#include <pqPipelineFilter.h>
Signals | |
void | producerChanged (const QString &inputportname) |
fired whenever an input connection changes. More... | |
void | connectionAdded (pqPipelineSource *source, pqPipelineSource *consumer, int srcOutputPort) |
fired when a connection is created between two pqPipelineSources. More... | |
void | preConnectionAdded (pqPipelineSource *source, pqPipelineSource *consumer, int srcOutputPort) |
void | connectionRemoved (pqPipelineSource *source, pqPipelineSource *consumer, int srcOutputPort) |
fired when a connection is broken between two pqPipelineSources. More... | |
void | preConnectionRemoved (pqPipelineSource *source, pqPipelineSource *consumer, int srcOutputPort) |
void | representationAdded (pqPipelineSource *source, pqDataRepresentation *repr, int srcOutputPort) |
fired when a representation is added. More... | |
void | representationRemoved (pqPipelineSource *source, pqDataRepresentation *repr, int srcOutputPort) |
fired when a representation is removed. More... | |
void | visibilityChanged (pqPipelineSource *source, pqDataRepresentation *repr) |
Fired when the visbility of a representation for the source changes. More... | |
void | dataUpdated (pqPipelineSource *source) |
Fired right after the underlying algorithm updates (executes). More... | |
void | selectionChanged (pqOutputPort *port) |
Fired when the selection on a port has changed. More... | |
void | nameChanged (pqServerManagerModelItem *) |
Fired when the name of the proxy is changed. More... | |
void | modifiedStateChanged (pqServerManagerModelItem *) |
Fired when the modified status changes for the proxy. More... | |
pqPipelineFilter (QString name, vtkSMProxy *proxy, pqServer *server, QObject *parent=nullptr) | |
~pqPipelineFilter () override | |
int | getNumberOfInputPorts () const |
Returns the number of input ports available on this filter. More... | |
QString | getInputPortName (int index) const |
Returns the name of the input port at a given index. More... | |
int | getNumberOfInputs (const QString &portname) const |
Returns the number of input proxies connected to given named input port. More... | |
QList< pqOutputPort * > | getInputs (const QString &portname) const |
Returns the input proxies connected to the given named input port. More... | |
QList< pqOutputPort * > | getAllInputs () const |
Returns inputs connected to all input ports connections. More... | |
QMap< QString, QList< pqOutputPort * > > | getNamedInputs () const |
Returns a map of input port name to the list of output ports that are set as the input to that port. More... | |
pqOutputPort * | getInput (const QString &portname, int index) const |
Returns a pair (input, output port) at the given index on the given named input port. More... | |
int | getInputCount () const |
Get number of inputs. More... | |
QList< pqOutputPort * > | getInputs () const |
Get a list of all inputs. More... | |
pqPipelineSource * | getInput (int index) const |
Get input at given index. More... | |
pqOutputPort * | getAnyInput () const |
Get first available input, any port, any index. More... | |
int | replaceInput () const |
"Replace input" is a hint given to the GUI to turn off input visibility when the filter is created. More... | |
pqPipelineSource (const QString &name, vtkSMProxy *proxy, pqServer *server, QObject *parent=nullptr) | |
~pqPipelineSource () override | |
int | getNumberOfOutputPorts () const |
A source may have multiple output ports. More... | |
pqOutputPort * | getOutputPort (int outputport) const |
Returns the pqOutputPort for the given output port. More... | |
pqOutputPort * | getOutputPort (const QString &portName) const |
Returns the pqOutputPort given the name of the port. More... | |
QList< pqOutputPort * > | getOutputPorts () const |
Returns all the output ports. More... | |
int | getNumberOfConsumers (int outputport) const |
Returns the number of consumers connected to the given output port. More... | |
int | getNumberOfConsumers () const |
Get the number of consumers connected to output port 0. More... | |
pqPipelineSource * | getConsumer (int outputport, int index) const |
Get the consumer at a particulat index on a given output port. More... | |
pqPipelineSource * | getConsumer (int index) const |
Get consumer at a particular index on output port 0. More... | |
QList< pqPipelineSource * > | getAllConsumers () const |
Returns a list of consumers for all output ports. More... | |
QList< pqDataRepresentation * > | getRepresentations (int outputport, pqView *view) const |
Returns a list of representations for this source in the given view. More... | |
QList< pqDataRepresentation * > | getRepresentations (pqView *view) const |
pqDataRepresentation * | getRepresentation (int outputport, pqView *view) const |
Returns the first representation for this source in the given view. More... | |
pqDataRepresentation * | getRepresentation (pqView *view) const |
QList< pqView * > | getViews () const |
Returns a list of render modules in which this source has representations added (the representations may not be visible). More... | |
void | renderAllViews (bool force=false) |
This method updates all render modules to which all representations for this source belong, if force is true, it for an immediate render otherwise render on idle. More... | |
void | updatePipeline () |
Update the pipeline with the current time. More... | |
vtkSMSourceProxy * | getSourceProxy () |
Return the vtkSMSourceProxy instance corresponding to this pqPipelineSource. More... | |
pqProxy (const QString &group, const QString &name, vtkSMProxy *proxy, pqServer *server, QObject *parent=nullptr) | |
~pqProxy () override | |
pqServer * | getServer () const |
Get the server on which this proxy exists. More... | |
void | rename (const QString &newname) |
This is a convenience method. More... | |
const QString & | getSMName () |
Get the name with which this proxy is registered on the server manager. More... | |
const QString & | getSMGroup () |
vtkSMProxy * | getProxy () const |
Get the vtkSMProxy this object stands for. More... | |
ModifiedState | modifiedState () const |
Gets whether or not the source has been modified. More... | |
void | setModifiedState (ModifiedState modified) |
Sets whether or not the source has been modified. More... | |
vtkPVXMLElement * | getHints () const |
Returns the hints for this proxy, if any. More... | |
QList< vtkSMProxy * > | getHelperProxies () const |
Returns a list of all helper proxies. More... | |
QList< vtkSMProxy * > | getHelperProxies (const QString &key) const |
Returns a list of all the helper proxies added with a given key. More... | |
QList< QString > | getHelperKeys () const |
Returns the keys for helper proxies. More... | |
virtual void | addHelperProxy (const QString &key, vtkSMProxy *) |
Concept of helper proxies: A pqProxy is created for every important vtkSMProxy registered. More... | |
void | removeHelperProxy (const QString &key, vtkSMProxy *) |
void | updateHelperProxies () const |
Updates the internal datastructures using the proxies currently registered under the group that would be used for helper proxies. More... | |
vtkSMSessionProxyManager * | proxyManager () const |
Returns the proxy manager by calling this->getProxy()->GetProxyManager();. More... | |
bool | userModifiedSMName () |
Return whether or not the user has modified the GUI name of the source. More... | |
pqServerManagerModelItem (QObject *parent=nullptr) | |
~pqServerManagerModelItem () override | |
static QList< const char * > | getInputPorts (vtkSMProxy *) |
Returns the inputs ports on any proxy. More... | |
static QList< const char * > | getRequiredInputPorts (vtkSMProxy *) |
Returns the required inputs ports on any proxy. More... | |
static pqProxy * | findProxyWithHelper (vtkSMProxy *aproxy, QString &key) |
Returns a pqProxy instance, of any, whose helper proxy is the aproxy. More... | |
static std::string | rstToHtml (const char *rstStr) |
convert proxy documentation from RST to HTML (so that it can be used in Qt) More... | |
static QString | rstToHtml (const QString &rstStr) |
Protected Slots | |
void | inputChanged (vtkObject *, unsigned long, void *client_data) |
process some change in the input property for the proxy. More... | |
void | onRepresentationVisibilityChanged () |
Called when the visibility of any representation for this source changes. More... | |
void | onProxyRegistered (const QString &, const QString &, vtkSMProxy *) |
void | onProxyUnRegistered (const QString &, const QString &, vtkSMProxy *) |
void | initialize () override |
Use this method to initialize the pqObject state using the underlying vtkSMProxy. More... | |
void | inputChanged (const QString &portname) |
Called when a input property changes. More... | |
void | removeConsumer (int outputport, pqPipelineSource *) |
called by pqPipelineFilter when the connections change. More... | |
void | addConsumer (int outputport, pqPipelineSource *) |
void | setSMName (const QString &new_name) |
Make this pqProxy take on a new identity. More... | |
virtual void | addInternalHelperProxy (const QString &key, vtkSMProxy *) const |
virtual void | removeInternalHelperProxy (const QString &key, vtkSMProxy *) const |
vtkEventQtSlotConnect * | getConnector () |
All subclasses generally need some vtkEventQtSlotConnect instance to connect to VTK events. More... | |
enum | ModifiedState { UNINITIALIZED, MODIFIED, UNMODIFIED } |
The modification state of this proxy. More... | |
Definition at line 19 of file pqPipelineFilter.h.
pqPipelineFilter::pqPipelineFilter | ( | QString | name, |
vtkSMProxy * | proxy, | ||
pqServer * | server, | ||
QObject * | parent = nullptr |
This is generally same as getInputPorts() except if the property has a "hint" saying it's optional.
int pqPipelineFilter::getNumberOfInputPorts | ( | ) | const |
QString pqPipelineFilter::getInputPortName | ( | int | index | ) | const |
QList<pqOutputPort*> pqPipelineFilter::getInputs | ( | const QString & | portname | ) | const |
QList<pqOutputPort*> pqPipelineFilter::getAllInputs | ( | ) | const |
QMap<QString, QList<pqOutputPort*> > pqPipelineFilter::getNamedInputs | ( | ) | const |
pqOutputPort* pqPipelineFilter::getInput | ( | const QString & | portname, |
int | index | ||
) | const |
Definition at line 80 of file pqPipelineFilter.h.
Definition at line 85 of file pqPipelineFilter.h.
pqPipelineSource* pqPipelineFilter::getInput | ( | int | index | ) | const |
pqOutputPort* pqPipelineFilter::getAnyInput | ( | ) | const |
Return nullptr if none are available.
int pqPipelineFilter::replaceInput | ( | ) | const |
Returns if this proxy replaces input on creation. This checks the "Hints" for the proxy, if any. If a <Visibility>
element is present with replace_input="0", then this method returns false, otherwise true.
signal |
protectedslot |
overrideprotectedvirtual |
This needs to be done only once, after the object has been created.
Reimplemented from pqProxy.
portname
is the name of the input port represented by the property.
