pqScalarBarRepresentation is created for "ScalarBarWidgetRepresentation" proxies. More...
#include <pqScalarBarRepresentation.h>
pqScalarBarRepresentation (const QString &group, const QString &name, vtkSMProxy *scalarbar, pqServer *server, QObject *parent=nullptr) | |
~pqScalarBarRepresentation () override | |
pqRepresentation (const QString &group, const QString &name, vtkSMProxy *repr, pqServer *server, QObject *parent=nullptr) | |
~pqRepresentation () override | |
virtual bool | isVisible () const |
Returns if the status of the visbility property of this display. More... | |
virtual void | setVisible (bool visible) |
Set the visibility. More... | |
pqView * | getView () const |
Returns the view to which this representation has been added, if any. More... | |
vtkSMViewProxy * | getViewProxy () const |
Returns the view proxy to which this representation has been added, if any. More... | |
pqProxy (const QString &group, const QString &name, vtkSMProxy *proxy, pqServer *server, QObject *parent=nullptr) | |
~pqProxy () override | |
pqServer * | getServer () const |
Get the server on which this proxy exists. More... | |
void | rename (const QString &newname) |
This is a convenience method. More... | |
const QString & | getSMName () |
Get the name with which this proxy is registered on the server manager. More... | |
const QString & | getSMGroup () |
vtkSMProxy * | getProxy () const |
Get the vtkSMProxy this object stands for. More... | |
ModifiedState | modifiedState () const |
Gets whether or not the source has been modified. More... | |
void | setModifiedState (ModifiedState modified) |
Sets whether or not the source has been modified. More... | |
vtkPVXMLElement * | getHints () const |
Returns the hints for this proxy, if any. More... | |
QList< vtkSMProxy * > | getHelperProxies () const |
Returns a list of all helper proxies. More... | |
QList< vtkSMProxy * > | getHelperProxies (const QString &key) const |
Returns a list of all the helper proxies added with a given key. More... | |
QList< QString > | getHelperKeys () const |
Returns the keys for helper proxies. More... | |
virtual void | addHelperProxy (const QString &key, vtkSMProxy *) |
Concept of helper proxies: A pqProxy is created for every important vtkSMProxy registered. More... | |
void | removeHelperProxy (const QString &key, vtkSMProxy *) |
void | updateHelperProxies () const |
Updates the internal datastructures using the proxies currently registered under the group that would be used for helper proxies. More... | |
vtkSMSessionProxyManager * | proxyManager () const |
Returns the proxy manager by calling this->getProxy()->GetProxyManager();. More... | |
bool | userModifiedSMName () |
Return whether or not the user has modified the GUI name of the source. More... | |
pqServerManagerModelItem (QObject *parent=nullptr) | |
~pqServerManagerModelItem () override | |
Protected Slots | |
void | startInteraction () |
void | endInteraction () |
virtual void | onVisibilityChanged () |
called when the display visibility property changes. More... | |
void | onProxyRegistered (const QString &, const QString &, vtkSMProxy *) |
void | onProxyUnRegistered (const QString &, const QString &, vtkSMProxy *) |
enum | ModifiedState { UNINITIALIZED, MODIFIED, UNMODIFIED } |
The modification state of this proxy. More... | |
void | renderView (bool force) |
Renders the view to which this representation has been added if any. More... | |
void | renderViewEventually () |
Simply calls renderView(false);. More... | |
void | visibilityChanged (bool visible) |
Fired when the visibility property of the underlying display changes. More... | |
void | updated () |
Fired whenever Update() is called on the underlying display proxy. More... | |
void | nameChanged (pqServerManagerModelItem *) |
Fired when the name of the proxy is changed. More... | |
void | modifiedStateChanged (pqServerManagerModelItem *) |
Fired when the modified status changes for the proxy. More... | |
static pqProxy * | findProxyWithHelper (vtkSMProxy *aproxy, QString &key) |
Returns a pqProxy instance, of any, whose helper proxy is the aproxy. More... | |
static std::string | rstToHtml (const char *rstStr) |
convert proxy documentation from RST to HTML (so that it can be used in Qt) More... | |
static QString | rstToHtml (const QString &rstStr) |
virtual void | setView (pqView *) |
Called by pqView when this representation gets added to / removed from the view. More... | |
void | setSMName (const QString &new_name) |
Make this pqProxy take on a new identity. More... | |
virtual void | initialize () |
virtual void | addInternalHelperProxy (const QString &key, vtkSMProxy *) const |
virtual void | removeInternalHelperProxy (const QString &key, vtkSMProxy *) const |
vtkEventQtSlotConnect * | getConnector () |
All subclasses generally need some vtkEventQtSlotConnect instance to connect to VTK events. More... | |
The only reason why pqScalarBarRepresentation is used is to keep create undo elements to aid with undo/redo for scalar bar interaction i.e. if user drags the scalar-bar widget, we capture the entire operation in a single undo-able action.
Definition at line 20 of file pqScalarBarRepresentation.h.
pqScalarBarRepresentation::pqScalarBarRepresentation | ( | const QString & | group, |
const QString & | name, | ||
vtkSMProxy * | scalarbar, | ||
pqServer * | server, | ||
QObject * | parent = nullptr |
protectedslot |
protectedslot |
