Public Slots | Signals | Public Member Functions | Protected Slots | List of all members
pqAnimationManager Class Reference
pqAnimationManager manages the Animation sub-system. More...
#include <pqAnimationManager.h>
Inherits QObject.
Public Slots
void onActiveServerChanged (pqServer *)
Signals
void activeSceneChanged (pqAnimationScene *scene)
 emitted when the active scene changes (scene may be nullptr). More...
void activeServerChanged (pqServer *scene)
 emitted when the active server changes and updated active scene. More...
void saveProgress (const QString &, int)
 emitted with the current save progress. More...
void beginNonUndoableChanges ()
 emitted when the manager begins changes that should not get recorded on the undo stack. More...
void endNonUndoableChanges ()
 emitted when the manager is done with changes that should not get recorded on the undo stack. More...
void writeAnimation (const QString &filename, int magnification, double frameRate)
 emitted to indicate an animation is being written out to a file. More...
void beginPlay (vtkObject *caller, unsigned long, void *, void *reversed)
 Emitted when the active animation scene begins playing. More...
void endPlay (vtkObject *caller, unsigned long, void *, void *reversed)
 Emitted when the active animation scene finishes playing. More...
 pqAnimationManager (QObject *parent=nullptr)
 ~pqAnimationManager () override
pqAnimationScenegetActiveScene () const
 Returns the scene for the active server connection, if any. More...
pqAnimationScenegetScene (pqServer *server) const
 Returns the scene on the server connection, if any. More...
pqAnimationCuegetCue (pqAnimationScene *scene, vtkSMProxy *proxy, const char *propertyname, int index) const
 In the given scene, returns the cue that animates the given index of the given property on the proxy. More...
bool saveGeometry (const QString &filename, pqView *view)
 Saves the animation geometry from the active scene as visible in the given view. More...
bool animationPlaying () const
 Query whether or not an animation is currently playing. More...
Protected Slots
void onProxyAdded (pqProxy *)
void onProxyRemoved (pqProxy *)
void onTick (int)
 Called on every tick while saving animation. More...
void onBeginPlay (vtkObject *caller, unsigned long, void *, void *reversed)
 Called to demarcate the start and end of an animation. More...
void onEndPlay (vtkObject *caller, unsigned long, void *, void *reversed)
It encapsulates the initialization of animation scene per server connection i.e. this class basically keeps track of the active animation scene.
Definition at line 27 of file pqAnimationManager.h.
◆ pqAnimationManager()
pqAnimationManager::pqAnimationManager ( QObject *  parent = nullptr)
◆ ~pqAnimationManager()
pqAnimationManager::~pqAnimationManager ( )
override
◆ getActiveScene()
pqAnimationScene* pqAnimationManager::getActiveScene ( ) const
◆ getScene()
pqAnimationScene* pqAnimationManager::getScene ( pqServer server) const
◆ getCue()
pqAnimationCue* pqAnimationManager::getCue ( pqAnimationScene scene,
vtkSMProxy proxy,
const char *  propertyname,
int  index
) const
This method simply calls getCue() on the pqAnimationScene instance.
◆ saveGeometry()
bool pqAnimationManager::saveGeometry ( const QString &  filename,
pqView view
◆ animationPlaying()
bool pqAnimationManager::animationPlaying ( ) const
◆ activeSceneChanged
void pqAnimationManager::activeSceneChanged ( pqAnimationScene scene)
signal
◆ activeServerChanged
void pqAnimationManager::activeServerChanged ( pqServer scene)
signal
◆ saveProgress
void pqAnimationManager::saveProgress ( const QString &  ,
int
signal
◆ beginNonUndoableChanges
void pqAnimationManager::beginNonUndoableChanges ( )
signal
◆ endNonUndoableChanges
void pqAnimationManager::endNonUndoableChanges ( )
signal
◆ writeAnimation
void pqAnimationManager::writeAnimation ( const QString &  filename,
int  magnification,
double  frameRate
signal
◆ beginPlay
void pqAnimationManager::beginPlay ( vtkObject caller,
unsigned  long,
void *  ,
void *  reversed
signal
◆ endPlay
void pqAnimationManager::endPlay ( vtkObject caller,
unsigned  long,
void *  ,
void *  reversed
signal
◆ onActiveServerChanged
void pqAnimationManager::onActiveServerChanged ( pqServer )
slot
◆ onProxyAdded
void pqAnimationManager::onProxyAdded ( pqProxy )
protectedslot
◆ onProxyRemoved
void pqAnimationManager::onProxyRemoved ( pqProxy )
protectedslot
◆ onTick
void pqAnimationManager::onTick ( int  )
protectedslot
◆ onBeginPlay
void pqAnimationManager::onBeginPlay ( vtkObject caller,
unsigned  long,
void *  ,
void *  reversed
protectedslot
◆ onEndPlay
void pqAnimationManager::onEndPlay ( vtkObject caller,
unsigned  long,
void *  ,
void *  reversed
protectedslot
