double range domain based on data set bounds More...
#include <vtkSMBoundsDomain.h>
enum | Modes { NORMAL, MAGNITUDE, ORIENTED_MAGNITUDE, SCALED_EXTENT, ARRAY_SCALED_EXTENT, APPROXIMATE_CELL_LENGTH, DATA_BOUNDS, EXTENTS, COMPONENT_MAGNITUDE } |
SCALED_EXTENT: is used for vtkPVScaleFactorEntry. More... | |
enum | Axes { X_AXIS = 1, Y_AXIS = 2, Z_AXIS = 4, X_AND_Y_AXES = X_AXIS | Y_AXIS, Y_AND_Z_AXES = Y_AXIS | Z_AXIS, X_AND_Z_AXES = X_AXIS | Z_AXIS, X_Y_AND_Z_AXES = X_AXIS | Y_AXIS | Z_AXIS } |
typedef vtkSMDoubleRangeDomain | Superclass |
typedef vtkSMDomain | Superclass |
enum | IsInDomainReturnCodes { NOT_APPLICABLE = -1, NOT_IN_DOMAIN = 0, IN_DOMAIN = 1 } |
void | Update (vtkSMProperty *) override |
Update self checking the "unchecked" values of all required properties. More... | |
virtual double | GetScaleFactor () |
virtual int | GetAxisFlags () |
int | SetDefaultValues (vtkSMProperty *property, bool use_unchecked_values) override |
Overridden to handle APPROXIMATE_CELL_LENGTH. More... | |
virtual void | SetMode (int) |
virtual int | GetMode () |
virtual double | GetMinimum (unsigned int idx, int &exists) |
Return a min. More... | |
virtual double | GetMaximum (unsigned int idx, int &exists) |
Return a max. More... | |
virtual int | GetMinimumExists (unsigned int idx) |
Returns if minimum/maximum bound is set for the domain. More... | |
virtual int | GetMaximumExists (unsigned int idx) |
virtual double | GetMinimum (unsigned int idx) |
Returns the minimum/maximum value, is exists, otherwise 0 is returned. More... | |
virtual double | GetMaximum (unsigned int idx) |
virtual int | GetResolution () |
Returns the resolution. More... | |
Is the (unchecked) value of the property in the domain? Overwritten by sub-classes. More... | |
Set the value of an element of a property from the animation editor. More... | |
A vtkSMProperty is often defined with a default value in the XML itself. More... | |
Provides access to the vtkSMProperty on which this domain is hooked up. More... | |
Helper method to get the number of input connections hence the number of available vtkPVDataInformation from input proxy connected to the required property with the given function. More... | |
Returns a given required property of the given function. More... | |
When the IsOptional flag is set, IsInDomain() always returns true. More... | |
Helper methods to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More... | |
virtual vtkPVDataInformation * | GetInputSubsetDataInformation (const char *selector, const char *assemblyName, const char *function, unsigned int index=0) |
virtual void | Modified () |
static vtkSMBoundsDomain * | New () |
static vtkSMBoundsDomain * | SafeDownCast (vtkObject *o) |
static vtkSMDoubleRangeDomain * | New () |
static vtkSMDoubleRangeDomain * | SafeDownCast (vtkObject *o) |
static vtkSMDomain * | New () |
static vtkSMDomain * | SafeDownCast (vtkObject *o) |
static vtkObject * | New () |
vtkSMBoundsDomain () | |
~vtkSMBoundsDomain () override | |
int | ReadXMLAttributes (vtkSMProperty *prop, vtkPVXMLElement *element) override |
Set the appropriate ivars from the xml element. More... | |
vtkPVDataInformation * | GetInputInformation () |
vtkSMIntVectorProperty * | GetAxisFlagsInformation () |
bool | IsAxisEnabled (int axis) |
void | SetDomainValues (double bounds[6]) |
void | UpdateOriented () |
vtkSMDoubleRangeDomain () | |
~vtkSMDoubleRangeDomain () override | |
vtkSMDomain () | |
~vtkSMDomain () override | |
Load the state of the domain from the XML. More... | |
Remove the given property from the required properties list. More... | |
Add a new required property to this domain. More... | |
void | DomainModified () |
Invokes DomainModifiedEvent. More... | |
void | InvokeModified () |
Gets the number of required properties added. More... | |
Set the domain's property. More... | |
Add the header and creates a new vtkPVXMLElement for the domain, fills it up with the common attributes. More... | |
virtual void | ChildSaveState (vtkPVXMLElement *domainElement) |
vtkSMSessionObject () | |
vtkSMObject () | |
~vtkSMObject () override | |
vtkObject () | |
virtual | ~vtkObject () |
vtkObjectBase () | |
virtual | ~vtkObjectBase () |
Protected Attributes | |
int | Mode |
double | ScaleFactor |
int | AxisFlags |
char * | XMLName |
bool | IsOptional |
vtkSMDomainInternals * | Internals |
vtkWeakPointer< vtkSMSession > | Session |
Identifies the session id to which this object is related. More... | |
bool | Debug |
vtkTimeStamp | MTime |
vtkSMBoundsDomain extends vtkSMDoubleRangeDomain to add support to determine the valid range for the values based on the dataset bounds. There are several Modes
which can be used to control how the range is computed based on the data bounds (defined by the vtkSMBoundsDomain::Modes enum).
NORMAL
: this is the basic mode where the domain will have 3 ranges which are the min and max for the bounds along each of the coordinate axis. MAGNITUDE:
the domain has a single range set to (-magn/2.0, +magn/2.0) where magn is the magnitude of the diagonal. ORIENTED_MAGNITUDE:
same as MAGNITUDE, but instead of the diagonal, a vector determined using two additional required properties with functions Normal, and Origin is used. COMPONENT_MAGNITUDE:
similar to MAGNITUDE except suitable for 3 component properties where each component is given range for the corresponding axis i.e. (0, xmax-xmin), (0, ymax-ymin), (0, zmax-zmin)
. SCALED_EXTENT:
the range is set to (0, maxbounds * this->ScaleFactor) where maxbounds is the length of the longest axis for the bounding box. ARRAY_SCALED_EXTENT:
the range is set to (0, (arrayMagnitude / maxbounds) * this->ScaleFactor) where maxbounds is the length of the longest axis for the bounding box. and arrayMagnitude the maximum magnitude of the array. APPROXIMATE_CELL_LENGTH:
approximation for cell length computed using the DATA_BOUNDS:
this mode for a 6 tuple property that takes the data bounds. The range will have 6 ranges: (xmin,xmax), (xmin,xmax), (ymin,ymax), (ymin,ymax), (zmin,zmax), and (zmin,zmax). If default_mode is not specified, then "min,max,min,max,min,max" is assumed. EXTENTS:
this mode for a property that takes a value between 0 and (max-min) for each component.To determine the input data bounds, this domain depends on a required property with function Input
. The data-information from the source-proxy set as the value for that property is used to determine the bounds.
Supported XML attributes:
mode
: used to specify the Mode. Value can be "normal", "magnitude", "oriented_magnitude", "scaled_extent", "array_scaled_extent", or "approximate_cell_length", "data_bounds". scale_factor
: used in SCALED_EXTENT, ARRAY_SCALED_EXTENT and APPROXIMATE_CELL_LENGTH mode. Value is a floating point number that is used as the scale factor. Definition at line 59 of file vtkSMBoundsDomain.h.
Definition at line 63 of file vtkSMBoundsDomain.h.
Enumerator | |
NORMAL | |
MAGNITUDE | |
ORIENTED_MAGNITUDE | |
SCALED_EXTENT | |
ARRAY_SCALED_EXTENT | |
APPROXIMATE_CELL_LENGTH | |
DATA_BOUNDS | |
EXTENTS | |
COMPONENT_MAGNITUDE |
Definition at line 80 of file vtkSMBoundsDomain.h.
Enumerator | |
X_AXIS | |
Y_AXIS | |
Z_AXIS | |
X_AND_Y_AXES | |
Y_AND_Z_AXES | |
X_AND_Z_AXES | |
X_Y_AND_Z_AXES |
Definition at line 95 of file vtkSMBoundsDomain.h.
Reimplemented from vtkSMDoubleRangeDomain.
overrideprotectedvirtual |
Definition at line 136 of file vtkSMBoundsDomain.h.
Definition at line 137 of file vtkSMBoundsDomain.h.
Definition at line 138 of file vtkSMBoundsDomain.h.
