virtual int | GetPortIndex () |
| Controls which input port this property uses when making connections. More...
virtual bool | GetNullOnEmpty () |
virtual char * | GetCleanCommand () |
| Command that can be used to remove inputs. More...
virtual char * | GetRemoveCommand () |
| Remove command is the command called to remove the VTK object on the server-side. More...
| The name assigned by the xml parser. More...
virtual char * | GetCommand () |
| The command name used to set the value on the server object. More...
virtual bool | GetInformationOnly () |
| Is InformationOnly is set to true, this property is used to get information from server instead of setting values. More...
virtual bool | GetRepeatable () |
| If repeatable, a property can have 1 or more values of the same kind. More...
virtual void | SetIsInternal (bool) |
| This ivar is configured when the xml file is read and is mainly useful to trigger a method call. More...
virtual bool | GetIsInternal () |
virtual void | Modified () |
| vtkSIXMLAnimationWriterRepresentationProperty () |
| ~vtkSIXMLAnimationWriterRepresentationProperty () override |
bool | Push (vtkSMMessage *, int) override |
| Overridden to call AddRepresentation on the vtkXMLPVAnimationWriter instance with correct API. More...
| vtkSIInputProperty () |
| ~vtkSIInputProperty () override |
| Push a new state to the underneath implementation. More...
bool | ReadXMLAttributes (vtkSIProxy *proxyhelper, vtkPVXMLElement *element) override |
| Parse the xml for the property. More...
virtual void | SetPortIndex (int) |
| vtkSIProxyProperty () |
| ~vtkSIProxyProperty () override |
virtual void | SetNullOnEmpty (bool) |
vtkObjectBase * | GetObjectBase (vtkTypeUInt32 globalId) |
bool | IsValidNull (vtkTypeUInt32 globalId) |
virtual void | SetCleanCommand (const char *) |
virtual void | SetRemoveCommand (const char *) |
| vtkSIProperty () |
| ~vtkSIProperty () override |
vtkSIObject * | GetSIObject (vtkTypeUInt32 globalid) |
| Convenience method to obtain a vtkSIObject subclass given its global id. More...
virtual bool | Pull (vtkSMMessage *) |
| Pull the current state of the underneath implementation. More...
virtual void | SetCommand (const char *) |
void | SaveValueToCache (vtkSMMessage *proxyStateUpdate, int offset) |
bool | ProcessMessage (vtkClientServerStream &stream) |
| Interprets the message. More...
const vtkClientServerStream & | GetLastResult () |
vtkObjectBase * | GetVTKObject () |
| vtkObject () |
virtual | ~vtkObject () |
| vtkObjectBase () |
virtual | ~vtkObjectBase () |
| vtkObjectBase (const vtkObjectBase &) |
vtkSIXMLAnimationWriterRepresentationProperty extends vtkSIInputProperty to add push-API specific to vtkXMLPVAnimationWriter to add representations while assigning them unique names consistently across all processes.
Definition at line 17 of file vtkSIXMLAnimationWriterRepresentationProperty.h.
