This component is used by pqLiveSourceManager to interact with the underlying proxy of the LiveSource. More...
#include <pqLiveSourceItem.h>
Inherits QObject.
Signals | |
| void | refreshSource () |
| Triggered when the internal refresh timer timeout. More... | |
| void | onInformationUpdated () |
| Triggered when the proxy information are updated. More... | |
| void | stateChanged (bool isPaused) |
| Triggered when the live source is paused / resumed. More... | |
| pqLiveSourceItem (pqPipelineSource *src, vtkPVXMLElement *liveHints, QObject *parent=nullptr) | |
| ~pqLiveSourceItem () override | |
| void | update (double time) |
Calls GetNeedsUpdate on the associated vtkAlgorithm proxy. More... | |
| bool | isPaused () |
| Returns true if is currently paused. More... | |
| double * | getTimestampRange () |
| If the LiveSource is an EmulatedTimeAlgorithm, return the first and last proxy timestamp, else return nullptr. More... | |
| bool | isEmulatedTimeAlgorithm () |
Return true is the LiveSource XML tag has a emulated_time attribute to true. More... | |
| vtkTypeUInt32 | getSourceId () |
| Get underlying proxy global ID. More... | |
| void | pause () |
| Pause / Resume live updates for this source. More... | |
| void | resume () |
Each pqLiveSourceItem have a pqTimer that periodically emit the refreshSource signal, which is monitored by pqLiveSourceManager. Upon receiving this signal, it triggers the update function, which in turn invokes GetNeedsUpdate on the proxy.
If the LiveSource is an emulated time algorithm (with the emulated_time XML attribute), the pqLiveSourceManager will call the update function with a synchronized "real" time among all live sources.
Definition at line 32 of file pqLiveSourceItem.h.
| pqLiveSourceItem::pqLiveSourceItem | ( | pqPipelineSource * | src, |
| vtkPVXMLElement * | liveHints, | ||
| QObject * | parent = nullptr |
| void pqLiveSourceItem::update | ( | double | time | ) |
If the LiveSource is a EmulatedTimeAlgorithm send time as a parameter.
| void pqLiveSourceItem::pause | ( | ) |
| void pqLiveSourceItem::resume | ( | ) |
| bool pqLiveSourceItem::isPaused | ( | ) |
| double* pqLiveSourceItem::getTimestampRange | ( | ) |
| bool pqLiveSourceItem::isEmulatedTimeAlgorithm | ( | ) |
| vtkTypeUInt32 pqLiveSourceItem::getSourceId | ( | ) |
signal |
signal |
(Its time range could have been updated as well)
signal |
1.8.13 on Sun Dec 14 2025
