initialization helper for a proxy. More...
#include <vtkSMProxyInitializationHelper.h>
virtual void | PostInitializeProxy (vtkSMProxy *proxy, vtkPVXMLElement *xml, vtkMTimeType initializationTimeStamp)=0 |
Called during vtkSMParaViewPipelineController::PostInitializeProxy() to initialize a proxy. More... | |
virtual void | RegisterProxy (vtkSMProxy *proxy, vtkPVXMLElement *xml) |
Called during vtkSMParaViewPipelineController::Register. More... | |
virtual void | Modified () |
static vtkSMProxyInitializationHelper * | SafeDownCast (vtkObject *o) |
static vtkObject * | New () |
vtkSMProxyInitializationHelper () | |
~vtkSMProxyInitializationHelper () override | |
vtkSMObject () | |
~vtkSMObject () override | |
vtkObject () | |
virtual | ~vtkObject () |
vtkObjectBase () | |
virtual | ~vtkObjectBase () |
bool | Debug |
vtkTimeStamp | MTime |
vtkSMProxyInitializationHelper is used to add custom initialization logic to the initialization of a proxy done by vtkSMParaViewPipelineController. Developers can create new subclasses of vtkSMProxyInitializationHelper for specific proxy types. vtkSMProxyInitializationHelper will instantiate the helper and call PostInitializeProxy() in vtkSMParaViewPipelineController::PostInitializeProxy().
Helpers are added to a proxy in the XML configuration as follows:
Definition at line 32 of file vtkSMProxyInitializationHelper.h.
Definition at line 35 of file vtkSMProxyInitializationHelper.h.
Reimplemented in vtkSMXYChartRepresentationInitializationHelper.
pure virtual |
proxy | : the proxy being initialized. |
xml | : the XML configuration from this helper from this Hints for the proxy. This makes it possible to pass additional configuration parameters to the initialization helper. |
initializationTimeStamp | the timestamp for the proxy initialization. Generally, if a property on the proxy has MTime greater than initializationTimeStamp, the initializer should not modify the property since it was explicitly set by the user during initialization. |
Implemented in vtkSMCSVProxiesInitializationHelper, vtkSMOMETIFFChannelCalculatorInitializationHelper, vtkSMPLYWriterProxyInitializationHelper, vtkSMXYChartRepresentationInitializationHelper, and vtkSMExtractSelectionProxyInitializationHelper.
*Proxy to register any helper proxies created during by this helper. Default implementation does nothing.
Reimplemented in vtkSMOMETIFFChannelCalculatorInitializationHelper.
