vtkSMCSVProxiesInitializationHelper Class Reference
initialization helper for (writers, PCSVReader) proxy. More...
#include <vtkSMCSVProxiesInitializationHelper.h>
Inheritance diagram for vtkSMCSVProxiesInitializationHelper:
Collaboration diagram for vtkSMCSVProxiesInitializationHelper:
typedef vtkSMProxyInitializationHelper Superclass
- Public Types inherited from vtkSMProxyInitializationHelper
void PostInitializeProxy (vtkSMProxy *, vtkPVXMLElement *, vtkMTimeType) override
 Called during vtkSMParaViewPipelineController::PostInitializeProxy() to initialize a proxy. More...
- Public Member Functions inherited from vtkSMProxyInitializationHelper
virtual void RegisterProxy (vtkSMProxy *proxy, vtkPVXMLElement *xml)
 Called during vtkSMParaViewPipelineController::Register. More...
static vtkSMCSVProxiesInitializationHelperNew ()
static vtkSMCSVProxiesInitializationHelperSafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMProxyInitializationHelper
static vtkSMProxyInitializationHelperSafeDownCast (vtkObject *o)
static vtkSMObjectNew ()
static vtkObjectNew ()
static vtkObjectBaseNew ()
 vtkSMCSVProxiesInitializationHelper ()
 ~vtkSMCSVProxiesInitializationHelper () override
- Protected Member Functions inherited from vtkSMProxyInitializationHelper
 vtkSMProxyInitializationHelper ()
 ~vtkSMProxyInitializationHelper () override
 vtkSMObject ()
 ~vtkSMObject () override
vtkSMCSVProxiesInitializationHelper is an initialization helper for the PCSVReader or PCSVWriter proxy that sets up the delimiter to use based on the file extension. If the file extension is .txt or .tsv then
'\t'
is set as the delimiter.
Definition at line 20 of file vtkSMCSVProxiesInitializationHelper.h.
Definition at line 25 of file vtkSMCSVProxiesInitializationHelper.h.
◆ vtkSMCSVProxiesInitializationHelper()
vtkSMCSVProxiesInitializationHelper::vtkSMCSVProxiesInitializationHelper ( )
◆ ~vtkSMCSVProxiesInitializationHelper()
vtkSMCSVProxiesInitializationHelper::~vtkSMCSVProxiesInitializationHelper ( )
static vtkSMCSVProxiesInitializationHelper* vtkSMCSVProxiesInitializationHelper::New ( )
virtual const char* vtkSMCSVProxiesInitializationHelper::GetClassName ( )
Reimplemented from vtkSMProxyInitializationHelper.
static int vtkSMCSVProxiesInitializationHelper::IsTypeOf ( const char *  type)
virtual int vtkSMCSVProxiesInitializationHelper::IsA ( const char *  type)
static vtkSMCSVProxiesInitializationHelper* vtkSMCSVProxiesInitializationHelper::SafeDownCast ( vtkObject o)
void vtkSMCSVProxiesInitializationHelper::PrintSelf ( ostream &  os,
◆ PostInitializeProxy()
void vtkSMCSVProxiesInitializationHelper::PostInitializeProxy ( vtkSMProxy proxy,
vtkPVXMLElement xml,
vtkMTimeType  initializationTimeStamp
Parameters
proxy: the proxy being initialized.
xml: the XML configuration from this helper from this Hints for the proxy. This makes it possible to pass additional configuration parameters to the initialization helper.
initializationTimeStampthe timestamp for the proxy initialization. Generally, if a property on the proxy has MTime greater than initializationTimeStamp, the initializer should not modify the property since it was explicitly set by the user during initialization.
Implements vtkSMProxyInitializationHelper.
