vtkSISourceProxy is the server-side helper for a vtkSMSourceProxy. More...
#include <vtkSISourceProxy.h>
typedef vtkSIProxy | Superclass |
typedef vtkSIObject | Superclass |
virtual vtkAlgorithmOutput * | GetOutputPort (int port) |
Returns the vtkAlgorithmOutput for an output port, if valid. More... | |
void | UpdatePipelineInformation () override |
Triggers UpdateInformation() on vtkObject if possible. More... | |
virtual void | UpdatePipeline (int port, double time, bool doTime) |
Triggers UpdatePipeline(). More... | |
virtual void | SetupSelectionProxy (int port, vtkSIProxy *extractSelection) |
setups extract selection proxies. More... | |
virtual void | SetDisablePipelineExecution (bool value) |
Allow to shut down pipeline execution. More... | |
void | RecreateVTKObjects () override |
Overridden to update the output ports. More... | |
void | AboutToDelete () override |
This method is called before the deletion of the SIObject. More... | |
void | Push (vtkSMMessage *msg) override |
Push a new state to the underneath implementation. More... | |
void | Pull (vtkSMMessage *msg) override |
Pull the current state of the underneath implementation. More... | |
vtkSIProperty * | GetSIProperty (const char *name) |
Provides access to the property helper. More... | |
bool | IsNullProxy () |
Return true if that Proxy is supposed to have NO vtk class, which means its a NullProxy. More... | |
virtual bool | ExtendDefinition (const char *xml) |
Counter part to vtkSMSelfGeneratingSourceProxy::ExtendDefinition(). More... | |
A helper that makes up an default name if none is provided. More... | |
vtkObjectBase * | GetVTKObject () |
Returns access to the VTKObject pointer, if any. More... | |
void | SetVTKObject (vtkObjectBase *) |
Returns the VTKClassName. More... | |
virtual void | AddInput (int input_port, vtkAlgorithmOutput *connection, const char *method) |
These methods are called to add/remove input connections by vtkSIInputProperty. More... | |
virtual void | CleanInputs (const char *method) |
virtual void | Initialize (vtkPVSessionCore *session) |
Initializes the instance. More... | |
vtkClientServerInterpreter * | GetInterpreter () |
Provides access to the Interpreter. More... | |
vtkSIObject * | GetSIObject (vtkTypeUInt32 globalid) const |
Convenience method to obtain a vtkSIObject subclass given its global id. More... | |
vtkObject * | GetRemoteObject (vtkTypeUInt32 globalid) |
Convenience method to obtain a vtkObject subclass given its global id. More... | |
virtual void | SetGlobalID (vtkTypeUInt32) |
Get/Set the global id for this object. More... | |
virtual void | Modified () |
static vtkSISourceProxy * | New () |
static vtkSISourceProxy * | SafeDownCast (vtkObject *o) |
static vtkSIProxy * | New () |
static vtkSIProxy * | SafeDownCast (vtkObject *o) |
static vtkSIObject * | New () |
static vtkSIObject * | SafeDownCast (vtkObject *o) |
static vtkObject * | New () |
vtkSISourceProxy () | |
~vtkSISourceProxy () override | |
bool | CreateVTKObjects () override |
Overridden to setup the output ports and pipelines for the output ports. More... | |
bool | ReadXMLAttributes (vtkPVXMLElement *element) override |
Read xml-attributes. More... | |
void | OnCreateVTKObjects () override |
Called after CreateVTKObjects(). More... | |
virtual bool | CreateOutputPorts () |
Create the output ports and add post filters for each output port. More... | |
virtual void | SetExecutiveName (const char *) |
void | MarkStartEvent () |
Callbacks to add start/end events to the timer log. More... | |
void | MarkEndEvent () |
vtkSIProxy () | |
~vtkSIProxy () override | |
virtual vtkObjectBase * | NewVTKObject (const char *className) |
Create an instance of the class specified. More... | |
vtkSIProxy * | GetSubSIProxy (const char *name) |
Returns the subproxy helper for the subproxy with the given name, if any. More... | |
vtkSIProxyDefinitionManager * | GetProxyDefinitionManager () |
Provides access to the vtkSIProxyDefinitionManager held by the session. More... | |
virtual void | DeleteVTKObjects () |
Called to delete VTK objects. More... | |
bool | InitializeAndCreateVTKObjects (vtkSMMessage *message) |
Called by vtkSIProxy::Push() to ensure that the vtkSIProxy has been initialized. More... | |
void | AddSIProperty (const char *name, vtkSIProperty *) |
Adds a vtkSMProperty's server-implementation. More... | |
virtual void | SetXMLGroup (const char *) |
virtual void | SetXMLSubProxyName (const char *) |
virtual void | SetPostPush (const char *) |
virtual void | SetPostCreation (const char *) |
unsigned int | GetNumberOfSubSIProxys () |
API to iterate over subproxy helpers. More... | |
vtkSIProxy * | GetSubSIProxy (unsigned int cc) |
virtual bool | ReadXMLProperty (vtkPVXMLElement *property_element) |
Parses the XML to create property/subproxy helpers. More... | |
virtual bool | ReadXMLSubProxy (vtkPVXMLElement *subproxy_element) |
vtkSIObject () | |
~vtkSIObject () override | |
vtkObject () | |
virtual | ~vtkObject () |
vtkObjectBase () | |
virtual | ~vtkObjectBase () |
Protected Attributes | |
char * | ExecutiveName |
bool | DisablePipelineExecution |
char * | VTKClassName |
char * | XMLGroup |
char * | XMLName |
char * | XMLSubProxyName |
char * | PostPush |
char * | PostCreation |
int | NumberOfInputPorts |
vtkSmartPointer< vtkObjectBase > | VTKObject |
bool | ObjectsCreated |
vtkWeakPointer< vtkClientServerInterpreter > | Interpreter |
vtkWeakPointer< vtkPVSessionCore > | SessionCore |
vtkSMMessage * | LastPushedMessage |
vtkTypeUInt32 | GlobalID |
bool | Debug |
vtkTimeStamp | MTime |
Friends | |
class | vtkSICompoundSourceProxy |
It adds support to handle various vtkAlgorithm specific Invoke requests coming from the client. vtkSISourceProxy also inserts post-processing filters for each output port from the vtkAlgorithm. These post-processing filters deal with things like parallelizing the data etc.
Definition at line 23 of file vtkSISourceProxy.h.
Definition at line 27 of file vtkSISourceProxy.h.
Reimplemented from vtkSIProxy.
Reimplemented in vtkSIPythonSourceProxy, vtkSIMetaReaderProxy, vtkSICompoundSourceProxy, vtkSIImageTextureProxy, vtkSIMultiplexerSourceProxy, and vtkSIWriterProxy.
Reimplemented in vtkSIPythonSourceProxy, vtkSIImageTextureProxy, and vtkSIWriterProxy.
Reimplemented in vtkSICompoundSourceProxy.
Called from client.
inlinevirtual |
This is particularly useful for a Catalyst session that does not contains any real data.
Definition at line 55 of file vtkSISourceProxy.h.
Reimplemented in vtkSIPythonSourceProxy.
overrideprotectedvirtual |
The main difference for subclasses when overriding CreateVTKObjects() or OnCreateVTKObjects() is that CreateVTKObjects() is called before ReadXMLAttributes() is called, while OnCreateVTKObjects() is called after ReadXMLAttributes().
Reimplemented in vtkSIWriterProxy, and vtkSIImageTextureProxy.
protectedvirtual |
CreateOutputPorts is only called when an output-port is requested, i.e. GetOutputPort() is called.
protectedvirtual |
friend |
Definition at line 103 of file vtkSISourceProxy.h.
Definition at line 99 of file vtkSISourceProxy.h.
Definition at line 100 of file vtkSISourceProxy.h.
