type specific extension to vtkSMRangeDomainTemplate for doubles. More...
#include <vtkSMDoubleRangeDomain.h>
typedef vtkSMDomain | Superclass |
enum | IsInDomainReturnCodes { NOT_APPLICABLE = -1, NOT_IN_DOMAIN = 0, IN_DOMAIN = 1 } |
virtual double | GetMinimum (unsigned int idx, int &exists) |
Return a min. More... | |
virtual double | GetMaximum (unsigned int idx, int &exists) |
Return a max. More... | |
virtual int | GetMinimumExists (unsigned int idx) |
Returns if minimum/maximum bound is set for the domain. More... | |
virtual int | GetMaximumExists (unsigned int idx) |
virtual double | GetMinimum (unsigned int idx) |
Returns the minimum/maximum value, is exists, otherwise 0 is returned. More... | |
virtual double | GetMaximum (unsigned int idx) |
virtual int | GetResolution () |
Returns the resolution. More... | |
Is the (unchecked) value of the property in the domain? Overwritten by sub-classes. More... | |
virtual void | Update (vtkSMProperty *requestingProperty) |
Update self based on the "unchecked" values of all required properties. More... | |
Set the value of an element of a property from the animation editor. More... | |
A vtkSMProperty is often defined with a default value in the XML itself. More... | |
Provides access to the vtkSMProperty on which this domain is hooked up. More... | |
Helper method to get the number of input connections hence the number of available vtkPVDataInformation from input proxy connected to the required property with the given function. More... | |
Returns a given required property of the given function. More... | |
When the IsOptional flag is set, IsInDomain() always returns true. More... | |
Helper methods to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More... | |
virtual vtkPVDataInformation * | GetInputSubsetDataInformation (const char *selector, const char *assemblyName, const char *function, unsigned int index=0) |
virtual void | Modified () |
static vtkSMDoubleRangeDomain * | New () |
static vtkSMDoubleRangeDomain * | SafeDownCast (vtkObject *o) |
static vtkSMDomain * | New () |
static vtkSMDomain * | SafeDownCast (vtkObject *o) |
static vtkObject * | New () |
vtkSMDoubleRangeDomain () | |
~vtkSMDoubleRangeDomain () override | |
vtkSMDomain () | |
~vtkSMDomain () override | |
Load the state of the domain from the XML. More... | |
virtual int | ReadXMLAttributes (vtkSMProperty *prop, vtkPVXMLElement *elem) |
Set the appropriate ivars from the xml element. More... | |
Remove the given property from the required properties list. More... | |
Add a new required property to this domain. More... | |
void | DomainModified () |
Invokes DomainModifiedEvent. More... | |
void | InvokeModified () |
Gets the number of required properties added. More... | |
Set the domain's property. More... | |
Add the header and creates a new vtkPVXMLElement for the domain, fills it up with the common attributes. More... | |
virtual void | ChildSaveState (vtkPVXMLElement *domainElement) |
vtkSMSessionObject () | |
vtkSMObject () | |
~vtkSMObject () override | |
vtkObject () | |
virtual | ~vtkObject () |
vtkObjectBase () | |
virtual | ~vtkObjectBase () |
char * | XMLName |
bool | IsOptional |
vtkSMDomainInternals * | Internals |
vtkWeakPointer< vtkSMSession > | Session |
Identifies the session id to which this object is related. More... | |
bool | Debug |
vtkTimeStamp | MTime |
vtkSMDoubleRangeDomain is a type-specific specialization for vtkSMRangeDomainTemplate.
Definition at line 28 of file vtkSMDoubleRangeDomain.h.
Definition at line 35 of file vtkSMDoubleRangeDomain.h.
Reimplemented in vtkSMBoundsDomain, and vtkSMArrayRangeDomain.
Return a min.
value if it exists. If the min. exists exists is set to 1. Otherwise, it is set to 0. An unspecified min. is equivalent to -inf
Definition at line 43 of file vtkSMDoubleRangeDomain.h.
Return a max.
value if it exists. If the max. exists exists is set to 1. Otherwise, it is set to 0. An unspecified max. is equivalent to +inf
Definition at line 53 of file vtkSMDoubleRangeDomain.h.
Definition at line 61 of file vtkSMDoubleRangeDomain.h.
Definition at line 65 of file vtkSMDoubleRangeDomain.h.
Use GetMaximumExists() GetMaximumExists() to make sure that the bound is set.
Definition at line 75 of file vtkSMDoubleRangeDomain.h.
Definition at line 76 of file vtkSMDoubleRangeDomain.h.
inlinevirtual |
Definition at line 81 of file vtkSMDoubleRangeDomain.h.
