helper for color map editor handling More...
#include <vtkSMColorMapEditorHelper.h>
enum | SelectedPropertiesTypes { Representation = 0, Blocks = 1 } |
enum | BlockPropertyState : std::uint8_t { Disabled = 0x0, RepresentationInherited = 0x1, BlockInherited = 0x2, MixedInherited = 0x3, Set = 0x4, SetAndRepresentationInherited = 0x5, SetAndBlockInherited = 0x6, SetAndMixedInherited = 0x7, NumberOfStates = 0x8 } |
using | Color = std::array< double, 3 > |
using | ColorArray = std::pair< int, std::string > |
virtual void | SetSelectedPropertiesType (int) |
Set/Get the selected properties type. More... | |
void | SetSelectedPropertiesTypeToRepresentation () |
void | SetSelectedPropertiesTypeToBlocks () |
virtual int | GetSelectedPropertiesType () |
virtual void | Modified () |
static vtkSMColorMapEditorHelper * | New () |
static vtkSMColorMapEditorHelper * | SafeDownCast (vtkObject *o) |
static SelectedPropertiesTypes | GetPropertyType (vtkSMProperty *property) |
Determine if a property is a block property. More... | |
static std::vector< std::string > | GetSelectedBlockSelectors (vtkSMProxy *proxy) |
Returns the selected block selectors for this representation. More... | |
static std::vector< std::string > | GetColorArraysBlockSelectors (vtkSMProxy *proxy) |
Returns the selectors that use a color array for this representation. More... | |
static std::pair< std::string, BlockPropertyState > | HasBlockProperty (vtkSMProxy *proxy, const std::string &blockSelector, const std::string &propertyName) |
Determine if a propert(y/ies) of a selector(s) is set, inherited from a block, or from the representation, or mixed. More... | |
static std::pair< std::string, BlockPropertyState > | GetBlockPropertyStateFromBlockPropertyStates (const std::vector< std::pair< std::string, BlockPropertyState >> &states) |
static std::pair< std::string, BlockPropertyState > | HasBlockProperty (vtkSMProxy *proxy, const std::vector< std::string > &blockSelectors, const std::string &propertyName) |
static std::pair< std::string, BlockPropertyState > | HasBlockProperties (vtkSMProxy *proxy, const std::string &blockSelector, const std::vector< std::string > &propertyNames) |
static std::pair< std::string, BlockPropertyState > | HasBlocksProperties (vtkSMProxy *proxy, const std::vector< std::string > &blockSelectors, const std::vector< std::string > &propertyNames) |
static void | SetupLookupTable (vtkSMProxy *proxy) |
Given the input registered representation proxy , sets up a lookup table associated with the representation if a scalar bar is being used for proxy . More... | |
static void | SetupBlocksLookupTables (vtkSMProxy *proxy) |
static bool | UpdateScalarBarRange (vtkSMProxy *proxy, vtkSMProxy *view, bool deleteRange) |
Updates the ranges shown in the scalar bar. More... | |
static std::vector< vtkTypeBool > | UpdateBlocksScalarBarRange (vtkSMProxy *proxy, vtkSMProxy *view, bool deleteRange) |
static bool | RescaleTransferFunctionToVisibleRange (vtkSMProxy *proxy, vtkSMProxy *view) |
Rescales the color transfer function and the opacity transfer function using the current data range, limited to the current visible elements. More... | |
static bool | RescaleTransferFunctionToVisibleRange (vtkSMProxy *proxy, vtkSMProxy *view, const char *arrayName, int attributeType) |
static bool | HideScalarBarIfNotNeeded (vtkSMProxy *repr, vtkSMProxy *view) |
While SetScalarBarVisibility can be used to hide a scalar bar, it will always simply hide the scalar bar even if its being used by some other representation. More... | |
static bool | HideBlocksScalarBarIfNotNeeded (vtkSMProxy *repr, vtkSMProxy *view) |
static bool | IsScalarBarVisible (vtkSMProxy *repr, vtkSMProxy *view) |
Check scalar bar visibility. More... | |
static bool | IsBlockScalarBarVisible (vtkSMProxy *repr, vtkSMProxy *view, const std::string &blockSelector) |
static std::vector< vtkTypeBool > | IsBlocksScalarBarVisible (vtkSMProxy *repr, vtkSMProxy *view, const std::vector< std::string > &blockSelectors) |
static vtkPVArrayInformation * | GetArrayInformationForColorArray (vtkSMProxy *proxy, bool checkRepresentedData=true) |
Returns the array information for the data array used for scalar coloring, from input data. More... | |
static vtkPVArrayInformation * | GetBlockArrayInformationForColorArray (vtkSMProxy *proxy, const std::string &blockSelector) |
static std::vector< vtkPVArrayInformation * > | GetBlocksArrayInformationForColorArray (vtkSMProxy *proxy, const std::vector< std::string > &blockSelectors) |
static std::string | GetDecoratedArrayName (vtkSMProxy *proxy, const std::string &arrayName) |
In case of UseSeparateColorMap enabled, this function prefix the given arrayName with unique identifier, otherwise it acts as a passthrough. More... | |
static std::string | GetBlockDecoratedArrayName (vtkSMProxy *proxy, const std::string &blockSelector, const std::string &arrayName) |
static std::vector< std::string > | GetBlocksDecoratedArrayNames (vtkSMProxy *proxy, const std::vector< std::string > &blockSelectors, const std::string &arrayName) |
static vtkPVProminentValuesInformation * | GetProminentValuesInformationForColorArray (vtkSMProxy *proxy, double uncertaintyAllowed=1e-6, double fraction=1e-3, bool force=false) |
Call vtkSMRepresentationProxy::GetProminentValuesInformation() for the array used for scalar color, if any. More... | |
static vtkPVProminentValuesInformation * | GetBlockProminentValuesInformationForColorArray (vtkSMProxy *proxy, const std::string &blockSelector, double uncertaintyAllowed=1e-6, double fraction=1e-3, bool force=false) |
static std::vector< vtkPVProminentValuesInformation * > | GetBlocksProminentValuesInformationForColorArray (vtkSMProxy *proxy, const std::vector< std::string > &blockSelectors, double uncertaintyAllowed=1e-6, double fraction=1e-3, bool force=false) |
static int | IsScalarBarStickyVisible (vtkSMProxy *proxy, vtkSMProxy *view) |
Checks if the scalar bar of this representation in view is sticky visible, i.e. More... | |
static int | IsBlockScalarBarStickyVisible (vtkSMProxy *proxy, vtkSMProxy *view, const std::string &blockSelector) |
static std::vector< int > | IsBlocksScalarBarStickyVisible (vtkSMProxy *proxy, vtkSMProxy *view, const std::vector< std::string > &blockSelectors) |
static void | ResetBlockProperty (vtkSMProxy *proxy, const std::string &blockSelector, const std::string &propertyName) |
Reset a block property. More... | |
static void | RemoveBlockProperties (vtkSMProxy *proxy, const std::string &blockSelector, const std::vector< std::string > &propertyNames) |
static void | ResetBlocksProperty (vtkSMProxy *proxy, const std::vector< std::string > &blockSelectors, const std::string &propertyName) |
static void | ResetBlocksProperties (vtkSMProxy *proxy, const std::vector< std::string > &blockSelectors, const std::vector< std::string > &propertyNames) |
static vtkObject * | New () |
vtkSMColorMapEditorHelper () | |
~vtkSMColorMapEditorHelper () override | |
std::vector< vtkTypeBool > | SetSelectedScalarColoringInternal (vtkSMProxy *proxy, const char *arrayName, int attributeType, bool useComponent, int component) |
vtkObject () | |
virtual | ~vtkObject () |
vtkObjectBase () | |
virtual | ~vtkObjectBase () |
Static Protected Member Functions | |
static bool | SetScalarColoringInternal (vtkSMProxy *proxy, const char *arrayName, int attributeType, bool useComponent, int component) |
Internal method to set scalar coloring, do not use directly. More... | |
static std::vector< vtkTypeBool > | SetBlocksScalarColoringInternal (vtkSMProxy *proxy, const std::vector< std::string > &blockSelectors, const char *arrayName, int attributeType, bool useComponent, int component) |
static bool | RescaleTransferFunctionToDataRange (vtkSMProxy *proxy, vtkPVArrayInformation *info, bool extend=false, bool force=true) |
Rescales transfer function ranges using the array information provided. More... | |
static bool | RescaleBlockTransferFunctionToDataRange (vtkSMProxy *proxy, const std::string &blockSelector, vtkPVArrayInformation *info, bool extend=false, bool force=true) |
static std::vector< vtkTypeBool > | RescaleBlocksTransferFunctionToDataRange (vtkSMProxy *proxy, const std::vector< std::string > &blockSelectors, std::vector< vtkPVArrayInformation *> infos, bool extend=false, bool force=true) |
static void | SetColorArray (vtkSMProxy *proxy, int attributeType, std::string arrayName) |
Set the color array name. More... | |
static void | SetBlockColorArray (vtkSMProxy *proxy, const std::string &blockSelector, int attributeType, std::string arrayName) |
static void | SetBlocksColorArray (vtkSMProxy *proxy, const std::vector< std::string > &blockSelectors, int attributeType, std::string arrayName) |
static void | RemoveBlockColorArray (vtkSMProxy *proxy, const std::string &blockSelector) |
static void | RemoveBlocksColorArrays (vtkSMProxy *proxy, const std::vector< std::string > &blockSelectors) |
static ColorArray | GetColorArray (vtkSMProxy *proxy) |
static ColorArray | GetBlockColorArray (vtkSMProxy *proxy, const std::string &blockSelector) |
static void | SetBlockLookupTable (vtkSMProxy *proxy, const std::string &blockSelector, vtkSMProxy *lutProxy) |
Set the block lookup table proxy. More... | |
static void | SetBlocksLookupTable (vtkSMProxy *proxy, const std::vector< std::string > &blockSelectors, vtkSMProxy *lutProxy) |
static void | RemoveBlockLookupTable (vtkSMProxy *proxy, const std::string &blockSelector) |
static void | RemoveBlocksLookupTables (vtkSMProxy *proxy, const std::vector< std::string > &blockSelectors) |
static vtkSMProxy * | GetLastLookupTable (vtkSMProxy *proxy) |
Used as a memory of what was the last LUT proxy linked to this representation. More... | |
static void | SetLastLookupTable (vtkSMProxy *proxy, vtkSMProxy *lutProxy) |
static vtkSMProxy * | GetLastBlockLookupTable (vtkSMProxy *proxy, const std::string &blockSelector) |
static std::vector< vtkSMProxy * > | GetLastBlocksLookupTables (vtkSMProxy *proxy, const std::vector< std::string > &blockSelectors) |
static void | SetLastBlockLookupTable (vtkSMProxy *proxy, const std::string &blockSelector, vtkSMProxy *lutProxy) |
static void | SetLastBlocksLookupTable (vtkSMProxy *proxy, const std::vector< std::string > &blockSelectors, vtkSMProxy *lutProxy) |
Friends | |
class | vtkSMPVRepresentationProxy |
static vtkSMProxy * | GetLUTProxy (vtkSMProxy *proxy, vtkSMProxy *view) |
Returns the lut proxy of this representation in the given view. More... | |
static vtkSMProxy * | GetLookupTable (vtkSMProxy *proxy) |
static vtkSMProxy * | GetLookupTable (vtkSMProxy *proxy, vtkSMProxy *view) |
static vtkSMProxy * | GetBlockLookupTable (vtkSMProxy *proxy, const std::string &blockSelector) |
static std::vector< vtkSMProxy * > | GetBlocksLookupTables (vtkSMProxy *proxy, const std::vector< std::string > &blockSelectors) |
static vtkSMProxy * | GetBlockLookupTable (vtkSMProxy *proxy, vtkSMProxy *view, const std::string &blockSelector) |
static std::vector< vtkSMProxy * > | GetBlocksLookupTables (vtkSMProxy *proxy, vtkSMProxy *view, const std::vector< std::string > &blockSelectors) |
std::vector< vtkSMProxy * > | GetSelectedLookupTables (vtkSMProxy *proxy) |
std::vector< vtkSMProxy * > | GetSelectedLookupTables (vtkSMProxy *proxy, vtkSMProxy *view) |
static bool | GetUsingScalarColoring (vtkSMProxy *proxy) |
Returns true if scalar coloring is enabled. More... | |
static bool | GetBlockUsingScalarColoring (vtkSMProxy *proxy, const std::string &blockSelector) |
static std::vector< vtkTypeBool > | GetBlocksUsingScalarColoring (vtkSMProxy *proxy, const std::vector< std::string > &blockSelectors) |
static bool | GetAnyBlockUsingScalarColoring (vtkSMProxy *proxy) |
std::vector< vtkTypeBool > | GetSelectedUsingScalarColorings (vtkSMProxy *proxy) |
bool | GetAnySelectedUsingScalarColoring (vtkSMProxy *proxy) |
static bool | SetScalarColoring (vtkSMProxy *proxy, const char *arrayName, int attributeType) |
Enable/disable scalar coloring using the specified array. More... | |
static bool | SetBlockScalarColoring (vtkSMProxy *proxy, const std::string &blockSelector, const char *arrayName, int attributeType) |
static std::vector< vtkTypeBool > | SetBlocksScalarColoring (vtkSMProxy *proxy, const std::vector< std::string > &blockSelectors, const char *arrayName, int attributeType) |
std::vector< vtkTypeBool > | SetSelectedScalarColoring (vtkSMProxy *proxy, const char *arrayName, int attributeType) |
static bool | SetScalarColoring (vtkSMProxy *proxy, const char *arrayName, int attributeType, int component) |
static bool | SetBlockScalarColoring (vtkSMProxy *proxy, const std::string &blockSelector, const char *arrayName, int attributeType, int component) |
static std::vector< vtkTypeBool > | SetBlocksScalarColoring (vtkSMProxy *proxy, const std::vector< std::string > &blockSelectors, const char *arrayName, int attributeType, int component) |
std::vector< vtkTypeBool > | SetSelectedScalarColoring (vtkSMProxy *proxy, const char *arrayName, int attributeType, int component) |
static bool | RescaleTransferFunctionToDataRange (vtkSMProxy *proxy, bool extend=false, bool force=true) |
Rescales the color transfer function and opacity transfer function using the current data range. More... | |
static bool | RescaleBlockTransferFunctionToDataRange (vtkSMProxy *proxy, const std::string &blockSelector, bool extend=false, bool force=true) |
static std::vector< vtkTypeBool > | RescaleBlocksTransferFunctionToDataRange (vtkSMProxy *proxy, const std::vector< std::string > &blockSelectors, bool extend=false, bool force=true) |
std::vector< vtkTypeBool > | RescaleSelectedTransferFunctionToDataRange (vtkSMProxy *proxy, bool extend=false, bool force=true) |
static bool | RescaleTransferFunctionToDataRange (vtkSMProxy *proxy, const char *arrayName, int attributeType, bool extend=false, bool force=true) |
Rescales the color transfer function and opacity transfer function using the current data range for the chosen data-array. More... | |
static bool | RescaleBlockTransferFunctionToDataRange (vtkSMProxy *proxy, const std::string &blockSelector, const char *arrayName, int attributeType, bool extend=false, bool force=true) |
static std::vector< vtkTypeBool > | RescaleBlocksTransferFunctionToDataRange (vtkSMProxy *proxy, const std::vector< std::string > &blockSelectors, const char *arrayName, int attributeType, bool extend=false, bool force=true) |
std::vector< vtkTypeBool > | RescaleSelectedTransferFunctionToDataRange (vtkSMProxy *proxy, const char *arrayName, int attributeType, bool extend=false, bool force=true) |
static bool | RescaleTransferFunctionToDataRangeOverTime (vtkSMProxy *proxy) |
Rescales the color transfer function and opacity transfer function using the current data range over time. More... | |
static bool | RescaleBlockTransferFunctionToDataRangeOverTime (vtkSMProxy *proxy, const std::string &blockSelector) |
static std::vector< vtkTypeBool > | RescaleBlocksTransferFunctionToDataRangeOverTime (vtkSMProxy *proxy, const std::vector< std::string > &blockSelectors) |
std::vector< vtkTypeBool > | RescaleSelectedTransferFunctionToDataRangeOverTime (vtkSMProxy *proxy) |
static bool | RescaleTransferFunctionToDataRangeOverTime (vtkSMProxy *proxy, const char *arrayName, int attributeType) |
Rescales the color transfer function and opacity transfer function using the current data range over time for the chosen data-array. More... | |
static bool | RescaleBlockTransferFunctionToDataRangeOverTime (vtkSMProxy *proxy, const std::string &blockSelector, const char *arrayName, int attributeType) |
static std::vector< vtkTypeBool > | RescaleBlocksTransferFunctionToDataRangeOverTime (vtkSMProxy *proxy, const std::vector< std::string > &blockSelectors, const char *arrayName, int attributeType) |
std::vector< vtkTypeBool > | RescaleSelectedTransferFunctionToDataRangeOverTime (vtkSMProxy *proxy, const char *arrayName, int attributeType) |
static bool | SetScalarBarVisibility (vtkSMProxy *proxy, vtkSMProxy *view, bool visible) |
Set the scalar bar visibility. More... | |
static bool | SetBlockScalarBarVisibility (vtkSMProxy *proxy, vtkSMProxy *view, const std::string &blockSelector, bool visible) |
static std::vector< vtkTypeBool > | SetBlocksScalarBarVisibility (vtkSMProxy *proxy, vtkSMProxy *view, const std::vector< std::string > &blockSelectors, bool visible) |
std::vector< vtkTypeBool > | SetSelectedScalarBarVisibility (vtkSMProxy *proxy, vtkSMProxy *view, bool visible) |
static int | GetEstimatedNumberOfAnnotationsOnScalarBar (vtkSMProxy *proxy, vtkSMProxy *view) |
Get an estimated number of annotation shown on this representation scalar bar. More... | |
static int | GetBlockEstimatedNumberOfAnnotationsOnScalarBar (vtkSMProxy *proxy, vtkSMProxy *view, const std::string &blockSelector) |
static std::vector< int > | GetBlocksEstimatedNumberOfAnnotationsOnScalarBars (vtkSMProxy *proxy, vtkSMProxy *view, const std::vector< std::string > &blockSelectors) |
std::vector< int > | GetSelectedEstimatedNumberOfAnnotationsOnScalarBars (vtkSMProxy *proxy, vtkSMProxy *view) |
int | GetAnySelectedEstimatedNumberOfAnnotationsOnScalarBar (vtkSMProxy *proxy, vtkSMProxy *view) |
static bool | IsColorValid (Color color) |
Set/Get the color of the representation. More... | |
static void | SetColor (vtkSMProxy *proxy, Color color) |
static void | SetBlockColor (vtkSMProxy *proxy, const std::string &blockSelector, Color color) |
static void | SetBlocksColor (vtkSMProxy *proxy, const std::vector< std::string > &blockSelectors, Color color) |
static void | RemoveBlockColor (vtkSMProxy *proxy, const std::string &blockSelector) |
static void | RemoveBlocksColors (vtkSMProxy *proxy, const std::vector< std::string > &blockSelectors) |
static Color | GetColor (vtkSMProxy *proxy) |
static Color | GetBlockColor (vtkSMProxy *proxy, const std::string &blockSelector) |
static std::vector< Color > | GetBlocksColors (vtkSMProxy *proxy, const std::vector< std::string > &blockSelectors) |
void | SetSelectedColor (vtkSMProxy *proxy, Color color) |
std::vector< Color > | GetSelectedColors (vtkSMProxy *proxy) |
static vtkSMProperty * | GetColorArrayProperty (vtkSMProxy *proxy) |
Get Color array property. More... | |
static vtkSMProperty * | GetBlockColorArrayProperty (vtkSMProxy *proxy) |
vtkSMProperty * | GetSelectedColorArrayProperty (vtkSMProxy *proxy) |
static bool | IsColorArrayValid (const ColorArray &array) |
Get the color array name. More... | |
static std::vector< ColorArray > | GetBlocksColorArrays (vtkSMProxy *proxy, const std::vector< std::string > &blockSelectors) |
static int | GetBlockColorArrayAssociation (vtkSMProxy *proxy, const std::string &blockSelector) |
static std::string | GetBlockColorArrayName (vtkSMProxy *proxy, const std::string &blockSelector) |
static std::map< ColorArray, std::vector< std::string > > | GetCommonColorArraysBlockSelectors (vtkSMProxy *proxy, const std::vector< std::string > &blockSelectors) |
std::vector< ColorArray > | GetSelectedColorArrays (vtkSMProxy *proxy) |
static vtkSMProperty * | GetUseSeparateColorMapProperty (vtkSMProxy *proxy) |
Get use separate color map property. More... | |
static vtkSMProperty * | GetBlockUseSeparateColorMapProperty (vtkSMProxy *proxy) |
vtkSMProperty * | GetSelectedUseSeparateColorMapProperty (vtkSMProxy *proxy) |
static bool | IsUseSeparateColorMapValid (int useSeparateColorMap) |
Set/Get if we should use a separate color map. More... | |
static void | SetUseSeparateColorMap (vtkSMProxy *proxy, bool use) |
static void | SetBlockUseSeparateColorMap (vtkSMProxy *proxy, const std::string &blockSelector, bool use) |
static void | SetBlocksUseSeparateColorMap (vtkSMProxy *proxy, const std::vector< std::string > &blockSelectors, bool use) |
static void | RemoveBlockUseSeparateColorMap (vtkSMProxy *proxy, const std::string &blockSelector) |
static void | RemoveBlocksUseSeparateColorMaps (vtkSMProxy *proxy, const std::vector< std::string > &blockSelectors) |
static bool | GetUseSeparateColorMap (vtkSMProxy *proxy) |
static int | GetBlockUseSeparateColorMap (vtkSMProxy *proxy, const std::string &blockSelector) |
static std::vector< int > | GetBlocksUseSeparateColorMaps (vtkSMProxy *proxy, const std::vector< std::string > &blockSelectors) |
void | SetSelectedUseSeparateColorMap (vtkSMProxy *proxy, bool use) |
std::vector< int > | GetSelectedUseSeparateColorMaps (vtkSMProxy *proxy) |
bool | GetAnySelectedUseSeparateColorMap (vtkSMProxy *proxy) |
static bool | IsMapScalarsValid (int mapScalars) |
Set/Get the map scalars of the representation. More... | |
static void | SetMapScalars (vtkSMProxy *proxy, bool mapScalars) |
static void | SetBlockMapScalars (vtkSMProxy *proxy, const std::string &blockSelector, bool mapScalars) |
static void | SetBlocksMapScalars (vtkSMProxy *proxy, const std::vector< std::string > &blockSelectors, bool mapScalars) |
static void | RemoveBlockMapScalars (vtkSMProxy *proxy, const std::string &blockSelector) |
static void | RemoveBlocksMapScalars (vtkSMProxy *proxy, const std::vector< std::string > &blockSelectors) |
static bool | GetMapScalars (vtkSMProxy *proxy) |
static int | GetBlockMapScalars (vtkSMProxy *proxy, const std::string &blockSelector) |
static std::vector< int > | GetBlocksMapScalars (vtkSMProxy *proxy, const std::vector< std::string > &blockSelectors) |
void | SetSelectedMapScalars (vtkSMProxy *proxy, bool mapScalars) |
std::vector< int > | GetSelectedMapScalars (vtkSMProxy *proxy) |
bool | GetAnySelectedMapScalars (vtkSMProxy *proxy) |
static bool | IsInterpolateScalarsBeforeMappingValid (int interpolate) |
static void | SetInterpolateScalarsBeforeMapping (vtkSMProxy *proxy, bool interpolate) |
static void | SetBlockInterpolateScalarsBeforeMapping (vtkSMProxy *proxy, const std::string &blockSelector, bool interpolate) |
static void | SetBlocksInterpolateScalarsBeforeMapping (vtkSMProxy *proxy, const std::vector< std::string > &blockSelectors, bool interpolate) |
static void | RemoveBlockInterpolateScalarsBeforeMapping (vtkSMProxy *proxy, const std::string &blockSelector) |
static void | RemoveBlocksInterpolateScalarsBeforeMappings (vtkSMProxy *proxy, const std::vector< std::string > &blockSelectors) |
static bool | GetInterpolateScalarsBeforeMapping (vtkSMProxy *proxy) |
static int | GetBlockInterpolateScalarsBeforeMapping (vtkSMProxy *proxy, const std::string &blockSelector) |
static std::vector< int > | GetBlocksInterpolateScalarsBeforeMappings (vtkSMProxy *proxy, const std::vector< std::string > &blockSelectors) |
void | SetSelectedInterpolateScalarsBeforeMapping (vtkSMProxy *proxy, bool interpolate) |
std::vector< int > | GetSelectedInterpolateScalarsBeforeMappings (vtkSMProxy *proxy) |
bool | GetAnySelectedInterpolateScalarsBeforeMapping (vtkSMProxy *proxy) |
static bool | IsOpacityValid (double opacity) |
Set/Get the opacity of the representation. More... | |
static void | SetOpacity (vtkSMProxy *proxy, double opacity) |
static void | SetBlockOpacity (vtkSMProxy *proxy, const std::string &blockSelector, double opacity) |
static void | SetBlocksOpacity (vtkSMProxy *proxy, const std::vector< std::string > &blockSelectors, double opacity) |
static void | RemoveBlockOpacity (vtkSMProxy *proxy, const std::string &blockSelector) |
static void | RemoveBlocksOpacities (vtkSMProxy *proxy, const std::vector< std::string > &blockSelectors) |
static double | GetOpacity (vtkSMProxy *proxy) |
static double | GetBlockOpacity (vtkSMProxy *proxy, const std::string &blockSelector) |
static std::vector< double > | GetBlocksOpacities (vtkSMProxy *proxy, const std::vector< std::string > &blockSelectors) |
void | SetSelectedOpacity (vtkSMProxy *proxy, double opacity) |
std::vector< double > | GetSelectedOpacities (vtkSMProxy *proxy) |
bool | Debug |
vtkTimeStamp | MTime |
It provides helper functions for controlling transfer functions, scalar coloring, etc. Scalar bar controlling is still working for RenderView only for now, as it's controlling the widget.
Definition at line 33 of file vtkSMColorMapEditorHelper.h.
Definition at line 37 of file vtkSMColorMapEditorHelper.h.
using vtkSMColorMapEditorHelper::Color = std::array<double, 3> |
Definition at line 498 of file vtkSMColorMapEditorHelper.h.
using vtkSMColorMapEditorHelper::ColorArray = std::pair<int, std::string> |
Definition at line 538 of file vtkSMColorMapEditorHelper.h.
Enumerator | |
Representation | |
Blocks |
Definition at line 40 of file vtkSMColorMapEditorHelper.h.
enum vtkSMColorMapEditorHelper::BlockPropertyState : std::uint8_t |
Enumerator | |
Disabled | |
RepresentationInherited | |
BlockInherited | |
MixedInherited | |
Set | |
SetAndRepresentationInherited | |
SetAndBlockInherited | |
SetAndMixedInherited | |
NumberOfStates |
Definition at line 46 of file vtkSMColorMapEditorHelper.h.
This variable is used in all instance functions with the Selected key-word in the name.
It decides whether to use a function that uses the representation's or blocks' properties.
Default is false.
Default is false.
Definition at line 80 of file vtkSMColorMapEditorHelper.h.
Default is false.
Definition at line 84 of file vtkSMColorMapEditorHelper.h.
Default is false.
if it's RepresentationInherited, the blockSelector will be empty. if it's BlockInherited, the blockSelector will be the inherited block. if it's MixedInherited, the blockSelector will be the inherited block. if it's Set, the block selector will be the block where the property is set. if it's SetAndRepresentationInherited, be the block where the property is set. if it's SetAndBlockInherited, be the block where the property is set. if it's SetAndMixedInherited, be the block where the property is set.
inlinestatic |
The methods with a view
parameter will return nullptr
if the view is not a render view.
Definition at line 138 of file vtkSMColorMapEditorHelper.h.
inlinestatic |
Definition at line 144 of file vtkSMColorMapEditorHelper.h.
inlinestatic |
Definition at line 150 of file vtkSMColorMapEditorHelper.h.
std::vector<vtkSMProxy*> vtkSMColorMapEditorHelper::GetSelectedLookupTables | ( | vtkSMProxy * | proxy | ) |
std::vector<vtkSMProxy*> vtkSMColorMapEditorHelper::GetSelectedLookupTables | ( | vtkSMProxy * | proxy, |
vtkSMProxy * | view | ||
This checks whether a property named "ColorArrayName" exists and has a non-empty string. This does not check for the validity of the array.
inlinestatic |
Definition at line 168 of file vtkSMColorMapEditorHelper.h.
std::vector<vtkTypeBool> vtkSMColorMapEditorHelper::GetSelectedUsingScalarColorings | ( | vtkSMProxy * | proxy | ) |
bool vtkSMColorMapEditorHelper::GetAnySelectedUsingScalarColoring | ( | vtkSMProxy * | proxy | ) |
If deleteRange is true, then the range stored for current representation proxy is deleted. This should be done when the scalar bar gets separated or becomes not visible. If deleteRange is false, then the range stored for current representation proxy is updated with the new range value.
This will set up a color and opacity transfer functions using vtkSMTransferFunctionProxy instance. If arrayName is nullptr, then scalar coloring is turned off. attributeType
must be one of vtkDataObject::AttributeTypes.
inlinestatic |
Definition at line 210 of file vtkSMColorMapEditorHelper.h.
std::vector<vtkTypeBool> vtkSMColorMapEditorHelper::SetSelectedScalarColoring | ( | vtkSMProxy * | proxy, |
const char * | arrayName, | ||
int | attributeType | ||
must be one of vtkDataObject::AttributeTypes. component
enables choosing a component to color with, -1 will change to Magnitude, >=0 will change to corresponding component.
inlinestatic |
Definition at line 234 of file vtkSMColorMapEditorHelper.h.
int | attributeType, | ||
int | component | ||
Returns true if rescale was successful. If extend
is true (false by default), the transfer function range will only be extended as needed to fit the data range. If force
is false (true by default), then the transfer function range is not changed if locked.
inlinestatic |
Definition at line 259 of file vtkSMColorMapEditorHelper.h.
std::vector<vtkTypeBool> vtkSMColorMapEditorHelper::RescaleSelectedTransferFunctionToDataRange | ( | vtkSMProxy * | proxy, |
bool | extend = false , |
bool | force = true |
Returns true if rescale was successful. attributeType
must be one of vtkDataObject::AttributeTypes. If extend
inlinestatic |
Definition at line 285 of file vtkSMColorMapEditorHelper.h.
inlinestatic |
Definition at line 306 of file vtkSMColorMapEditorHelper.h.
std::vector<vtkTypeBool> vtkSMColorMapEditorHelper::RescaleSelectedTransferFunctionToDataRangeOverTime | ( | vtkSMProxy * | proxy | ) |
must be one of vtkDataObject::AttributeTypes,
inlinestatic |
Definition at line 327 of file vtkSMColorMapEditorHelper.h.
std::vector<vtkTypeBool> vtkSMColorMapEditorHelper::RescaleSelectedTransferFunctionToDataRangeOverTime | ( | vtkSMProxy * | proxy, |
This will create a new scalar bar as needed. Scalar bar is only shown if scalar coloring is indeed being used.
inlinestatic |
Definition at line 357 of file vtkSMColorMapEditorHelper.h.
std::vector<vtkTypeBool> vtkSMColorMapEditorHelper::SetSelectedScalarBarVisibility | ( | vtkSMProxy * | proxy, |
vtkSMProxy * | view, | ||
bool | visible | ||
Use this method instead to only hide the scalar/color bar if no other visible representation in the view is mapping data using the scalar bar.
Return true if the scalar bar for this representation and view is visible, return false otherwise.
inlinestatic |
Definition at line 388 of file vtkSMColorMapEditorHelper.h.
If checkRepresentedData is true, it will also check in the represented data. Default is true. If none is found, returns nullptr.
inlinestatic |
Definition at line 406 of file vtkSMColorMapEditorHelper.h.
inlinestatic |
Definition at line 423 of file vtkSMColorMapEditorHelper.h.
Otherwise returns nullptr.
inlinestatic |
Definition at line 442 of file vtkSMColorMapEditorHelper.h.
If the return value is -1, then the value is not set.
inlinestatic |
Definition at line 463 of file vtkSMColorMapEditorHelper.h.
std::vector<int> vtkSMColorMapEditorHelper::GetSelectedEstimatedNumberOfAnnotationsOnScalarBars | ( | vtkSMProxy * | proxy, |
int vtkSMColorMapEditorHelper::GetAnySelectedEstimatedNumberOfAnnotationsOnScalarBar | ( | vtkSMProxy * | proxy, |
should be visible whenever this representation is also visible. It returns 1 if the scalar bar is sticky visible, 0 other wise. If any problem is encountered, for example if view == nullptr, or if the scalar bar representation is not instantiated / found, it returns -1.
inlinestatic |
Definition at line 488 of file vtkSMColorMapEditorHelper.h.
IsColorValid
to check if the returned value is valid/set.
IsColorValid
inlinestatic |
IsColorValid
to check if the returned value is valid/set. Definition at line 507 of file vtkSMColorMapEditorHelper.h.
IsColorValid
inlinestatic |
IsColorValid
to check if the returned value is valid/set. Definition at line 513 of file vtkSMColorMapEditorHelper.h.
IsColorValid
to check if the returned value is valid/set. void vtkSMColorMapEditorHelper::SetSelectedColor | ( | vtkSMProxy * | proxy, |
Color | color | ||
IsColorValid
IsColorValid
inlinestatic |
IsColorValid
to check if the returned value is valid/set. Definition at line 520 of file vtkSMColorMapEditorHelper.h.
IsColorValid
to check if the returned value is valid/set. std::vector<Color> vtkSMColorMapEditorHelper::GetSelectedColors | ( | vtkSMProxy * | proxy | ) |
IsColorValid
vtkSMProperty* vtkSMColorMapEditorHelper::GetSelectedColorArrayProperty | ( | vtkSMProxy * | proxy | ) |
IsColorArrayValid
IsColorArrayValid
inlinestatic |
IsColorArrayValid
to check if the returned value is valid/set. Definition at line 548 of file vtkSMColorMapEditorHelper.h.
inlinestatic |
IsColorArrayValid
to check if the returned value is valid/set. Definition at line 552 of file vtkSMColorMapEditorHelper.h.
IsColorArrayValid
to check if the returned value is valid/set. std::vector<ColorArray> vtkSMColorMapEditorHelper::GetSelectedColorArrays | ( | vtkSMProxy * | proxy | ) |
IsColorArrayValid
vtkSMProperty* vtkSMColorMapEditorHelper::GetSelectedUseSeparateColorMapProperty | ( | vtkSMProxy * | proxy | ) |
inlinestatic |
to check if the returned value is valid/set. Definition at line 578 of file vtkSMColorMapEditorHelper.h.
inlinestatic |
to check if the returned value is valid/set. Definition at line 585 of file vtkSMColorMapEditorHelper.h.
to check if the returned value is valid/set. void vtkSMColorMapEditorHelper::SetSelectedUseSeparateColorMap | ( | vtkSMProxy * | proxy, |
bool | use | ||
inlinestatic |
to check if the returned value is valid/set. Definition at line 593 of file vtkSMColorMapEditorHelper.h.
to check if the returned value is valid/set. std::vector<int> vtkSMColorMapEditorHelper::GetSelectedUseSeparateColorMaps | ( | vtkSMProxy * | proxy | ) |
to check if the returned value is valid/set. bool vtkSMColorMapEditorHelper::GetAnySelectedUseSeparateColorMap | ( | vtkSMProxy * | proxy | ) |
IsMapScalarsValid
IsMapScalarsValid
inlinestatic |
IsMapScalarsValid
to check if the returned value is valid/set. Definition at line 612 of file vtkSMColorMapEditorHelper.h.
IsMapScalarsValid
inlinestatic |
IsMapScalarsValid
to check if the returned value is valid/set. Definition at line 619 of file vtkSMColorMapEditorHelper.h.
IsMapScalarsValid
to check if the returned value is valid/set. void vtkSMColorMapEditorHelper::SetSelectedMapScalars | ( | vtkSMProxy * | proxy, |
bool | mapScalars | ||
IsMapScalarsValid
IsMapScalarsValid
inlinestatic |
IsMapScalarsValid
to check if the returned value is valid/set. Definition at line 627 of file vtkSMColorMapEditorHelper.h.
IsMapScalarsValid
to check if the returned value is valid/set. std::vector<int> vtkSMColorMapEditorHelper::GetSelectedMapScalars | ( | vtkSMProxy * | proxy | ) |
IsMapScalarsValid
to check if the returned value is valid/set. bool vtkSMColorMapEditorHelper::GetAnySelectedMapScalars | ( | vtkSMProxy * | proxy | ) |
IsMapScalarsValid
inlinestatic |
to check if the returned value is valid/set. Definition at line 645 of file vtkSMColorMapEditorHelper.h.
inlinestatic |
to check if the returned value is valid/set. Definition at line 653 of file vtkSMColorMapEditorHelper.h.
to check if the returned value is valid/set. void vtkSMColorMapEditorHelper::SetSelectedInterpolateScalarsBeforeMapping | ( | vtkSMProxy * | proxy, |
bool | interpolate | ||
inlinestatic |
to check if the returned value is valid/set. Definition at line 663 of file vtkSMColorMapEditorHelper.h.
to check if the returned value is valid/set. std::vector<int> vtkSMColorMapEditorHelper::GetSelectedInterpolateScalarsBeforeMappings | ( | vtkSMProxy * | proxy | ) |
to check if the returned value is valid/set. bool vtkSMColorMapEditorHelper::GetAnySelectedInterpolateScalarsBeforeMapping | ( | vtkSMProxy * | proxy | ) |
IsOpacityValid
IsOpacityValid
inlinestatic |
IsOpacityValid
to check if the returned value is valid/set. Definition at line 684 of file vtkSMColorMapEditorHelper.h.
IsOpacityValid
inlinestatic |
IsOpacityValid
to check if the returned value is valid/set. Definition at line 690 of file vtkSMColorMapEditorHelper.h.
IsOpacityValid
to check if the returned value is valid/set. void vtkSMColorMapEditorHelper::SetSelectedOpacity | ( | vtkSMProxy * | proxy, |
double | opacity | ||
IsOpacityValid
IsOpacityValid
inlinestatic |
IsOpacityValid
to check if the returned value is valid/set. Definition at line 698 of file vtkSMColorMapEditorHelper.h.
IsOpacityValid
to check if the returned value is valid/set. std::vector<double> vtkSMColorMapEditorHelper::GetSelectedOpacities | ( | vtkSMProxy * | proxy | ) |
IsOpacityValid
inlinestatic |
Definition at line 711 of file vtkSMColorMapEditorHelper.h.
inlinestatic |
Definition at line 716 of file vtkSMColorMapEditorHelper.h.
inlinestatic |
Definition at line 721 of file vtkSMColorMapEditorHelper.h.
staticprotected |
inlinestaticprotected |
Definition at line 741 of file vtkSMColorMapEditorHelper.h.
staticprotected |
staticprotected |
Definition at line 759 of file vtkSMColorMapEditorHelper.h.
staticprotected |
Definition at line 767 of file vtkSMColorMapEditorHelper.h.
staticprotected |
staticprotected |
Definition at line 774 of file vtkSMColorMapEditorHelper.h.
Definition at line 784 of file vtkSMColorMapEditorHelper.h.
staticprotected |
Definition at line 791 of file vtkSMColorMapEditorHelper.h.
staticprotected |
staticprotected |
staticprotected |
staticprotected |
This is used in UpdateScalarBarRange
to update the scalar bar range when turning off the coloring for this representation.
staticprotected |
Definition at line 819 of file vtkSMColorMapEditorHelper.h.
staticprotected |
Definition at line 825 of file vtkSMColorMapEditorHelper.h.
staticprotected |
friend |
Definition at line 834 of file vtkSMColorMapEditorHelper.h.
