vtkSISourceProxy for all VTKPythonAlgorithmBase
-based algorithms.
#include <vtkSIPythonSourceProxy.h>
typedef vtkSISourceProxy | Superclass |
typedef vtkSIProxy | Superclass |
typedef vtkSIObject | Superclass |
void | Push (vtkSMMessage *) override |
Push a new state to the underneath implementation. More... | |
void | Pull (vtkSMMessage *) override |
Pull the current state of the underneath implementation. More... | |
void | RecreateVTKObjects () override |
Overridden to update the output ports. More... | |
void | Initialize (vtkPVSessionCore *session) override |
Initializes the instance. More... | |
virtual vtkAlgorithmOutput * | GetOutputPort (int port) |
Returns the vtkAlgorithmOutput for an output port, if valid. More... | |
void | UpdatePipelineInformation () override |
Triggers UpdateInformation() on vtkObject if possible. More... | |
virtual void | UpdatePipeline (int port, double time, bool doTime) |
Triggers UpdatePipeline(). More... | |
virtual void | SetupSelectionProxy (int port, vtkSIProxy *extractSelection) |
setups extract selection proxies. More... | |
virtual void | SetDisablePipelineExecution (bool value) |
Allow to shut down pipeline execution. More... | |
void | AboutToDelete () override |
This method is called before the deletion of the SIObject. More... | |
vtkSIProperty * | GetSIProperty (const char *name) |
Provides access to the property helper. More... | |
bool | IsNullProxy () |
Return true if that Proxy is supposed to have NO vtk class, which means its a NullProxy. More... | |
virtual bool | ExtendDefinition (const char *xml) |
Counter part to vtkSMSelfGeneratingSourceProxy::ExtendDefinition(). More... | |
A helper that makes up an default name if none is provided. More... | |
vtkObjectBase * | GetVTKObject () |
Returns access to the VTKObject pointer, if any. More... | |
void | SetVTKObject (vtkObjectBase *) |
Returns the VTKClassName. More... | |
virtual void | AddInput (int input_port, vtkAlgorithmOutput *connection, const char *method) |
These methods are called to add/remove input connections by vtkSIInputProperty. More... | |
virtual void | CleanInputs (const char *method) |
vtkClientServerInterpreter * | GetInterpreter () |
Provides access to the Interpreter. More... | |
vtkSIObject * | GetSIObject (vtkTypeUInt32 globalid) const |
Convenience method to obtain a vtkSIObject subclass given its global id. More... | |
vtkObject * | GetRemoteObject (vtkTypeUInt32 globalid) |
Convenience method to obtain a vtkObject subclass given its global id. More... | |
virtual void | SetGlobalID (vtkTypeUInt32) |
Get/Set the global id for this object. More... | |
virtual void | Modified () |
static vtkSIPythonSourceProxy * | New () |
static vtkSIPythonSourceProxy * | SafeDownCast (vtkObject *o) |
static vtkSISourceProxy * | New () |
static vtkSISourceProxy * | SafeDownCast (vtkObject *o) |
static vtkSIProxy * | New () |
static vtkSIProxy * | SafeDownCast (vtkObject *o) |
static vtkSIObject * | New () |
static vtkSIObject * | SafeDownCast (vtkObject *o) |
static vtkObject * | New () |
vtkSIPythonSourceProxy () | |
~vtkSIPythonSourceProxy () override | |
vtkObjectBase * | NewVTKObject (const char *className) override |
Overridden to use the Python interpreter to instantiate Python classes. More... | |
void | DeleteVTKObjects () override |
Overridden to release any Python objects created. More... | |
vtkSISourceProxy () | |
~vtkSISourceProxy () override | |
bool | CreateVTKObjects () override |
Overridden to setup the output ports and pipelines for the output ports. More... | |
bool | ReadXMLAttributes (vtkPVXMLElement *element) override |
Read xml-attributes. More... | |
void | OnCreateVTKObjects () override |
Called after CreateVTKObjects(). More... | |
virtual bool | CreateOutputPorts () |
Create the output ports and add post filters for each output port. More... | |
virtual void | SetExecutiveName (const char *) |
void | MarkStartEvent () |
Callbacks to add start/end events to the timer log. More... | |
void | MarkEndEvent () |
vtkSIProxy () | |
~vtkSIProxy () override | |
vtkSIProxy * | GetSubSIProxy (const char *name) |
Returns the subproxy helper for the subproxy with the given name, if any. More... | |
vtkSIProxyDefinitionManager * | GetProxyDefinitionManager () |
Provides access to the vtkSIProxyDefinitionManager held by the session. More... | |
bool | InitializeAndCreateVTKObjects (vtkSMMessage *message) |
Called by vtkSIProxy::Push() to ensure that the vtkSIProxy has been initialized. More... | |
void | AddSIProperty (const char *name, vtkSIProperty *) |
Adds a vtkSMProperty's server-implementation. More... | |
virtual void | SetXMLGroup (const char *) |
virtual void | SetXMLSubProxyName (const char *) |
virtual void | SetPostPush (const char *) |
virtual void | SetPostCreation (const char *) |
unsigned int | GetNumberOfSubSIProxys () |
API to iterate over subproxy helpers. More... | |
vtkSIProxy * | GetSubSIProxy (unsigned int cc) |
virtual bool | ReadXMLProperty (vtkPVXMLElement *property_element) |
Parses the XML to create property/subproxy helpers. More... | |
virtual bool | ReadXMLSubProxy (vtkPVXMLElement *subproxy_element) |
vtkSIObject () | |
~vtkSIObject () override | |
vtkObject () | |
virtual | ~vtkObject () |
vtkObjectBase () | |
virtual | ~vtkObjectBase () |
char * | ExecutiveName |
bool | DisablePipelineExecution |
char * | VTKClassName |
char * | XMLGroup |
char * | XMLName |
char * | XMLSubProxyName |
char * | PostPush |
char * | PostCreation |
int | NumberOfInputPorts |
vtkSmartPointer< vtkObjectBase > | VTKObject |
bool | ObjectsCreated |
vtkWeakPointer< vtkClientServerInterpreter > | Interpreter |
vtkWeakPointer< vtkPVSessionCore > | SessionCore |
vtkSMMessage * | LastPushedMessage |
vtkTypeUInt32 | GlobalID |
bool | Debug |
vtkTimeStamp | MTime |
-based algorithms.
vtkSIPythonSourceProxy makes is possible to work with a VTKPythonAlgorithmBase-based Python class in ParaView. By handling the push/pull APIs to forward the calls to the Python object, we can make such Python algorithms behave like regular C++-based algorithm subclasses.
Definition at line 23 of file vtkSIPythonSourceProxy.h.
Definition at line 27 of file vtkSIPythonSourceProxy.h.
Reimplemented from vtkSISourceProxy.
Reimplemented from vtkSIProxy.
Session is the session to which this instance belongs to. During initialization, the SIObject basically obtains ivars for necessary components.
Reimplemented from vtkSIObject.
overrideprotectedvirtual |
