vtkSMSessionClient is a remote-session that connects to a remote server. More...
#include <vtkSMSessionClient.h>
typedef vtkSMSession | Superclass |
enum | RenderingMode { RENDERING_NOT_AVAILABLE = 0x00, RENDERING_UNIFIED = 0x01, RENDERING_SPLIT = 0x02 } |
typedef vtkPVSessionBase | Superclass |
enum | EventIds { RegisterRemoteObjectEvent = 1234, UnRegisterRemoteObjectEvent = 4321, ProcessingRemoteEnd = 2143, ConnectionLost = 6789 } |
typedef vtkPVSession | Superclass |
enum | ServerFlags { NONE = 0, DATA_SERVER = 0x01, DATA_SERVER_ROOT = 0x02, RENDER_SERVER = 0x04, RENDER_SERVER_ROOT = 0x08, SERVERS = DATA_SERVER | RENDER_SERVER, CLIENT = 0x10, CLIENT_AND_SERVERS = DATA_SERVER | CLIENT | RENDER_SERVER } |
typedef vtkSession | Superclass |
const char * | GetURI () override |
Return the url used to connect the current session to a server. More... | |
bool | GetIsAlive () override |
Returns true is this session is active/alive/valid. More... | |
ServerFlags | GetProcessRoles () override |
Returns a ServerFlags indicate the nature of the current processes. More... | |
vtkMultiProcessController * | GetController (ServerFlags processType) override |
Returns the controller used to communicate with the process. More... | |
vtkPVServerInformation * | GetServerInformation () override |
vtkPVServerInformation is an information-object that provides information about the server processes. More... | |
void | Initialize () override |
Called to do any initializations after a successful session has been established. More... | |
void | CloseSession () |
Gracefully exits the session. More... | |
bool | GatherInformation (vtkTypeUInt32 location, vtkPVInformation *information, vtkTypeUInt32 globalid) override |
Gather information about an object referred by the globalid . More... | |
int | GetNumberOfProcesses (vtkTypeUInt32 servers) override |
Returns the number of processes on the given server/s. More... | |
bool | IsMPIInitialized (vtkTypeUInt32 servers) override |
Returns whether or not MPI is initialized on the specified server/s. More... | |
void | PreDisconnection () override |
virtual bool | IsNotBusy () |
Flag used to know if it is a good time to handle server notification. More... | |
virtual void | StartBusyWork () |
BusyWork should be declared inside method that will request several network call that we don't want to interrupt such as GatherInformation and Pull. More... | |
virtual void | EndBusyWork () |
vtkSMCollaborationManager * | GetCollaborationManager () override |
Return the instance of vtkSMCollaborationManager that will be lazy created at the first call. More... | |
int | GetConnectID () |
Return the connect id of this client. More... | |
vtkTypeUInt32 | GetNextGlobalUniqueIdentifier () override |
Provides the next available identifier. More... | |
vtkTypeUInt32 | GetNextChunkGlobalUniqueIdentifier (vtkTypeUInt32 chunkSize) override |
Return the first Id of the requested chunk. More... | |
void | OnServerNotificationMessageRMI (void *message, int message_length) |
virtual bool | Connect (const char *url, int timeout=60) |
Connects a remote server. More... | |
virtual bool | Connect (const char *url, int timeout, bool(*callback)(), vtkNetworkAccessManager::ConnectionResult &connectionResult) |
void | PushState (vtkSMMessage *msg) override |
Push the state. More... | |
void | PullState (vtkSMMessage *message) override |
void | ExecuteStream (vtkTypeUInt32 location, const vtkClientServerStream &stream, bool ignore_errors=false) override |
const vtkClientServerStream & | GetLastResult (vtkTypeUInt32 location) override |
virtual void | SetAbortConnect (bool) |
When Connect() is waiting for a server to connect back to the client (in reverse connect mode), then it periodically fires ProgressEvent. More... | |
void | PrepareProgressInternal () override |
Should be called to begin/end receiving progresses on this session. More... | |
void | CleanupPendingProgressInternal () override |
virtual vtkSMProxyLocator * | GetProxyLocator () |
virtual unsigned int | GetRenderClientMode () |
Convenient method to determine if the rendering is done in a pvrenderer or not. More... | |
void | NotifyAllClients (const vtkSMMessage *msg) override |
Sends the message to all clients. More... | |
void | NotifyOtherClients (const vtkSMMessage *) override |
Sends the message to all but the active client-session. More... | |
Returns the vtkSMSessionProxyManager associated with this session. More... | |
virtual vtkSMStateLocator * | GetStateLocator () |
Provide an access to the session state locator that can provide the last state of a given remote object that have been pushed. More... | |
vtkMPIMToNSocketConnection * | GetMPIMToNSocketConnection () override |
This is socket connection, if any to communicate between the data-server and render-server nodes. More... | |
vtkSIProxyDefinitionManager * | GetProxyDefinitionManager () |
Get the ProxyDefinitionManager. More... | |
vtkSIObject * | GetSIObject (vtkTypeUInt32 globalid) |
Returns a vtkSIObject or subclass given its global id, if any. More... | |
vtkObject * | GetRemoteObject (vtkTypeUInt32 globalid) |
Return a vtkSMRemoteObject given its global id if any otherwise return nullptr;. More... | |
virtual void | GetAllRemoteObjects (vtkCollection *collection) |
Allow the user to fill its vtkCollection with all RemoteObject This could be useful when you want to hold a reference to them to prevent any deletion across several method call. More... | |
virtual bool | IsProcessingRemoteNotification () |
This property is used to discard ignore_synchronization proxy property when we load protobuf states. More... | |
virtual void | UseSessionCoreOf (vtkPVSessionBase *other) |
Update internal session core in order to use the one used in another session. More... | |
virtual vtkPVSessionCore * | GetSessionCore () |
Provides access to the session core. More... | |
bool | HasProcessRole (vtkTypeUInt32 flag) |
Convenience method that returns true if the current session is serving the indicated role on this process. More... | |
virtual bool | IsMultiClients () |
Allow anyone to know easily if the current session is involved in collaboration or not. More... | |
bool | GetPendingProgress () |
Returns true if the session is within a PrepareProgress() and CleanupPendingProgress() block. More... | |
virtual vtkPVProgressHandler * | GetProgressHandler () |
Provides access to the progress handler. More... | |
void | PrepareProgress () |
void | CleanupPendingProgress () |
virtual void | Modified () |
static vtkSMSessionClient * | New () |
static vtkSMSessionClient * | SafeDownCast (vtkObject *o) |
static vtkSMSession * | New () |
static vtkSMSession * | New (vtkPVSessionBase *otherSession) |
static vtkSMSession * | New (vtkPVSessionCore *otherSessionCore) |
static vtkSMSession * | SafeDownCast (vtkObject *o) |
static vtkIdType | ConnectToCatalyst () |
These are static helper methods that help create Catalyst ParaView sessions. More... | |
static vtkIdType | ConnectToSelf () |
These are static helper methods that help create standard ParaView sessions. More... | |
static vtkIdType | ConnectToRemote (const char *hostname, int port, int timeout=60) |
static vtkIdType | ConnectToRemote (const char *hostname, int port, int timeout, bool(*callback)(), vtkNetworkAccessManager::ConnectionResult &result) |
static vtkIdType | ReverseConnectToRemote (int port) |
Same as ConnectToRemote() except that it waits for a reverse connection for timeout seconds. More... | |
static vtkIdType | ReverseConnectToRemoteWithTimeout (int port, int timeout) |
static vtkIdType | ReverseConnectToRemote (int port, int timeout, bool(*callback)(), vtkNetworkAccessManager::ConnectionResult &result) |
static vtkIdType | ConnectToRemote (const char *dshost, int dsport, const char *rshost, int rsport, int timeout=60) |
static vtkIdType | ConnectToRemote (const char *dshost, int dsport, const char *rshost, int rsport, int timeout, bool(*callback)(), vtkNetworkAccessManager::ConnectionResult &result) |
static vtkIdType | ReverseConnectToRemote (int dsport, int rsport) |
static vtkIdType | ReverseConnectToRemoteWithTimeout (int dsport, int rsport, int timeout) |
static vtkIdType | ReverseConnectToRemote (int dsport, int rsport, int timeout, bool(*callback)(), vtkNetworkAccessManager::ConnectionResult &result) |
static void | Disconnect (vtkIdType sessionid) |
Use this method to disconnect from a session. More... | |
static void | Disconnect (vtkSMSession *session) |
static vtkPVSessionBase * | SafeDownCast (vtkObject *o) |
static vtkPVSession * | SafeDownCast (vtkObject *o) |
static vtkSession * | SafeDownCast (vtkObject *o) |
static vtkObject * | New () |
vtkSMSessionClient () | |
~vtkSMSessionClient () override | |
void | SetRenderServerController (vtkMultiProcessController *) |
void | SetDataServerController (vtkMultiProcessController *) |
void | SetupDataServerRenderServerConnection () |
void | UnRegisterSIObject (vtkSMMessage *msg) override |
Delete server side object. More... | |
void | RegisterSIObject (vtkSMMessage *msg) override |
Notify server side object that it is used by one more client. More... | |
vtkTypeUInt32 | GetRealLocation (vtkTypeUInt32) |
Translates the location to a real location based on whether a separate render-server exists. More... | |
virtual void | SetURI (const char *) |
bool | OnWrongTagEvent (vtkObject *caller, unsigned long eventid, void *calldata) override |
Callback when any vtkMultiProcessController subclass fires a WrongTagEvent. More... | |
virtual void | OnConnectionLost (vtkObject *caller, unsigned long eventid, void *calldata) |
Callback when any vtkMultiProcessController subclass fires a ErrorEvent. More... | |
vtkSMSession (bool initialize_during_constructor=true, vtkPVSessionCore *preExistingSessionCore=nullptr) | |
~vtkSMSession () override | |
virtual void | ProcessNotification (const vtkSMMessage *) |
Process the Notifation message sent using API to communicate from server-to-client. More... | |
void | UpdateStateHistory (vtkSMMessage *msg) |
This method has been externalized so classes that heritate from vtkSMSession and override PushState could easily keep track of the StateHistory and maintain the UndoRedo mecanisme. More... | |
vtkPVSessionBase () | |
vtkPVSessionBase (vtkPVSessionCore *coreToUse) | |
~vtkPVSessionBase () override | |
void | RegisterRemoteObject (vtkTypeUInt32 globalid, vtkTypeUInt32 location, vtkObject *obj) |
Register a remote object. More... | |
void | UnRegisterRemoteObject (vtkTypeUInt32 globalid, vtkTypeUInt32 location) |
Unregister a remote object. More... | |
vtkPVSessionCore * | GetSessionCore () const |
Method used to migrate from one Session type to another by keeping the same vtkPVSessionCore. More... | |
void | SetSessionCore (vtkPVSessionCore *) |
virtual bool | StartProcessingRemoteNotification () |
Methods used to monitor if we are currently processing a server notification Only vtkSMSessionClient use the flag to disable ignore_synchronization properties from being updated. More... | |
virtual void | StopProcessingRemoteNotification (bool previousValue) |
vtkPVSession () | |
~vtkPVSession () override | |
vtkSession () | |
~vtkSession () override | |
virtual void | Activate () |
Subclasses must call this to mark the session active. More... | |
virtual void | DeActivate () |
Subclasses must call this to mark the session inactive. More... | |
vtkObject () | |
virtual | ~vtkObject () |
vtkObjectBase () | |
virtual | ~vtkObjectBase () |
enum | { EXCEPTION_EVENT_TAG = 31416 } |
vtkSMSessionClient supports both connecting a pvserver as well as connecting a pvdataserver/pvrenderserver.
Definition at line 23 of file vtkSMSessionClient.h.
Definition at line 27 of file vtkSMSessionClient.h.
Reimplemented from vtkSMSession.
inlineoverridevirtual |
Definition at line 33 of file vtkSMSessionClient.h.
URL can be of the following format: cs://<pvserver-host>:<pvserver-port> cdsrs://<pvdataserver-host>:<pvdataserver-port>/<pvrenderserver-host>:<pvrenderserver-port> In both cases the port is optional. When not provided default pvserver/pvdataserver port // is 11111, while default pvrenderserver port is 22221. For reverse connect i.e. the client waits for the server to connect back, simply add "rc" to the protocol e.g. csrc://<pvserver-host>:<pvserver-port> cdsrsrc://<pvdataserver-host>:<pvdataserver-port>/<pvrenderserver-host>:<pvrenderserver-port> In this case, the hostname is irrelevant and is ignored. Wait for timeout seconds for the connection. Default is 60, 0 means no retry. -1 means infinite retries. The callback should return true, if the connection should continue trying to connect, else return false to abort. The result arg provide information about the failure or sucess of the connection, see vtkNetworkAccessManager::ConnectionResult for possible values.
Definition at line 55 of file vtkSMSessionClient.h.
e.g. if the current processes acts as a data-server and a render-server, it returns DATA_SERVER | RENDER_SERVER. Overridden to return CLIENT since this process only acts as the client.
Definition at line 75 of file vtkSMSessionClient.h.
Value must be DATA_SERVER_ROOT or RENDER_SERVER_ROOT or CLIENT.
Reimplemented from vtkPVSession.
These include server-side capabilities as well as server-side command line arguments e.g. tile-display parameters. Use this method to obtain the server-side information. Overridden to provide return the information gathered from data-server and render-server.
Reimplemented from vtkPVSessionBase.
Definition at line 91 of file vtkSMSessionClient.h.
Initialize the data-server-render-server connection, if applicable.
Push the state.
Push the state.
Push the state.
Push the state.
Application can add observer to this signal and set this flag to true, if it wants to abort the wait for the server.
void vtkSMSessionClient::CloseSession | ( | ) |
location
identifies the processes to gather the information from. Overridden to fetch the information from server if needed, otherwise it's handled locally.
If more than 1 server is identified, than it returns the maximum number of processes e.g. is servers = DATA_SERVER | RENDER_SERVER and there are 3 data-server nodes and 2 render-server nodes, then this method will return 3.
If more than 1 server is identified it will return true only if all of the servers have MPI initialized.
Overridden to relay to the server(s).
int vtkSMSessionClient::GetConnectID | ( | ) |
This implementation works locally. without any code distribution. To support the distributed architecture the vtkSMSessionClient override those method to call them on the DATA_SERVER vtkPVSessionBase instance.
1 = ReverveNextIdChunk(10); | Reserved ids [1,2,3,4,5,6,7,8,9,10] 11 = ReverveNextIdChunk(10);| Reserved ids [11,12,13,14,15,16,17,18,19,20] b = a + 10;
void vtkSMSessionClient::OnServerNotificationMessageRMI | ( | void * | message, |
int | message_length | ||
overrideprotectedvirtual |
(SIObject)
protectedvirtual |
Return true if the event was handle locally.
protectedvirtual |
Definition at line 243 of file vtkSMSessionClient.h.
Definition at line 244 of file vtkSMSessionClient.h.
Definition at line 246 of file vtkSMSessionClient.h.
Definition at line 247 of file vtkSMSessionClient.h.
Definition at line 248 of file vtkSMSessionClient.h.
Definition at line 249 of file vtkSMSessionClient.h.
Definition at line 251 of file vtkSMSessionClient.h.
Definition at line 254 of file vtkSMSessionClient.h.
Definition at line 260 of file vtkSMSessionClient.h.
Definition at line 263 of file vtkSMSessionClient.h.
