void | Update (vtkSMProperty *) override |
| Update the domain using the "unchecked" values (if available) for all required properties. More...
Public Member Functions inherited from vtkSMIntRangeDomain |
virtual int | GetMinimum (unsigned int idx, int &exists) |
| Return a min. More...
virtual int | GetMaximum (unsigned int idx, int &exists) |
| Return a max. More...
virtual int | GetMinimumExists (unsigned int idx) |
| Returns if minimum/maximum bound is set for the domain. More...
virtual int | GetMaximumExists (unsigned int idx) |
virtual int | GetMinimum (unsigned int idx) |
| Returns the minimum/maximum value, is exists, otherwise 0 is returned. More...
virtual int | GetMaximum (unsigned int idx) |
| Is the (unchecked) value of the property in the domain? Overwritten by sub-classes. More...
| Set the value of an element of a property from the animation editor. More...
| A vtkSMProperty is often defined with a default value in the XML itself. More...
| Provides access to the vtkSMProperty on which this domain is hooked up. More...
| Helper method to get the number of input connections hence the number of available vtkPVDataInformation from input proxy connected to the required property with the given function. More...
| Returns a given required property of the given function. More...
| When the IsOptional flag is set, IsInDomain() always returns true. More...
| Helper methods to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More...
virtual vtkPVDataInformation * | GetInputSubsetDataInformation (const char *selector, const char *assemblyName, const char *function, unsigned int index=0) |
virtual void | Modified () |
