virtual void | SetFileDescription (const char *) |
virtual char * | GetFileDescription () |
virtual void | SetFileExtension (const char *) |
virtual char * | GetFileExtension () |
virtual const char * | GetWriterVersion () |
| Return the writer version string. More...
virtual int | WriteConfiguration (ostream &os) |
| Write the proxy's state to a stream, in PV state format. More...
virtual void | SetProxy (vtkSMProxy *proxy) |
| Set the proxy to write out. More...
virtual vtkSMProxy * | GetProxy () |
virtual void | SetPropertyIterator (vtkSMPropertyIterator *iter) |
| Set the ieterator used to traverse properties during the write. More...
virtual vtkSMPropertyIterator * | GetPropertyIterator () |
virtual void | SetFileName (const char *) |
| Set/Get the file name. More...
virtual char * | GetFileName () |
virtual void | SetFileIdentifier (const char *) |
| Set/get file meta data. More...
virtual char * | GetFileIdentifier () |
virtual int | WriteConfiguration () |
| Write the proxy's state directly to an XML file, in PV state format. More...
virtual int | WriteConfiguration (const char *fileName) |
virtual void | Modified () |
