1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/Remoting/Animation 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Release")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
46 file(INSTALL DESTINATION
"vtkRemotingAnimation-hierarchy.txt" FILES
"/builds/gitlab-kitware-sciviz-ci/build/lib64/vtk/hierarchy/ParaView/vtkRemotingAnimation-hierarchy.txt")
51 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRemotingAnimation-pv6.0.so.6.0
" 52 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRemotingAnimation-pv6.0.so.1
" 54 if(EXISTS "${file}
") 58 RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
" TYPE SHARED_LIBRARY FILES 62 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkRemotingAnimation-pv6.0.so.6.0
" 63 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkRemotingAnimation-pv6.0.so.1
" 66 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRemotingAnimation-pv6.0.so.6.0
" 67 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRemotingAnimation-pv6.0.so.1
" 69 if(EXISTS "${file}
") 73 OLD_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib:
" 74 NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
" "${file}
" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkRemotingAnimation-pv6.0.so
" OR NOT CMAKE_INSTALL_COMPONENT) 90 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.0
" TYPE FILE FILES 102 "/builds/gitlab-kitware-sciviz-ci/Remoting/Animation/
vtkPVKeyFrame.h
" 125 if(CMAKE_INSTALL_COMPONENT STREQUAL "development
" OR NOT CMAKE_INSTALL_COMPONENT) 126 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.0
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/Remoting/Animation/vtkRemotingAnimationModule.h
") 129 if(CMAKE_INSTALL_COMPONENT STREQUAL "spdx
" OR NOT CMAKE_INSTALL_COMPONENT) 130 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/doc/ParaView/spdx
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/Remoting/Animation/vtkRemotingAnimation.spdx
") domain for animation frame window.
Abstract superclass for an animation player.
proxy for vtkAnimationCue.
proxy to save animation to images/video.
vtkPVKeyFrameAnimationCueForProxies extends vtkPVKeyFrameAnimationCue to update properties on proxies...
helper class to write animation geometry in a data file.
vtkSMAnimationSceneProxy observe vtkCommand::ModifiedEvent on the client-side VTK-object to call Upda...
helper proxy used to animate properties on the representations for any source.
Interplates lineraly between consecutive key frames.
animation manipulator that uses keyframes to generate the animation.
vtkSIXMLAnimationWriterRepresentationProperty extends vtkSIInputProperty to add push-API specific to ...
This is composite animation player that can me made to play an animation using the active player...
helper class used to write animations.
vtkPVKeyFrameAnimationCue is a specialization of vtkPVAnimationCue that uses the vtkPVKeyFrameCueMani...
helper class to write animation geometry in a web archive.
Special key frame for animating Camera.
animation scene for ParaView.
abstract proxy for manipulators used in animation.
Data writer for ParaView.
vtkPVCameraAnimationCue is a specialization of the vtkPVKeyFrameAnimationCue suitable for animating c...
Base class for key frames.
vtkAnimationPlayer subclass that plays through a discrete set of time values.
vtkPythonAnimationCue is an animation cue that can execute arbitrary Python scripts.
