pqPVApplicationCore is the application code used by ParaView-based applications that use more of ParaView's functionality than that provided by pqApplicationCore such as the the selection manager, animation manager etc. More...
#include <pqPVApplicationCore.h>
Public Slots | |
void | applyPipeline () |
A useful slot to trigger an apply on the pipeline. More... | |
void | quickLaunch () |
Pops-up the quick launch dialog. More... | |
void | startSearch () |
Pops-up the search dialog if the focused widget is QAsbstractItemView type. More... | |
void | prepareForQuit () |
Applications calls this to ensure that any cleanup is performed correctly. More... | |
void | quit () |
Calls QCoreApplication::quit(). More... | |
void | updateAvailableReadersAndWriters () |
Update the available readers and writers using the factories. More... | |
void | render () |
Renders all windows. More... | |
void | loadConfiguration (const QString &filename) |
Load configuration xml. More... | |
void | loadConfigurationXML (const char *xmldata) |
Signals | |
void | aboutToShowQuickLaunch () |
Emitted whenever the quickLaunch dialog is about to show. More... | |
void | triggerApply () |
void | aboutToWriteState (QString filename) |
Fired before a state file, either python or XML, is written. More... | |
void | aboutToReadState (QString filename) |
Fired before a state file, either python or XML, is read. More... | |
void | aboutToLoadState (vtkPVXMLElement *root) |
Fired before a state xml is being loaded. More... | |
void | stateLoaded (vtkPVXMLElement *root, vtkSMProxyLocator *locator) |
Fired when a state file is loaded successfully. More... | |
void | stateSaved (vtkPVXMLElement *root) |
Fired to save state xml. More... | |
void | undoStackChanged (pqUndoStack *) |
Fired when the undo stack is set. More... | |
void | loadXML (vtkPVXMLElement *) |
Fired on loadConfiguration(). More... | |
void | forceFilterMenuRefresh () |
Fired when the filter menu state needs to be manually updated. More... | |
void | updateMasterEnableState (bool) |
Fired when master changed. More... | |
void | clientEnvironmentDone () |
Fired when the ParaView Client infrastructure has completed setting up the environment. More... | |
pqPVApplicationCore (int &argc, char **argv, vtkCLIOptions *options=nullptr, bool addStandardArgs=true, QObject *parent=nullptr) | |
~pqPVApplicationCore () override | |
pqSelectionManager * | selectionManager () const |
Provides access to the selection manager. More... | |
pqAnimationManager * | animationManager () const |
Provides access to the animation manager. More... | |
pqTestUtility * | testUtility () override |
Provides access to the test utility. More... | |
pqPythonManager * | pythonManager () const |
Provides access to the python manager. More... | |
pqLiveSourceManager * | liveSourceManager () const |
Provides access to the live source manager. More... | |
virtual void | registerForQuicklaunch (QWidget *) |
ParaView provides a mechanism to trigger menu actions using a quick-launch dialog. More... | |
void | loadStateFromPythonFile (const QString &filename, pqServer *server, vtkTypeUInt32 location=0x10) |
void | instantiateLiveSourceManager () |
Instantiate the live source manager, if it has not been done yet. More... | |
pqApplicationCore (int &argc, char **argv, vtkCLIOptions *options=nullptr, bool addStandardArgs=true, QObject *parent=nullptr) | |
Initializes the ParaView application engine. More... | |
pqObjectBuilder * | getObjectBuilder () const |
Get the Object Builder. More... | |
void | setUndoStack (pqUndoStack *stack) |
Set/Get the application's central undo stack. More... | |
pqUndoStack * | getUndoStack () const |
void | registerManager (const QString &function, QObject *manager) |
Custom Applications may need use various "managers" All such manager can be registered with the pqApplicationCore so that that can be used by other components of the application. More... | |
QObject * | manager (const QString &function) |
Returns a manager for a particular function, if any. More... | |
void | unRegisterManager (const QString &function) |
Unregisters a manager for a particular function, if any. More... | |
QHelpEngine * | helpEngine () |
provides access to the help engine. More... | |
void | registerDocumentation (const QString &filename) |
QHelpEngine doesn't like filenames in resource space. More... | |
pqServerManagerObserver * | getServerManagerObserver () |
ServerManagerObserver observer the vtkSMProxyManager for changes to the server manager and fires signals on certain actions such as registeration/unregistration of proxies etc. More... | |
pqServerManagerModel * | getServerManagerModel () const |
ServerManagerModel is the representation of the ServerManager using pqServerManagerModelItem subclasses. More... | |
pqInterfaceTracker * | interfaceTracker () const |
Locates the interface tracker for the application. More... | |
pqLinksModel * | getLinksModel () const |
pqLinksModel is the model used to keep track of proxy/property links maintained by vtkSMProxyManager. More... | |
pqMainWindowEventManager * | getMainWindowEventManager () const |
pqMainWindowManager manages signals called for main window events. More... | |
pqPluginManager * | getPluginManager () const |
pqPluginManager manages all functionality associated with loading plugins. More... | |
pqProgressManager * | getProgressManager () const |
ProgressManager is the manager that streamlines progress. More... | |
pqRecentlyUsedResourcesList & | recentlyUsedResources () |
Returns the set of recently-used resources i.e. More... | |
pqServerConfigurationCollection & | serverConfigurations () |
Returns the collection of server configurations known. More... | |
pqSettings * | settings () |
Get the application settings. More... | |
void | clearSettings () |
Clears the settings. More... | |
vtkPVXMLElement * | saveState () |
Save the ServerManager state to a XML element. More... | |
bool | saveState (const QString &filename, vtkTypeUInt32 location=0x10) |
Save the ServerManager state to a file. More... | |
void | loadState (vtkPVXMLElement *root, pqServer *server, vtkSMStateLoader *loader=nullptr) |
Loads the ServerManager state. More... | |
void | loadState (const char *filename, pqServer *server, vtkSMStateLoader *loader=nullptr) |
Load state xml from a file. More... | |
void | loadStateFromString (const char *xmlcontents, pqServer *server, vtkSMStateLoader *loader=nullptr) |
Loads state from an in-memory buffer. More... | |
void | clearViewsForLoadingState (pqServer *server) |
void | loadStateIncremental (vtkPVXMLElement *root, pqServer *server, vtkSMStateLoader *loader=nullptr) |
Same as loadState() except that it doesn't clear the current visualization state. More... | |
void | loadStateIncremental (const QString &filename, pqServer *server, vtkSMStateLoader *loader=nullptr) |
void | setLoadingState (bool value) |
Set the loading state flag. More... | |
bool | isLoadingState () |
Check to see if its in the process of loading a state Reliance on this flag is chimerical since we cannot set this ivar when state file is being loaded from python shell. More... | |
pqServer * | getActiveServer () const |
returns the active server is any. More... | |
QString | getTranslationsPathFromInterfaceLanguage (QString prefix, QString locale) |
returns a path to a directory containing a translation binary file located in a path specified by the PV_TRANSLATIONS_DIR environment variable or in the resources directory. More... | |
QTranslator * | getQtTranslations (QString prefix, QString locale) |
returns a QTranslator with a loaded qm file. More... | |
QString | getInterfaceLanguage () |
returns interface language in use in a locale code form. More... | |
~pqApplicationCore () override | |
Destructor. More... | |
void | _paraview_client_environment_complete () |
INTERNAL. More... | |
static pqPVApplicationCore * | instance () |
Returns the pqPVApplicationCore instance. More... | |
static pqApplicationCore * | instance () |
bool | eventFilter (QObject *obj, QEvent *event) override |
Override event filter in order to catch file association mechanism. More... | |
Protected Attributes | |
QPointer< pqSelectionManager > | SelectionManager |
QPointer< pqAnimationManager > | AnimationManager |
QPointer< pqLiveSourceManager > | LiveSourceManager |
pqPythonManager * | PythonManager |
QList< QPointer< QWidget > > | QuickLaunchMenus |
bool | LoadingState |
pqLinksModel * | LinksModel |
pqObjectBuilder * | ObjectBuilder |
pqInterfaceTracker * | InterfaceTracker |
pqMainWindowEventManager * | MainWindowEventManager |
pqPluginManager * | PluginManager |
pqProgressManager * | ProgressManager |
pqServerManagerModel * | ServerManagerModel |
pqServerManagerObserver * | ServerManagerObserver |
pqUndoStack * | UndoStack |
pqRecentlyUsedResourcesList * | RecentlyUsedResourcesList |
pqServerConfigurationCollection * | ServerConfigurations |
pqSettings * | Settings |
QHelpEngine * | HelpEngine |
QPointer< pqTestUtility > | TestUtility |
void | onStateLoaded (vtkPVXMLElement *root, vtkSMProxyLocator *locator) |
void | onStateSaved (vtkPVXMLElement *root) |
void | onHelpEngineWarning (const QString &) |
Definition at line 26 of file pqPVApplicationCore.h.
pqPVApplicationCore::pqPVApplicationCore | ( | int & | argc, |
char ** | argv, | ||
vtkCLIOptions * | options = nullptr , |
bool | addStandardArgs = true , |
QObject * | parent = nullptr |
inlinestatic |
If no pqPVApplicationCore has been created then return nullptr.
Definition at line 40 of file pqPVApplicationCore.h.
pqSelectionManager* pqPVApplicationCore::selectionManager | ( | ) | const |
Selection manager provides access to the ParaView wide data selection mechanism. This must not be confused with the active-object selection.
pqAnimationManager* pqPVApplicationCore::animationManager | ( | ) | const |
Animation manager helps with the animation subsystem – saving movies, creating scenes etc.
Reimplemented from pqApplicationCore.
pqPythonManager* pqPVApplicationCore::pythonManager | ( | ) | const |
This is non-nullptr only when paraview is compiled with python support i.e. PARAVIEW_USE_PYTHON is ON.
pqLiveSourceManager* pqPVApplicationCore::liveSourceManager | ( | ) | const |
This can be nullptr if the live source manager was not instantiated first. (Either with pqLiveSourceBehavior or directly with instantiateLiveSourceManager()).
Applications can register menus action from which should be launch-able from the quick-launch dialog. Typical candidates are the sources menu, filters menu etc.
void pqPVApplicationCore::loadStateFromPythonFile | ( | const QString & | filename, |
pqServer * | server, | ||
vtkTypeUInt32 | location = 0x10 |
void pqPVApplicationCore::instantiateLiveSourceManager | ( | ) |
This method was designed to be called by pqLiveSourceBehavior.
slot |
This is just emitting a signal usually caught by a pqApplyBehavior.
slot |
slot |
signal |
This can be used to update the menu items (QActions) that will be shown in the quick-launch dialog.
signal |
Definition at line 127 of file pqPVApplicationCore.h.
Definition at line 128 of file pqPVApplicationCore.h.
Definition at line 129 of file pqPVApplicationCore.h.
Definition at line 131 of file pqPVApplicationCore.h.
Definition at line 132 of file pqPVApplicationCore.h.
