Public Slots | Signals | Public Member Functions | Static Public Member Functions | Protected Slots | Protected Attributes | List of all members
pqApplicationCore Class Reference
This class is the crux of the ParaView application. More...
#include <pqApplicationCore.h>
Inheritance diagram for pqApplicationCore:
Collaboration diagram for pqApplicationCore:
Public Slots
void prepareForQuit ()
 Applications calls this to ensure that any cleanup is performed correctly. More...
void quit ()
 Calls QCoreApplication::quit(). More...
void updateAvailableReadersAndWriters ()
 Update the available readers and writers using the factories. More...
void render ()
 Renders all windows. More...
void loadConfiguration (const QString &filename)
 Load configuration xml. More...
void loadConfigurationXML (const char *xmldata)
Signals
void aboutToWriteState (QString filename)
 Fired before a state file, either python or XML, is written. More...
void aboutToReadState (QString filename)
 Fired before a state file, either python or XML, is read. More...
void aboutToLoadState (vtkPVXMLElement *root)
 Fired before a state xml is being loaded. More...
void stateLoaded (vtkPVXMLElement *root, vtkSMProxyLocator *locator)
 Fired when a state file is loaded successfully. More...
void stateSaved (vtkPVXMLElement *root)
 Fired to save state xml. More...
void undoStackChanged (pqUndoStack *)
 Fired when the undo stack is set. More...
void loadXML (vtkPVXMLElement *)
 Fired on loadConfiguration(). More...
void forceFilterMenuRefresh ()
 Fired when the filter menu state needs to be manually updated. More...
void updateMasterEnableState (bool)
 Fired when master changed. More...
void clientEnvironmentDone ()
 Fired when the ParaView Client infrastructure has completed setting up the environment. More...
 pqApplicationCore (int &argc, char **argv, vtkCLIOptions *options=nullptr, bool addStandardArgs=true, QObject *parent=nullptr)
 Initializes the ParaView application engine. More...
pqObjectBuildergetObjectBuilder () const
 Get the Object Builder. More...
void setUndoStack (pqUndoStack *stack)
 Set/Get the application's central undo stack. More...
pqUndoStackgetUndoStack () const
void registerManager (const QString &function, QObject *manager)
 Custom Applications may need use various "managers" All such manager can be registered with the pqApplicationCore so that that can be used by other components of the application. More...
QObject * manager (const QString &function)
 Returns a manager for a particular function, if any. More...
void unRegisterManager (const QString &function)
 Unregisters a manager for a particular function, if any. More...
QHelpEngine * helpEngine ()
 provides access to the help engine. More...
void registerDocumentation (const QString &filename)
 QHelpEngine doesn't like filenames in resource space. More...
pqServerManagerObservergetServerManagerObserver ()
 ServerManagerObserver observer the vtkSMProxyManager for changes to the server manager and fires signals on certain actions such as registeration/unregistration of proxies etc. More...
pqServerManagerModelgetServerManagerModel () const
 ServerManagerModel is the representation of the ServerManager using pqServerManagerModelItem subclasses. More...
pqInterfaceTrackerinterfaceTracker () const
 Locates the interface tracker for the application. More...
pqLinksModelgetLinksModel () const
 pqLinksModel is the model used to keep track of proxy/property links maintained by vtkSMProxyManager. More...
pqMainWindowEventManagergetMainWindowEventManager () const
 pqMainWindowManager manages signals called for main window events. More...
pqPluginManagergetPluginManager () const
 pqPluginManager manages all functionality associated with loading plugins. More...
pqProgressManagergetProgressManager () const
 ProgressManager is the manager that streamlines progress. More...
virtual pqTestUtility * testUtility ()
 Provides access to the test utility. More...
pqRecentlyUsedResourcesListrecentlyUsedResources ()
 Returns the set of recently-used resources i.e. More...
pqServerConfigurationCollectionserverConfigurations ()
 Returns the collection of server configurations known. More...
pqSettingssettings ()
 Get the application settings. More...
void clearSettings ()
 Clears the settings. More...
vtkPVXMLElementsaveState ()
 Save the ServerManager state to a XML element. More...
bool saveState (const QString &filename, vtkTypeUInt32 location=0x10)
 Save the ServerManager state to a file. More...
void loadState (vtkPVXMLElement *root, pqServer *server, vtkSMStateLoader *loader=nullptr)
 Loads the ServerManager state. More...
void loadState (const char *filename, pqServer *server, vtkSMStateLoader *loader=nullptr)
 Load state xml from a file. More...
void loadStateFromString (const char *xmlcontents, pqServer *server, vtkSMStateLoader *loader=nullptr)
 Loads state from an in-memory buffer. More...
void clearViewsForLoadingState (pqServer *server)
void loadStateIncremental (vtkPVXMLElement *root, pqServer *server, vtkSMStateLoader *loader=nullptr)
 Same as loadState() except that it doesn't clear the current visualization state. More...
void loadStateIncremental (const QString &filename, pqServer *server, vtkSMStateLoader *loader=nullptr)
void setLoadingState (bool value)
 Set the loading state flag. More...
bool isLoadingState ()
 Check to see if its in the process of loading a state Reliance on this flag is chimerical since we cannot set this ivar when state file is being loaded from python shell. More...
pqServergetActiveServer () const
 returns the active server is any. More...
QString getTranslationsPathFromInterfaceLanguage (QString prefix, QString locale)
 returns a path to a directory containing a translation binary file located in a path specified by the PV_TRANSLATIONS_DIR environment variable or in the resources directory. More...
QTranslator * getQtTranslations (QString prefix, QString locale)
 returns a QTranslator with a loaded qm file. More...
QString getInterfaceLanguage ()
 returns interface language in use in a locale code form. More...
 ~pqApplicationCore () override
 Destructor. More...
void _paraview_client_environment_complete ()
 INTERNAL. More...
static pqApplicationCoreinstance ()
Protected Slots
void onStateLoaded (vtkPVXMLElement *root, vtkSMProxyLocator *locator)
void onStateSaved (vtkPVXMLElement *root)
void onHelpEngineWarning (const QString &)
bool LoadingState
pqLinksModelLinksModel
pqObjectBuilderObjectBuilder
pqInterfaceTrackerInterfaceTracker
pqMainWindowEventManagerMainWindowEventManager
pqPluginManagerPluginManager
pqProgressManagerProgressManager
pqServerManagerModelServerManagerModel
pqServerManagerObserverServerManagerObserver
pqUndoStackUndoStack
pqRecentlyUsedResourcesListRecentlyUsedResourcesList
pqServerConfigurationCollectionServerConfigurations
pqSettingsSettings
QHelpEngine * HelpEngine
QPointer< pqTestUtility > TestUtility
It creates and manages various managers which are necessary for the ParaView-based client to work with the ServerManager. For clients based of the pqCore library, simply instantiate this pqApplicationCore after QApplication initialization and then create your main window etc. like a standard Qt application. You can then use the facilities provided by pqCore such as the pqObjectBuilder, pqUndoStack etc. in your application. After that point.
Definition at line 60 of file pqApplicationCore.h.
◆ pqApplicationCore()
pqApplicationCore::pqApplicationCore ( int argc,
char **  argv,
vtkCLIOptions options = nullptr,
bool  addStandardArgs = true,
QObject *  parent = nullptr
vtkCLIOptions may be provide if the application wants to customize command line argument processing. By default all standard ParaView-specific command line arguments will be supported. To avoid that, simply pass addStandardArgs=false.
Note
This constructor may raise pqApplicationCoreExitCode exception if the initialization process was short circuited and the application should simply quit.
If options is nullptr, an vtkCLIOptions instance will be created and used. It is also setup to accept extra / unknown arguments without raising errors.
◆ ~pqApplicationCore()
pqApplicationCore::~pqApplicationCore ( )
override
Destructor.
◆ instance()
static pqApplicationCore* pqApplicationCore::instance ( )
◆ getObjectBuilder()
pqObjectBuilder* pqApplicationCore::getObjectBuilder ( ) const
inline
Object Buider must be used to create complex objects such as sources, filters, readers, views, displays etc.
Definition at line 91 of file pqApplicationCore.h.
◆ setUndoStack()
void pqApplicationCore::setUndoStack ( pqUndoStack stack)
By default no undo stack is provided. Applications must set on up as required.
◆ getUndoStack()
pqUndoStack* pqApplicationCore::getUndoStack ( ) const
inline
Definition at line 98 of file pqApplicationCore.h.
◆ registerManager()
void pqApplicationCore::registerManager ( const QString &  function,
QObject *  manager
Registering with pqApplicationCore gives easy access to these managers from the application code. Note that custom applications are not required to register managers. However certain optional components of the pqCore may expect some managers. Only one manager can be registered for a function.
◆ manager()
QObject* pqApplicationCore::manager ( const QString &  function)
◆ unRegisterManager()
void pqApplicationCore::unRegisterManager ( const QString &  function)
◆ helpEngine()
QHelpEngine* pqApplicationCore::helpEngine ( )
The engine is created the first time this method is called.
◆ registerDocumentation()
void pqApplicationCore::registerDocumentation ( const QString &  filename)
This method creates a temporary file for the resource and registers that with the QHelpEngine.
◆ getServerManagerObserver()
pqServerManagerObserver* pqApplicationCore::getServerManagerObserver ( )
inline
Returns the ServerManagerObserver used by the application.
Definition at line 142 of file pqApplicationCore.h.
◆ getServerManagerModel()
pqServerManagerModel* pqApplicationCore::getServerManagerModel ( ) const
inline
It makes it possible to explore the ServerManager with ease by separating proxies based on their functionality/type.
Definition at line 150 of file pqApplicationCore.h.
◆ interfaceTracker()
pqInterfaceTracker* pqApplicationCore::interfaceTracker ( ) const
inline
pqInterfaceTracker is used to locate all interface implementations typically loaded from plugins.
Definition at line 157 of file pqApplicationCore.h.
◆ getLinksModel()
pqLinksModel* pqApplicationCore::getLinksModel ( ) const
inline
TODO: It may be worthwhile to investigate if we even need a global pqLinksModel. All the information is already available in vtkSMProxyManager.
Definition at line 166 of file pqApplicationCore.h.
◆ getMainWindowEventManager()
pqMainWindowEventManager* pqApplicationCore::getMainWindowEventManager ( ) const
inline
Definition at line 171 of file pqApplicationCore.h.
◆ getPluginManager()
pqPluginManager* pqApplicationCore::getPluginManager ( ) const
inline
Definition at line 179 of file pqApplicationCore.h.
◆ getProgressManager()
pqProgressManager* pqApplicationCore::getProgressManager ( ) const
inline
Definition at line 184 of file pqApplicationCore.h.
◆ testUtility()
virtual pqTestUtility* pqApplicationCore::testUtility ( )
Reimplemented in pqPVApplicationCore.
◆ recentlyUsedResources()
pqRecentlyUsedResourcesList& pqApplicationCore::recentlyUsedResources ( )
data files and state files.
◆ serverConfigurations()
pqServerConfigurationCollection& pqApplicationCore::serverConfigurations ( )
Server configurations have information about connecting to different servers.
◆ settings()
pqSettings* pqApplicationCore::settings ( )
◆ clearSettings()
void pqApplicationCore::clearSettings ( )
Since various UI components that only read settings at creation time may get out of sync, it's best to warn the user to restart the application.
Any changes made to pqSettings after calling this method will be lost and will not get restored. If that's not desired, see QSettings::clear.
◆ saveState() [1/2]
vtkPVXMLElement* pqApplicationCore::saveState ( )
◆ saveState() [2/2]
bool pqApplicationCore::saveState ( const QString &  filename,
vtkTypeUInt32  location = 0x10
Return true if the operation succeeded otherwise return false.
◆ loadState() [1/2]
void pqApplicationCore::loadState ( vtkPVXMLElement root,
pqServer server,
vtkSMStateLoader loader = nullptr
Emits the signal stateLoaded() on loading state successfully.
◆ loadState() [2/2]
void pqApplicationCore::loadState ( const char *  filename,
pqServer server,
The filename can be a Qt resource file, besides regular filesystem files (refer to QFile documentation for more information on Qt resource system).
◆ loadStateFromString()
void pqApplicationCore::loadStateFromString ( const char *  xmlcontents,
pqServer server,
◆ clearViewsForLoadingState()
void pqApplicationCore::clearViewsForLoadingState ( pqServer server)
◆ loadStateIncremental() [1/2]
void pqApplicationCore::loadStateIncremental ( vtkPVXMLElement root,
pqServer server,
◆ loadStateIncremental() [2/2]
void pqApplicationCore::loadStateIncremental ( const QString &  filename,
pqServer server,
◆ setLoadingState()
void pqApplicationCore::setLoadingState ( bool  value)
inline
Definition at line 262 of file pqApplicationCore.h.
◆ isLoadingState()
bool pqApplicationCore::isLoadingState ( )
inline
Definition at line 269 of file pqApplicationCore.h.
◆ getActiveServer()
pqServer* pqApplicationCore::getActiveServer ( ) const
◆ getTranslationsPathFromInterfaceLanguage()
QString pqApplicationCore::getTranslationsPathFromInterfaceLanguage ( QString  prefix,
QString  locale
The binary file returned is the first one to have a name matching the locale given in the user settings.
Parameters
prefixThe prefix the filename should contain.
localeThe locale the filename suffix should contain.
◆ getQtTranslations()
QTranslator* pqApplicationCore::getQtTranslations ( QString  prefix,
QString  locale
The qm file can come either from the Qt's translation directory or from the ParaView's shared directory.
Parameters
◆ getInterfaceLanguage()
QString pqApplicationCore::getInterfaceLanguage ( )
It is first read from PV_INTERFACE_LANGUAGE environment variable if defined, then recovered from user settings. If not set, return en.
◆ _paraview_client_environment_complete()
void pqApplicationCore::_paraview_client_environment_complete ( )
INTERNAL.
Do not use.
◆ prepareForQuit
void pqApplicationCore::prepareForQuit ( )
slot
◆ quit
void pqApplicationCore::quit ( )
slot
◆ loadConfiguration
void pqApplicationCore::loadConfiguration ( const QString &  filename)
slot
This results in firing of the loadXML() signal which different components that support configuration catch and process to update their behavior. This also update available readers and writers.
◆ loadConfigurationXML
void pqApplicationCore::loadConfigurationXML ( const char *  xmldata)
slot
◆ updateAvailableReadersAndWriters
void pqApplicationCore::updateAvailableReadersAndWriters ( )
slot
◆ render
void pqApplicationCore::render ( )
slot
◆ aboutToWriteState
void pqApplicationCore::aboutToWriteState ( QString  filename)
signal
Note that writing can still fail at this point.
◆ aboutToReadState
void pqApplicationCore::aboutToReadState ( QString  filename)
signal
Note that loading can still fail at this point.
◆ aboutToLoadState
void pqApplicationCore::aboutToLoadState ( vtkPVXMLElement root)
signal
One can add slots for this signal and modify the fired xml-element as part of pre-processing before attempting to load the state xml. Note that never attempt to connect to signal in a delayed fashion i.e using Qt::QueuedConnection etc. since the root will be destroyed.
◆ stateLoaded
void pqApplicationCore::stateLoaded ( vtkPVXMLElement root,
vtkSMProxyLocator locator
signal
GUI components that may have state saved in the XML state file must listen to this signal and handle process the XML to update their state.
◆ stateSaved
void pqApplicationCore::stateSaved ( vtkPVXMLElement root)
signal
Components that need to save XML state should listen to this signal and add their XML elements to the root. DO NOT MODIFY THE ROOT besides adding new children.
◆ undoStackChanged
void pqApplicationCore::undoStackChanged ( pqUndoStack )
signal
◆ loadXML
void pqApplicationCore::loadXML ( vtkPVXMLElement )
signal
◆ forceFilterMenuRefresh
void pqApplicationCore::forceFilterMenuRefresh ( )
signal
◆ updateMasterEnableState
void pqApplicationCore::updateMasterEnableState ( bool  )
signal
true if current user is master, false otherwise.
◆ clientEnvironmentDone
void pqApplicationCore::clientEnvironmentDone ( )
signal
◆ onStateLoaded
void pqApplicationCore::onStateLoaded ( vtkPVXMLElement root,
protectedslot
◆ onStateSaved
void pqApplicationCore::onStateSaved ( vtkPVXMLElement root)
protectedslot
◆ onHelpEngineWarning
void pqApplicationCore::onHelpEngineWarning ( const QString &  )
protectedslot
◆ LoadingState
bool pqApplicationCore::LoadingState
Definition at line 423 of file pqApplicationCore.h.
◆ LinksModel
pqLinksModel* pqApplicationCore::LinksModel
Definition at line 425 of file pqApplicationCore.h.
◆ ObjectBuilder
pqObjectBuilder* pqApplicationCore::ObjectBuilder
Definition at line 426 of file pqApplicationCore.h.
◆ InterfaceTracker
pqInterfaceTracker* pqApplicationCore::InterfaceTracker
Definition at line 427 of file pqApplicationCore.h.
◆ MainWindowEventManager
pqMainWindowEventManager* pqApplicationCore::MainWindowEventManager
Definition at line 428 of file pqApplicationCore.h.
◆ PluginManager
pqPluginManager* pqApplicationCore::PluginManager
Definition at line 429 of file pqApplicationCore.h.
◆ ProgressManager
pqProgressManager* pqApplicationCore::ProgressManager
Definition at line 430 of file pqApplicationCore.h.
◆ ServerManagerModel
pqServerManagerModel* pqApplicationCore::ServerManagerModel
Definition at line 431 of file pqApplicationCore.h.
◆ ServerManagerObserver
pqServerManagerObserver* pqApplicationCore::ServerManagerObserver
Definition at line 432 of file pqApplicationCore.h.
◆ UndoStack
pqUndoStack* pqApplicationCore::UndoStack
Definition at line 433 of file pqApplicationCore.h.
◆ RecentlyUsedResourcesList
pqRecentlyUsedResourcesList* pqApplicationCore::RecentlyUsedResourcesList
Definition at line 434 of file pqApplicationCore.h.
◆ ServerConfigurations
pqServerConfigurationCollection* pqApplicationCore::ServerConfigurations
Definition at line 435 of file pqApplicationCore.h.
◆ Settings
pqSettings* pqApplicationCore::Settings
Definition at line 436 of file pqApplicationCore.h.
◆ HelpEngine
QHelpEngine* pqApplicationCore::HelpEngine
Definition at line 437 of file pqApplicationCore.h.
◆ TestUtility
QPointer<pqTestUtility> pqApplicationCore::TestUtility
Definition at line 438 of file pqApplicationCore.h.
