vtkSISourceProxy is the server-side helper for a vtkSMSourceProxy. More...
#include <vtkSIMetaReaderProxy.h>
typedef vtkSISourceProxy | Superclass |
typedef vtkSIProxy | Superclass |
typedef vtkSIObject | Superclass |
virtual vtkAlgorithmOutput * | GetOutputPort (int port) |
Returns the vtkAlgorithmOutput for an output port, if valid. More... | |
void | UpdatePipelineInformation () override |
Triggers UpdateInformation() on vtkObject if possible. More... | |
virtual void | UpdatePipeline (int port, double time, bool doTime) |
Triggers UpdatePipeline(). More... | |
virtual void | SetupSelectionProxy (int port, vtkSIProxy *extractSelection) |
setups extract selection proxies. More... | |
virtual void | SetDisablePipelineExecution (bool value) |
Allow to shut down pipeline execution. More... | |
void | RecreateVTKObjects () override |
Overridden to update the output ports. More... | |
void | AboutToDelete () override |
This method is called before the deletion of the SIObject. More... | |
void | Push (vtkSMMessage *msg) override |
Push a new state to the underneath implementation. More... | |
void | Pull (vtkSMMessage *msg) override |
Pull the current state of the underneath implementation. More... | |
vtkSIProperty * | GetSIProperty (const char *name) |
Provides access to the property helper. More... | |
bool | IsNullProxy () |
Return true if that Proxy is supposed to have NO vtk class, which means its a NullProxy. More... | |
virtual bool | ExtendDefinition (const char *xml) |
Counter part to vtkSMSelfGeneratingSourceProxy::ExtendDefinition(). More... | |
A helper that makes up an default name if none is provided. More... | |
vtkObjectBase * | GetVTKObject () |
Returns access to the VTKObject pointer, if any. More... | |
void | SetVTKObject (vtkObjectBase *) |
Returns the VTKClassName. More... | |
virtual void | AddInput (int input_port, vtkAlgorithmOutput *connection, const char *method) |
These methods are called to add/remove input connections by vtkSIInputProperty. More... | |
virtual void | CleanInputs (const char *method) |
virtual void | Initialize (vtkPVSessionCore *session) |
Initializes the instance. More... | |
vtkClientServerInterpreter * | GetInterpreter () |
Provides access to the Interpreter. More... | |
vtkSIObject * | GetSIObject (vtkTypeUInt32 globalid) const |
Convenience method to obtain a vtkSIObject subclass given its global id. More... | |
vtkObject * | GetRemoteObject (vtkTypeUInt32 globalid) |
Convenience method to obtain a vtkObject subclass given its global id. More... | |
virtual void | SetGlobalID (vtkTypeUInt32) |
Get/Set the global id for this object. More... | |
virtual void | Modified () |
static vtkSIMetaReaderProxy * | New () |
static vtkSIMetaReaderProxy * | SafeDownCast (vtkObject *o) |
static vtkSISourceProxy * | New () |
static vtkSISourceProxy * | SafeDownCast (vtkObject *o) |
static vtkSIProxy * | New () |
static vtkSIProxy * | SafeDownCast (vtkObject *o) |
static vtkSIObject * | New () |
static vtkSIObject * | SafeDownCast (vtkObject *o) |
static vtkObject * | New () |
vtkSIMetaReaderProxy () | |
~vtkSIMetaReaderProxy () override | |
void | OnCreateVTKObjects () override |
Called after CreateVTKObjects(). More... | |
bool | ReadXMLAttributes (vtkPVXMLElement *element) override |
Read xml-attributes. More... | |
virtual void | SetFileNameMethod (const char *) |
virtual char * | GetFileNameMethod () |
vtkSISourceProxy () | |
~vtkSISourceProxy () override | |
bool | CreateVTKObjects () override |
Overridden to setup the output ports and pipelines for the output ports. More... | |
virtual bool | CreateOutputPorts () |
Create the output ports and add post filters for each output port. More... | |
virtual void | SetExecutiveName (const char *) |
void | MarkStartEvent () |
Callbacks to add start/end events to the timer log. More... | |
void | MarkEndEvent () |
vtkSIProxy () | |
~vtkSIProxy () override | |
virtual vtkObjectBase * | NewVTKObject (const char *className) |
Create an instance of the class specified. More... | |
vtkSIProxy * | GetSubSIProxy (const char *name) |
Returns the subproxy helper for the subproxy with the given name, if any. More... | |
vtkSIProxyDefinitionManager * | GetProxyDefinitionManager () |
Provides access to the vtkSIProxyDefinitionManager held by the session. More... | |
virtual void | DeleteVTKObjects () |
Called to delete VTK objects. More... | |
bool | InitializeAndCreateVTKObjects (vtkSMMessage *message) |
Called by vtkSIProxy::Push() to ensure that the vtkSIProxy has been initialized. More... | |
void | AddSIProperty (const char *name, vtkSIProperty *) |
Adds a vtkSMProperty's server-implementation. More... | |
virtual void | SetXMLGroup (const char *) |
virtual void | SetXMLSubProxyName (const char *) |
virtual void | SetPostPush (const char *) |
virtual void | SetPostCreation (const char *) |
unsigned int | GetNumberOfSubSIProxys () |
API to iterate over subproxy helpers. More... | |
vtkSIProxy * | GetSubSIProxy (unsigned int cc) |
virtual bool | ReadXMLProperty (vtkPVXMLElement *property_element) |
Parses the XML to create property/subproxy helpers. More... | |
virtual bool | ReadXMLSubProxy (vtkPVXMLElement *subproxy_element) |
vtkSIObject () | |
~vtkSIObject () override | |
vtkObject () | |
virtual | ~vtkObject () |
vtkObjectBase () | |
virtual | ~vtkObjectBase () |
Protected Attributes | |
char * | FileNameMethod |
char * | ExecutiveName |
bool | DisablePipelineExecution |
char * | VTKClassName |
char * | XMLGroup |
char * | XMLName |
char * | XMLSubProxyName |
char * | PostPush |
char * | PostCreation |
int | NumberOfInputPorts |
vtkSmartPointer< vtkObjectBase > | VTKObject |
bool | ObjectsCreated |
vtkWeakPointer< vtkClientServerInterpreter > | Interpreter |
vtkWeakPointer< vtkPVSessionCore > | SessionCore |
vtkSMMessage * | LastPushedMessage |
vtkTypeUInt32 | GlobalID |
bool | Debug |
vtkTimeStamp | MTime |
It adds support to handle various vtkAlgorithm specific Invoke requests coming from the client. vtkSISourceProxy also inserts post-processing filters for each output port from the vtkAlgorithm. These post-processing filters deal with things like parallelizing the data etc.
Definition at line 21 of file vtkSIMetaReaderProxy.h.
Definition at line 25 of file vtkSIMetaReaderProxy.h.
Reimplemented from vtkSISourceProxy.
overrideprotectedvirtual |
The main difference for subclasses when overriding CreateVTKObjects() or OnCreateVTKObjects() is that CreateVTKObjects() is called before ReadXMLAttributes() is called, while OnCreateVTKObjects() is called after ReadXMLAttributes().
Reimplemented from vtkSIProxy.
protectedvirtual |
protectedvirtual |
Definition at line 42 of file vtkSIMetaReaderProxy.h.
