runtime configuration options for ParaView Qt client More...
#include <pqCoreConfiguration.h>
Inherits QObject.
const std::string & | stateFileName () const |
Returns state file to load on startup, if any. More... | |
const std::vector< std::string > & | dataFileNames () const |
Returns data file to load on startup, if any. More... | |
const std::string & | pythonScript () const |
Returns the Python script to load on startup, if any. More... | |
const std::string & | baselineDirectory () const |
Returns directory where to output test results and temporary files, if any else an empty string is returned. More... | |
const std::string & | testDirectory () const |
const std::string & | dataDirectory () const |
Returns directory containing test data files, if any, else an empty string is returned. More... | |
bool | exitApplicationWhenTestsDone () const |
Returns true if the application should exit after test playback is complete. More... | |
int | catalystLivePort () const |
When specified, ParaView will attempt to connect a Catalyst Live session at the given port. More... | |
bool | populateOptions (vtkCLIOptions *options) |
Populate vtkCLIOptions instance with command line options to control the configurable options provided by this class. More... | |
int | testScriptCount () const |
Returns information about tests scripts. More... | |
const std::string & | testScript (int index) const |
const std::string & | testBaseline (int index) const |
int | testThreshold (int index) const |
void | setActiveTestIndex (int index) |
A little bit of hack to activate a particular test script. More... | |
const std::string & | testScript () const |
const std::string & | testBaseline () const |
int | testThreshold () const |
bool | testMaster () const |
Collaboration testing related flags. More... | |
bool | testSlave () const |
static pqCoreConfiguration * | instance () |
Provides access to the singleton. More... | |
pqCoreConfiguration () | |
~pqCoreConfiguration () override | |
class | pqPVApplicationCore |
void | addDataFile (const std::string &data) |
pqCoreConfiguration is a singleton that maintains runtime configuration options for the ParaView Qt client.
Definition at line 25 of file pqCoreConfiguration.h.
Definition at line 37 of file pqCoreConfiguration.h.
Definition at line 42 of file pqCoreConfiguration.h.
Definition at line 47 of file pqCoreConfiguration.h.
Definition at line 53 of file pqCoreConfiguration.h.
Definition at line 59 of file pqCoreConfiguration.h.
Definition at line 65 of file pqCoreConfiguration.h.
Definition at line 71 of file pqCoreConfiguration.h.
Definition at line 72 of file pqCoreConfiguration.h.
Definition at line 73 of file pqCoreConfiguration.h.
Definition at line 74 of file pqCoreConfiguration.h.
Definition at line 81 of file pqCoreConfiguration.h.
Definition at line 87 of file pqCoreConfiguration.h.
bool pqCoreConfiguration::populateOptions | ( | vtkCLIOptions * | options | ) |
Definition at line 99 of file pqCoreConfiguration.h.
Definition at line 100 of file pqCoreConfiguration.h.
Definition at line 101 of file pqCoreConfiguration.h.
Definition at line 102 of file pqCoreConfiguration.h.
Definition at line 109 of file pqCoreConfiguration.h.
Definition at line 110 of file pqCoreConfiguration.h.
inlineprotected |
Definition at line 121 of file pqCoreConfiguration.h.
friend |
Definition at line 120 of file pqCoreConfiguration.h.
