pqProxy.h
4
11 #ifndef pqProxy_h
12 #define pqProxy_h
13
15 #include <QPointer>
16
17 class pqProxyInternal;
18 class pqServer;
19 class vtkPVXMLElement;
20 class vtkSMProxy;
22
29 {
30  Q_OBJECT
31 public:
36  {
39  UNMODIFIED
40  };
41
42  pqProxy(const QString& group, const QString& name, vtkSMProxy* proxy, pqServer* server,
43  QObject* parent = nullptr);
44  ~pqProxy() override;
45
49  pqServer* getServer() const;
50
57  void rename(const QString& newname);
58
64  const QString& getSMName();
65  const QString& getSMGroup();
66
72  vtkSMProxy* getProxy() const;
73
80  ModifiedState modifiedState() const { return this->Modified; }
81
87  void setModifiedState(ModifiedState modified);
88
93  vtkPVXMLElement* getHints() const;
94
98  QList<vtkSMProxy*> getHelperProxies() const;
99
103  QList<vtkSMProxy*> getHelperProxies(const QString& key) const;
104
108  QList<QString> getHelperKeys() const;
109
111
114  static std::string rstToHtml(const char* rstStr);
115  static QString rstToHtml(const QString& rstStr);
117
128  virtual void addHelperProxy(const QString& key, vtkSMProxy*);
129  void removeHelperProxy(const QString& key, vtkSMProxy*);
130
136  void updateHelperProxies() const;
137
141  vtkSMSessionProxyManager* proxyManager() const;
142
148  static pqProxy* findProxyWithHelper(vtkSMProxy* aproxy, QString& key);
149
159  bool userModifiedSMName() { return this->UserModifiedSMName; }
160
161 Q_SIGNALS:
165  void nameChanged(pqServerManagerModelItem*);
166
170  void modifiedStateChanged(pqServerManagerModelItem*);
171
172 protected:
173  friend class pqServerManagerModel;
174
184  void setSMName(const QString& new_name);
185
186  // Use this method to initialize the pqObject state using the
187  // underlying vtkSMProxy. This needs to be done only once,
188  // after the object has been created.
189  virtual void initialize();
190
191  // Method used to update the internal structure without affecting
192  // the ProxyManager proxy registration
193  virtual void addInternalHelperProxy(const QString& key, vtkSMProxy*) const;
194  virtual void removeInternalHelperProxy(const QString& key, vtkSMProxy*) const;
195
196 protected Q_SLOTS: // NOLINT(readability-redundant-access-specifiers)
197  // Used to monitor helper proxy registration when created on other clients
198  void onProxyRegistered(const QString&, const QString&, vtkSMProxy*);
199  void onProxyUnRegistered(const QString&, const QString&, vtkSMProxy*);
200
201 private:
202  QPointer<pqServer> Server;
203  QString SMName;
204  QString SMGroup;
205  pqProxyInternal* Internal;
206  ModifiedState Modified;
207  bool UserModifiedSMName;
208 };
209
210 #endif
Return whether or not the user has modified the GUI name of the source.
Definition: pqProxy.h:159
ModifiedState
The modification state of this proxy.
Definition: pqProxy.h:35
pqServerManagerModelItem is a element maintained by pqServerManagerModel.
#define PQCORE_EXPORT
Definition: pqCoreModule.h:15
The vtkSMSessionProxyManager is esponsible for creating and managing proxies for a given session...
virtual void onProxyUnRegistered(const QString &group, const QString &name, vtkSMProxy *proxy)
Called when a proxy is unregistered.
This class represents any registered Server Manager proxy.
Definition: pqProxy.h:28
pqServerManagerModel is the model for the Server Manager.
Definition: vtkSMProxy.h:140
virtual void onProxyRegistered(const QString &group, const QString &name, vtkSMProxy *proxy)
Called when a proxy is registered.
Gets whether or not the source has been modified.
Definition: pqProxy.h:80
key
pqServer (should be renamed to pqSession) is a pqServerManagerModelItem subclass that represents a vt...
Definition: pqServer.h:35
