| pqParallelCoordinatesChartView (const QString &group, const QString &name, vtkSMContextViewProxy *viewModule, pqServer *server, QObject *parent=nullptr) |
| ~pqParallelCoordinatesChartView () override |
| ~pqContextView () override |
virtual vtkContextView * | getVTKContextView () const |
| Returns the internal vtkContextView which provides the implementation for the chart rendering. More...
virtual vtkSMContextViewProxy * | getContextViewProxy () const |
| Returns the context view proxy associated with this object. More...
virtual bool | supportsSelection () const |
| Returns true if selection can be done. More...
bool | supportsCapture () const override |
| Returns if this view module can support image capture. More...
virtual void | setSelectionAction (int selAction) |
| set/get the selection action in the context view, defined by vtkChart enumeration from SELECT to SELECT_POLYGON. More...
virtual int | selectionAction () |
void | resetDisplay (bool closest=false) override |
| Resets the zoom level to 100%. More...
| ~pqView () override |
vtkSMViewProxy * | getViewProxy () const |
| Returns the internal render Module proxy associated with this object. More...
virtual vtkView * | getClientSideView () const |
| Return the client-side vtkView encapsulated by this view (if any), or return nullptr. More...
QWidget * | widget () |
| Return a widget associated with this view. More...
virtual bool | supportsUndo () const |
| Returns if this view module can support undo/redo. More...
QString | getViewType () const |
| Returns the type of this view module. More...
virtual bool | canUndo () const |
| Returns true if undo can be done. More...
virtual bool | canRedo () const |
| Returns true if redo can be done. More...
virtual QSize | getSize () |
| Returns the current size of the rendering context. More...
bool | hasRepresentation (pqRepresentation *repr) const |
| This method checks if the representation is shown in this view. More...
int | getNumberOfRepresentations () const |
| Returns the number representations in the view. More...
int | getNumberOfVisibleRepresentations () const |
int | getNumberOfVisibleDataRepresentations () const |
pqRepresentation * | getRepresentation (int index) const |
| Returns the representation for the specified index where (index < getNumberOfRepresentations()). More...
QList< pqRepresentation * > | getRepresentations () const |
| Returns a list of representations in this view. More...
bool | canDisplay (pqOutputPort *opPort) const |
| This method returns is any pqPipelineSource can be displayed in this view. More...
| pqProxy (const QString &group, const QString &name, vtkSMProxy *proxy, pqServer *server, QObject *parent=nullptr) |
| ~pqProxy () override |
pqServer * | getServer () const |
| Get the server on which this proxy exists. More...
void | rename (const QString &newname) |
| This is a convenience method. More...
const QString & | getSMName () |
| Get the name with which this proxy is registered on the server manager. More...
const QString & | getSMGroup () |
vtkSMProxy * | getProxy () const |
| Get the vtkSMProxy this object stands for. More...
ModifiedState | modifiedState () const |
| Gets whether or not the source has been modified. More...
void | setModifiedState (ModifiedState modified) |
| Sets whether or not the source has been modified. More...
vtkPVXMLElement * | getHints () const |
| Returns the hints for this proxy, if any. More...
QList< vtkSMProxy * > | getHelperProxies () const |
| Returns a list of all helper proxies. More...
QList< vtkSMProxy * > | getHelperProxies (const QString &key) const |
| Returns a list of all the helper proxies added with a given key. More...
QList< QString > | getHelperKeys () const |
| Returns the keys for helper proxies. More...
virtual void | addHelperProxy (const QString &key, vtkSMProxy *) |
| Concept of helper proxies: A pqProxy is created for every important vtkSMProxy registered. More...
void | removeHelperProxy (const QString &key, vtkSMProxy *) |
void | updateHelperProxies () const |
| Updates the internal datastructures using the proxies currently registered under the group that would be used for helper proxies. More...
vtkSMSessionProxyManager * | proxyManager () const |
| Returns the proxy manager by calling this->getProxy()->GetProxyManager();. More...
bool | userModifiedSMName () |
| Return whether or not the user has modified the GUI name of the source. More...
| pqServerManagerModelItem (QObject *parent=nullptr) |
| ~pqServerManagerModelItem () override |
enum | SelectionModifier { PV_SELECTION_DEFAULT = 0,
PV_SELECTION_ADDITION,
PV_SELECTION_SUBTRACTION,
PV_SELECTION_TOGGLE
enum | ModifiedState { UNINITIALIZED,
MODIFIED,
UNMODIFIED
| The modification state of this proxy. More...
virtual void | render () |
| Request a StillRender on idle. More...
virtual void | forceRender () |
| Forces an immediate render. More...
void | cancelPendingRenders () |
| Cancels any pending renders. More...
virtual void | undo () |
| Called to undo interaction. More...
virtual void | redo () |
| Called to redo interaction. More...
void | updateDataEvent () |
| Fired when the vtkSMViewProxy fires the vtkCommand::UpdateDataEvent The view proxy fires this event at the end of vtkSMViewProxy::Update() when the update executes, not just when the method is called. More...
void | representationAdded (pqRepresentation *) |
| Fired after a representation has been added to this view. More...
void | representationRemoved (pqRepresentation *) |
| Fired after a representation has been removed from this view. More...
void | beginRender () |
| Fired when the render module fires a vtkCommand::StartEvent signalling the beginning of rendering. More...
void | endRender () |
| Fired when the render module fires a vtkCommand::EndEvent signalling the end of rendering. More...
void | representationVisibilityChanged (pqRepresentation *repr, bool visible) |
| Fired when any representation visibility changes. More...
void | canUndoChanged (bool) |
| Fired when interaction undo stack status changes. More...
void | canRedoChanged (bool) |
void | selected (pqOutputPort *opport) |
| Fired when a selection is made in this view. More...
void | picked (pqOutputPort *opport) |
| Fired when a port is picked. More...
void | beginProgress () |
| Fired before doing any actions that may result in progress events that must be reported by the client. More...
void | endProgress () |
| Fired after performing any actions that may result in progress events. More...
void | progress (const QString &message, int percent_progress) |
| Fired to notify the current execution progress. More...
void | multipleSelected (QList< pqOutputPort *> opports) |
| Fired when UseMultipleRepresentationSelection is set to on and selection on multiple representations is made in this view. More...
void | nameChanged (pqServerManagerModelItem *) |
| Fired when the name of the proxy is changed. More...
void | modifiedStateChanged (pqServerManagerModelItem *) |
| Fired when the modified status changes for the proxy. More...
void | startInteraction () |
| Slots called when vtkCommand::StartInteractionEvent and vtkCommand::EndInteractionEvent are fired by vtkSMContextViewProxy. More...
void | endInteraction () |
void | onProxyRegistered (const QString &, const QString &, vtkSMProxy *) |
void | onProxyUnRegistered (const QString &, const QString &, vtkSMProxy *) |
| pqContextView (const QString &type, const QString &group, const QString &name, vtkSMViewProxy *view, pqServer *server, QObject *parent=nullptr) |
| Constructor: type :- view type. More...
QWidget * | createWidget () override |
| Creates a new instance of the QWidget subclass to be used to show this view. More...
virtual void | selectionChanged () |
| Listen for new selection events, and pass them back to ParaView. More...
virtual void | setSelection (vtkSelection *) |
| Set selection to the view. More...
| pqView (const QString &type, const QString &group, const QString &name, vtkSMViewProxy *view, pqServer *server, QObject *parent=nullptr) |
void | initialize () override |
| Use this method to initialize the pqObject state using the underlying vtkSMProxy. More...
void | setSMName (const QString &new_name) |
| Make this pqProxy take on a new identity. More...
virtual void | addInternalHelperProxy (const QString &key, vtkSMProxy *) const |
virtual void | removeInternalHelperProxy (const QString &key, vtkSMProxy *) const |
vtkEventQtSlotConnect * | getConnector () |
| All subclasses generally need some vtkEventQtSlotConnect instance to connect to VTK events. More...
command * | Command |
pqView subclass of ParallelCoordinatesChartView chart view.
Does not do anything specific besides passing the view type of pqView in the constructor.
Definition at line 17 of file pqParallelCoordinatesChartView.h.
