, |
QString | selector, | ||
QWidget * | parent, | ||
Qt::WindowFlags | flags = Qt::WindowFlags{} |
overrideslot |
overrideprotectedslot |
