pqCoordinateFramePropertyWidget.h
4 #ifndef pqCoordinateFramePropertyWidget_h
5 #define pqCoordinateFramePropertyWidget_h
6
29 {
30  Q_OBJECT
31  Q_PROPERTY(int lockedAxis READ getLockedAxis WRITE setLockedAxis NOTIFY lockedAxisChangedByUser)
33
34 public:
36  vtkSMProxy* proxy, vtkSMPropertyGroup* smgroup, QWidget* parent = nullptr);
38
42  int getLockedAxis() const;
43  void setLockedAxis(int lockedAxis);
45 public Q_SLOTS: // NOLINT(readability-redundant-access-specifiers)
49  void useXNormal() { this->setNormal(1, 0, 0); }
50
54  void useYNormal() { this->setNormal(0, 1, 0); }
55
59  void useZNormal() { this->setNormal(0, 0, 1); }
60
64  void resetToWorldXYZ();
65
69  void resetToDataBounds();
70
74  void resetCameraToNormal();
75
79  void useCameraNormal();
80
84  void setUserXAxis();
85  void setUserYAxis();
86  void setUserZAxis();
87
88 protected Q_SLOTS:
92  void placeWidget() override;
93
94 private Q_SLOTS:
95  void setOrigin(double x, double y, double z);
96  void setNormal(double x, double y, double z);
97  void setDirection(double x, double y, double z);
98  void currentIndexChangedLockAxis(int);
99
100 protected:
101  void setUserAxis(int axis);
102
103 Q_SIGNALS:
104  // Note this reports a lock axis (-1, 0, 1, or 2), not a combo-box index (0, 1, 2, 3)
105  void lockedAxisChangedByUser(int);
106
107 private:
108  Q_DISABLE_COPY(pqCoordinateFramePropertyWidget)
109 };
110
111 #endif
pqCoordinateFramePropertyWidget is a custom property widget that uses "CoordinateFrameWidgetRepresent...
void useXNormal()
Set the widget normal to be along the X axis.
#define PQAPPLICATIONCOMPONENTS_EXPORT
void useZNormal()
Set the widget normal to be along the Z axis.
Definition: vtkSMProxy.h:140
virtual void placeWidget()=0
Places the interactive widget using current data source information.
void useYNormal()
Set the widget normal to be along the Y axis.
pqInteractivePropertyWidget is an abstract pqPropertyWidget subclass designed to serve as the supercl...
