type specific extension to vtkSMRangeDomainTemplate for ints. More...
#include <vtkSMIntRangeDomain.h>
typedef vtkSMDomain | Superclass |
enum | IsInDomainReturnCodes { NOT_APPLICABLE = -1, NOT_IN_DOMAIN = 0, IN_DOMAIN = 1 } |
virtual int | GetMinimum (unsigned int idx, int &exists) |
Return a min. More... | |
virtual int | GetMaximum (unsigned int idx, int &exists) |
Return a max. More... | |
virtual int | GetMinimumExists (unsigned int idx) |
Returns if minimum/maximum bound is set for the domain. More... | |
virtual int | GetMaximumExists (unsigned int idx) |
virtual int | GetMinimum (unsigned int idx) |
Returns the minimum/maximum value, is exists, otherwise 0 is returned. More... | |
virtual int | GetMaximum (unsigned int idx) |
Is the (unchecked) value of the property in the domain? Overwritten by sub-classes. More... | |
virtual void | Update (vtkSMProperty *requestingProperty) |
Update self based on the "unchecked" values of all required properties. More... | |
Set the value of an element of a property from the animation editor. More... | |
A vtkSMProperty is often defined with a default value in the XML itself. More... | |
Provides access to the vtkSMProperty on which this domain is hooked up. More... | |
Helper method to get the number of input connections hence the number of available vtkPVDataInformation from input proxy connected to the required property with the given function. More... | |
Returns a given required property of the given function. More... | |
When the IsOptional flag is set, IsInDomain() always returns true. More... | |
Helper methods to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More... | |
virtual vtkPVDataInformation * | GetInputSubsetDataInformation (const char *selector, const char *assemblyName, const char *function, unsigned int index=0) |
virtual void | Modified () |
static vtkSMIntRangeDomain * | New () |
static vtkSMIntRangeDomain * | SafeDownCast (vtkObject *o) |
static vtkSMDomain * | New () |
static vtkSMDomain * | SafeDownCast (vtkObject *o) |
static vtkObject * | New () |
vtkSMIntRangeDomain () | |
~vtkSMIntRangeDomain () override | |
vtkSMDomain () | |
~vtkSMDomain () override | |
Load the state of the domain from the XML. More... | |
virtual int | ReadXMLAttributes (vtkSMProperty *prop, vtkPVXMLElement *elem) |
Set the appropriate ivars from the xml element. More... | |
Remove the given property from the required properties list. More... | |
Add a new required property to this domain. More... | |
void | DomainModified () |
Invokes DomainModifiedEvent. More... | |
void | InvokeModified () |
Gets the number of required properties added. More... | |
Set the domain's property. More... | |
Add the header and creates a new vtkPVXMLElement for the domain, fills it up with the common attributes. More... | |
virtual void | ChildSaveState (vtkPVXMLElement *domainElement) |
vtkSMSessionObject () | |
vtkSMObject () | |
~vtkSMObject () override | |
vtkObject () | |
virtual | ~vtkObject () |
vtkObjectBase () | |
virtual | ~vtkObjectBase () |
char * | XMLName |
bool | IsOptional |
vtkSMDomainInternals * | Internals |
vtkWeakPointer< vtkSMSession > | Session |
Identifies the session id to which this object is related. More... | |
bool | Debug |
vtkTimeStamp | MTime |
vtkSMIntRangeDomain is a type specific extension to vtkSMRangeDomainTemplate for ints.
Definition at line 27 of file vtkSMIntRangeDomain.h.
Definition at line 34 of file vtkSMIntRangeDomain.h.
Reimplemented in vtkSMDimensionsDomain, vtkSMAMRLevelsDomain, vtkSMExtentDomain, vtkSMTimeStepIndexDomain, vtkSMAnimationFrameWindowDomain, and vtkSMViewResolutionDomain.
Reimplemented in vtkSMTimeStepIndexDomain, and vtkSMViewResolutionDomain.
Return a min.
value if it exists. If the min. exists exists is set to 1. Otherwise, it is set to 0. An unspecified min. is equivalent to -inf
Definition at line 42 of file vtkSMIntRangeDomain.h.
Return a max.
value if it exists. If the max. exists exists is set to 1. Otherwise, it is set to 0. An unspecified max. is equivalent to +inf
Definition at line 52 of file vtkSMIntRangeDomain.h.
Definition at line 60 of file vtkSMIntRangeDomain.h.
Definition at line 64 of file vtkSMIntRangeDomain.h.
Use GetMaximumExists() GetMaximumExists() to make sure that the bound is set.
Definition at line 74 of file vtkSMIntRangeDomain.h.
Definition at line 75 of file vtkSMIntRangeDomain.h.
