vtkSMSessionServer is a session used on data and/or render servers. More...
#include <vtkPVSessionServer.h>
vtkMultiProcessController * | GetController (ServerFlags processType) override |
Returns the active controller used to communicate with the process. More... | |
virtual bool | Connect (const char *url) |
Connects a remote server. More... | |
bool | Connect () |
Overload that constructs the url using the command line parameters specified and then calls Connect(url). More... | |
bool | GetIsAlive () override |
Returns true is this session is active/alive/valid. More... | |
void | OnClientServerMessageRMI (void *message, int message_length) |
void | OnCloseSessionRMI () |
void | NotifyAllClients (const vtkSMMessage *) override |
Sends the message to all clients. More... | |
void | NotifyOtherClients (const vtkSMMessage *) override |
Sends the message to all but the active client-session. More... | |
virtual void | MultipleConnectionOn () |
Enable or Disable multi-connection support. More... | |
virtual void | MultipleConnectionOff () |
virtual void | SetMultipleConnection (bool) |
virtual bool | GetMultipleConnection () |
virtual void | DisableFurtherConnectionsOn () |
Enable or Disable further connections in multiple connection mode. More... | |
virtual void | DisableFurtherConnectionsOff () |
virtual bool | GetDisableFurtherConnections () |
void | SetDisableFurtherConnections (bool disable) |
void | SetConnectID (int newConnectID) |
Set/Get the server connect-id. More... | |
int | GetConnectID () |
ServerFlags | GetProcessRoles () override |
Returns a ServerFlags indicate the nature of the current processes. More... | |
vtkPVServerInformation * | GetServerInformation () override |
vtkPVServerInformation is an information-object that provides information about the server processes. More... | |
vtkMPIMToNSocketConnection * | GetMPIMToNSocketConnection () override |
This is socket connection, if any to communicate between the data-server and render-server nodes. More... | |
virtual void | PushState (vtkSMMessage *msg) |
Push the state message. More... | |
virtual void | PullState (vtkSMMessage *msg) |
Pull the state message. More... | |
virtual void | ExecuteStream (vtkTypeUInt32 location, const vtkClientServerStream &stream, bool ignore_errors=false) |
Execute a command on the given processes. More... | |
virtual const vtkClientServerStream & | GetLastResult (vtkTypeUInt32 location) |
Returns the response of the ExecuteStream() call from the location. More... | |
virtual bool | GatherInformation (vtkTypeUInt32 location, vtkPVInformation *information, vtkTypeUInt32 globalid) |
Gather information about an object referred by the globalid . More... | |
vtkSIProxyDefinitionManager * | GetProxyDefinitionManager () |
Get the ProxyDefinitionManager. More... | |
vtkSIObject * | GetSIObject (vtkTypeUInt32 globalid) |
Returns a vtkSIObject or subclass given its global id, if any. More... | |
virtual void | UnRegisterSIObject (vtkSMMessage *msg) |
Unregister server side object. More... | |
virtual void | RegisterSIObject (vtkSMMessage *msg) |
Register server side object. More... | |
vtkObject * | GetRemoteObject (vtkTypeUInt32 globalid) |
Return a vtkSMRemoteObject given its global id if any otherwise return nullptr;. More... | |
virtual void | GetAllRemoteObjects (vtkCollection *collection) |
Allow the user to fill its vtkCollection with all RemoteObject This could be useful when you want to hold a reference to them to prevent any deletion across several method call. More... | |
virtual vtkTypeUInt32 | GetNextGlobalUniqueIdentifier () |
Provides the next available identifier. More... | |
virtual vtkTypeUInt32 | GetNextChunkGlobalUniqueIdentifier (vtkTypeUInt32 chunkSize) |
Return the first Id of the requested chunk. More... | |
virtual bool | IsProcessingRemoteNotification () |
This property is used to discard ignore_synchronization proxy property when we load protobuf states. More... | |
virtual void | UseSessionCoreOf (vtkPVSessionBase *other) |
Update internal session core in order to use the one used in another session. More... | |
virtual vtkPVSessionCore * | GetSessionCore () |
Provides access to the session core. More... | |
bool | HasProcessRole (vtkTypeUInt32 flag) |
Convenience method that returns true if the current session is serving the indicated role on this process. More... | |
virtual bool | IsMultiClients () |
Allow anyone to know easily if the current session is involved in collaboration or not. More... | |
bool | GetPendingProgress () |
Returns true if the session is within a PrepareProgress() and CleanupPendingProgress() block. More... | |
virtual vtkPVProgressHandler * | GetProgressHandler () |
Provides access to the progress handler. More... | |
void | PrepareProgress () |
Should be called to begin/end receiving progresses on this session. More... | |
void | CleanupPendingProgress () |
virtual void | Modified () |
static vtkPVSessionServer * | New () |
static vtkPVSessionServer * | SafeDownCast (vtkObject *o) |
static vtkPVSessionBase * | SafeDownCast (vtkObject *o) |
static vtkPVSession * | SafeDownCast (vtkObject *o) |
static vtkSession * | SafeDownCast (vtkObject *o) |
static vtkObject * | New () |
vtkPVSessionServer () | |
~vtkPVSessionServer () override | |
void | GatherInformationInternal (vtkTypeUInt32 location, const char *classname, vtkTypeUInt32 globalid, vtkMultiProcessStream &) |
Called when client triggers GatherInformation(). More... | |
void | SendLastResultToClient () |
Sends the last result to client. More... | |
vtkPVSessionBase () | |
vtkPVSessionBase (vtkPVSessionCore *coreToUse) | |
~vtkPVSessionBase () override | |
void | RegisterRemoteObject (vtkTypeUInt32 globalid, vtkTypeUInt32 location, vtkObject *obj) |
Register a remote object. More... | |
void | UnRegisterRemoteObject (vtkTypeUInt32 globalid, vtkTypeUInt32 location) |
Unregister a remote object. More... | |
vtkPVSessionCore * | GetSessionCore () const |
Method used to migrate from one Session type to another by keeping the same vtkPVSessionCore. More... | |
void | SetSessionCore (vtkPVSessionCore *) |
void | PrepareProgressInternal () override |
void | CleanupPendingProgressInternal () override |
virtual bool | StartProcessingRemoteNotification () |
Methods used to monitor if we are currently processing a server notification Only vtkSMSessionClient use the flag to disable ignore_synchronization properties from being updated. More... | |
virtual void | StopProcessingRemoteNotification (bool previousValue) |
vtkPVSession () | |
~vtkPVSession () override | |
virtual bool | OnWrongTagEvent (vtkObject *caller, unsigned long eventid, void *calldata) |
Callback when any vtkMultiProcessController subclass fires a WrongTagEvent. More... | |
vtkSession () | |
~vtkSession () override | |
virtual void | Activate () |
Subclasses must call this to mark the session active. More... | |
virtual void | DeActivate () |
Subclasses must call this to mark the session inactive. More... | |
vtkObject () | |
virtual | ~vtkObject () |
vtkObjectBase () | |
virtual | ~vtkObjectBase () |
Protected Attributes | |
vtkMPIMToNSocketConnection * | MPIMToNSocketConnection |
bool | MultipleConnection |
bool | DisableFurtherConnections |
vtkInternals * | Internal |
vtkPVSessionCore * | SessionCore |
bool | ProcessingRemoteNotification |
vtkPVProgressHandler * | ProgressHandler |
bool | Debug |
vtkTimeStamp | MTime |
Friends | |
class | vtkInternals |
enum | { EXCEPTION_EVENT_TAG = 31416 } |
It's designed for a process that works with a separate client process that acts as the visualization driver.
Definition at line 22 of file vtkPVSessionServer.h.
Definition at line 26 of file vtkPVSessionServer.h.
anonymous enum |
Client-Server Communication tags.
Definition at line 65 of file vtkPVSessionServer.h.
Reimplemented from vtkPVSessionBase.
Value must be DATA_SERVER_ROOT or RENDER_SERVER_ROOT or CLIENT. But only the CLIENT do return something different than nullptr;
Reimplemented from vtkPVSession.
URL can be of the following format: cs://<pvserver-host>:<pvserver-port> cdsrs://<pvdataserver-host>:<pvdataserver-port>/<pvrenderserver-host>:<pvrenderserver-port> In both cases the port is optional. When not provided default pvserver/pvdataserver port // is 11111, while default pvrenderserver port is 22221. For reverse connect i.e. the client waits for the server to connect back, simply add "rc" to the protocol e.g. csrc://<pvserver-host>:<pvserver-port> cdsrsrc://<pvdataserver-host>:<pvdataserver-port>/<pvrenderserver-host>:<pvrenderserver-port> In this case, the hostname is irrelevant and is ignored.
bool vtkPVSessionServer::Connect | ( | ) |
Implements vtkSession.
The MultipleConnection is only used inside the DATA_SERVER to support several clients to connect to it. By default, collaboration is not allowed (this->MultipleConnection = false)
By default, further connections are enabled. (this->DisableFurtherConnections = false)
void vtkPVSessionServer::SetDisableFurtherConnections | ( | bool | disable | ) |
void vtkPVSessionServer::SetConnectID | ( | int | newConnectID | ) |
Default is 0.
int vtkPVSessionServer::GetConnectID | ( | ) |
Default is 0.
void vtkPVSessionServer::OnClientServerMessageRMI | ( | void * | message, |
int | message_length | ||
void vtkPVSessionServer::OnCloseSessionRMI | ( | ) |
Implements vtkPVSessionBase.
friend |
Definition at line 149 of file vtkPVSessionServer.h.
Definition at line 142 of file vtkPVSessionServer.h.
Definition at line 144 of file vtkPVSessionServer.h.
Definition at line 145 of file vtkPVSessionServer.h.
Definition at line 147 of file vtkPVSessionServer.h.
