void | AboutToDelete () override |
| This method is called before the deletion of the SIObject. More...
void | Push (vtkSMMessage *msg) override |
| Push a new state to the underneath implementation. More...
void | Pull (vtkSMMessage *msg) override |
| Pull the current state of the underneath implementation. More...
vtkSIProperty * | GetSIProperty (const char *name) |
| Provides access to the property helper. More...
bool | IsNullProxy () |
| Return true if that Proxy is supposed to have NO vtk class, which means its a NullProxy. More...
virtual void | UpdatePipelineInformation () |
| Triggers UpdateInformation() on vtkObject if possible. More...
| Called by vtkSMProxy::RecreateVTKObjects() to re-create the VTK objects. More...
virtual bool | ExtendDefinition (const char *xml) |
| Counter part to vtkSMSelfGeneratingSourceProxy::ExtendDefinition(). More...
vtkObjectBase * | GetVTKObject () |
| Returns access to the VTKObject pointer, if any. More...
void | SetVTKObject (vtkObjectBase *) |
| Returns the VTKClassName. More...
virtual void | AddInput (int input_port, vtkAlgorithmOutput *connection, const char *method) |
| These methods are called to add/remove input connections by vtkSIInputProperty. More...
virtual void | CleanInputs (const char *method) |
virtual void | Initialize (vtkPVSessionCore *session) |
| Initializes the instance. More...
vtkClientServerInterpreter * | GetInterpreter () |
| Provides access to the Interpreter. More...
vtkSIObject * | GetSIObject (vtkTypeUInt32 globalid) const |
| Convenience method to obtain a vtkSIObject subclass given its global id. More...
vtkObject * | GetRemoteObject (vtkTypeUInt32 globalid) |
| Convenience method to obtain a vtkObject subclass given its global id. More...
virtual void | SetGlobalID (vtkTypeUInt32) |
| Get/Set the global id for this object. More...
virtual void | Modified () |
