ServerSide Property use to set Object array as method argument. More...
#include <vtkSIProxyProperty.h>
| virtual bool | GetNullOnEmpty () |
| Command that can be used to remove inputs. More... | |
| virtual char * | GetRemoveCommand () |
| Remove command is the command called to remove the VTK object on the server-side. More... | |
| static vtkSIProxyProperty * | New () |
| static vtkSIProxyProperty * | SafeDownCast (vtkObject *o) |
Protected Types | |
| enum | TypeArg { VTK, SMProxy, SIProxy } |
| vtkSIProxyProperty () | |
| ~vtkSIProxyProperty () override | |
| bool | Push (vtkSMMessage *, int) override |
| bool | ReadXMLAttributes (vtkSIProxy *proxyhelper, vtkPVXMLElement *element) override |
| virtual void | SetNullOnEmpty (bool) |
| vtkObjectBase * | GetObjectBase (vtkTypeUInt32 globalId) |
| bool | IsValidNull (vtkTypeUInt32 globalId) |
| vtkSIProperty () | |
| virtual bool | Pull (vtkSMMessage *) |
Protected Attributes | |
| bool | NullOnEmpty |
| TypeArg | ArgumentType |
| char * | XMLName |
| char * | Command |
| bool | InformationOnly |
| bool | Repeatable |
| bool | IsInternal |
| char * | CleanCommand |
| char * | RemoveCommand |
| virtual void | SetRemoveCommand (const char *) |
Those object could be either SMProxy instance or their SIProxy instance or the VTK object managed by the SIProxy instance. The type of object is specified inside the XML definition of the property with the attribute argument_type=[VTK, SMProxy, SIProxy].
Definition at line 19 of file vtkSIProxyProperty.h.
Definition at line 23 of file vtkSIProxyProperty.h.
| Enumerator | |
| VTK | |
| SMProxy | |
| SIProxy | |
Definition at line 91 of file vtkSIProxyProperty.h.
Reimplemented in vtkSIXMLAnimationWriterRepresentationProperty, and vtkSIInputProperty.
If set, this command is called before the main Command is called with all the arguments.
If set, CleanCommand is ignored. Instead for every proxy that was absent from the proxies previously pushed, the RemoveCommand is invoked.
overrideprotectedvirtual |
Parse the xml for the property.
protectedvirtual |
protectedvirtual |
protectedvirtual |
Definition at line 70 of file vtkSIProxyProperty.h.
Definition at line 81 of file vtkSIProxyProperty.h.
Definition at line 88 of file vtkSIProxyProperty.h.
Definition at line 102 of file vtkSIProxyProperty.h.
1.8.13 on Sun Dec 14 2025
