int range domain based on data set extent More...
#include <vtkSMExtentDomain.h>
typedef vtkSMIntRangeDomain | Superclass |
typedef vtkSMDomain | Superclass |
enum | IsInDomainReturnCodes { NOT_APPLICABLE = -1, NOT_IN_DOMAIN = 0, IN_DOMAIN = 1 } |
void | Update (vtkSMProperty *) override |
Update self checking the "unchecked" values of all required properties. More... | |
void | SetAnimationValue (vtkSMProperty *property, int idx, double value) override |
Set the value of an element of a property from the animation editor. More... | |
virtual int | GetMinimum (unsigned int idx, int &exists) |
Return a min. More... | |
virtual int | GetMaximum (unsigned int idx, int &exists) |
Return a max. More... | |
virtual int | GetMinimumExists (unsigned int idx) |
Returns if minimum/maximum bound is set for the domain. More... | |
virtual int | GetMaximumExists (unsigned int idx) |
virtual int | GetMinimum (unsigned int idx) |
Returns the minimum/maximum value, is exists, otherwise 0 is returned. More... | |
virtual int | GetMaximum (unsigned int idx) |
Is the (unchecked) value of the property in the domain? Overwritten by sub-classes. More... | |
A vtkSMProperty is often defined with a default value in the XML itself. More... | |
Provides access to the vtkSMProperty on which this domain is hooked up. More... | |
Helper method to get the number of input connections hence the number of available vtkPVDataInformation from input proxy connected to the required property with the given function. More... | |
Returns a given required property of the given function. More... | |
When the IsOptional flag is set, IsInDomain() always returns true. More... | |
Helper methods to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More... | |
virtual vtkPVDataInformation * | GetInputSubsetDataInformation (const char *selector, const char *assemblyName, const char *function, unsigned int index=0) |
virtual void | Modified () |
static vtkSMExtentDomain * | New () |
static vtkSMExtentDomain * | SafeDownCast (vtkObject *o) |
static vtkSMIntRangeDomain * | New () |
static vtkSMIntRangeDomain * | SafeDownCast (vtkObject *o) |
static vtkSMDomain * | New () |
static vtkSMDomain * | SafeDownCast (vtkObject *o) |
static vtkObject * | New () |
void | Update (vtkSMProxyProperty *pp) |
vtkSMIntRangeDomain () | |
~vtkSMIntRangeDomain () override | |
vtkSMDomain () | |
~vtkSMDomain () override | |
Load the state of the domain from the XML. More... | |
virtual int | ReadXMLAttributes (vtkSMProperty *prop, vtkPVXMLElement *elem) |
Set the appropriate ivars from the xml element. More... | |
Remove the given property from the required properties list. More... | |
Add a new required property to this domain. More... | |
void | DomainModified () |
Invokes DomainModifiedEvent. More... | |
void | InvokeModified () |
Gets the number of required properties added. More... | |
Set the domain's property. More... | |
Add the header and creates a new vtkPVXMLElement for the domain, fills it up with the common attributes. More... | |
virtual void | ChildSaveState (vtkPVXMLElement *domainElement) |
vtkSMSessionObject () | |
vtkSMObject () | |
~vtkSMObject () override | |
vtkObject () | |
virtual | ~vtkObject () |
vtkObjectBase () | |
virtual | ~vtkObjectBase () |
int | SetDefaultValues (vtkSMProperty *, bool use_unchecked_values) override |
vtkSMExtentDomain () | |
~vtkSMExtentDomain () override | |
char * | XMLName |
bool | IsOptional |
vtkSMDomainInternals * | Internals |
vtkWeakPointer< vtkSMSession > | Session |
Identifies the session id to which this object is related. More... | |
bool | Debug |
vtkTimeStamp | MTime |
vtkSMExtentDomain is a subclass of vtkSMIntRangeDomain. In its Update method, it determines the minimum and maximum extent in each dimension of the structured data set with which it is associated. It requires a vtkSMSourceProxy to do this.
Definition at line 23 of file vtkSMExtentDomain.h.
Definition at line 27 of file vtkSMExtentDomain.h.
However, many times, the default value must be determined at run time. To facilitate this, domains can override this method to compute and set the default value for the property. Note that unlike the compile-time default values, the application must explicitly call this method to initialize the property.
Reimplemented from vtkSMIntRangeDomain.
