ServerSide Property use to set vtkOutputPort as method parameter. More...
#include <vtkSIInputProperty.h>
| typedef vtkSIProxyProperty | Superclass |
Public Types inherited from vtkSIProxyProperty | |
| virtual int | GetPortIndex () |
| Controls which input port this property uses when making connections. More... | |
Public Member Functions inherited from vtkSIProxyProperty | |
| virtual bool | GetNullOnEmpty () |
| Command that can be used to remove inputs. More... | |
| virtual char * | GetRemoveCommand () |
| Remove command is the command called to remove the VTK object on the server-side. More... | |
| static vtkSIInputProperty * | New () |
| static vtkSIInputProperty * | SafeDownCast (vtkObject *o) |
Static Public Member Functions inherited from vtkSIProxyProperty | |
| static vtkSIProxyProperty * | New () |
| static vtkSIProxyProperty * | SafeDownCast (vtkObject *o) |
| vtkSIInputProperty () | |
| ~vtkSIInputProperty () override | |
| bool | Push (vtkSMMessage *, int) override |
| bool | ReadXMLAttributes (vtkSIProxy *proxyhelper, vtkPVXMLElement *element) override |
| virtual void | SetPortIndex (int) |
Protected Member Functions inherited from vtkSIProxyProperty | |
| vtkSIProxyProperty () | |
| ~vtkSIProxyProperty () override | |
| virtual void | SetNullOnEmpty (bool) |
| vtkObjectBase * | GetObjectBase (vtkTypeUInt32 globalId) |
| bool | IsValidNull (vtkTypeUInt32 globalId) |
| virtual void | SetRemoveCommand (const char *) |
| vtkSIProperty () | |
| virtual bool | Pull (vtkSMMessage *) |
Protected Attributes | |
| int | PortIndex |
Protected Attributes inherited from vtkSIProxyProperty | |
| bool | NullOnEmpty |
| TypeArg | ArgumentType |
| char * | CleanCommand |
| char * | RemoveCommand |
| char * | XMLName |
| char * | Command |
| bool | InformationOnly |
| bool | Repeatable |
| bool | IsInternal |
Protected Types inherited from vtkSIProxyProperty | |
| enum | TypeArg { VTK, SMProxy, SIProxy } |
For that we need the object on which we should get the Port and its port number.
Definition at line 17 of file vtkSIInputProperty.h.
Definition at line 21 of file vtkSIInputProperty.h.
Reimplemented from vtkSIProxyProperty.
Reimplemented in vtkSIXMLAnimationWriterRepresentationProperty.
By default, this is 0.
overrideprotectedvirtual |
Parse the xml for the property.
protectedvirtual |
Definition at line 46 of file vtkSIInputProperty.h.
1.8.13 on Sun Dec 14 2025
