domain used to restrict an vtkSMIntVectorProperty values to valid flat-index
for a vtkCompositeDataSet.
#include <vtkSMCompositeTreeDomain.h>
enum | { ALL = 0, LEAVES = 1, NON_LEAVES = 2, NONE = 3, AMR = 4 } |
enum | DefaultModes { DEFAULT = 0, NONEMPTY_LEAF = 1 } |
typedef vtkSMDomain | Superclass |
enum | IsInDomainReturnCodes { NOT_APPLICABLE = -1, NOT_IN_DOMAIN = 0, IN_DOMAIN = 1 } |
void | Update (vtkSMProperty *input) override |
Called when the 'required-property' is modified. More... | |
vtkDataAssembly * | GetHierarchy () const |
Returns vtkDataAssembly representing the hierarchy. More... | |
int | IsInDomain (vtkSMProperty *vtkNotUsed(property)) override |
Is the (unchecked) value of the property in the domain? Overwritten by sub-classes. More... | |
int | SetDefaultValues (vtkSMProperty *, bool use_unchecked_values) override |
A vtkSMProperty is often defined with a default value in the XML itself. More... | |
virtual vtkPVDataInformation * | GetInformation () |
Get the vtkPVDataInformation which provides the tree structure for the composite dataset. More... | |
virtual int | GetMode () |
Mode indicates if the property is interested in all nodes, leaves only or non-leaves only. More... | |
virtual void | SetMode (int) |
virtual int | GetDefaultMode () |
DefaultMode controls how the default value for the property is set by SetDefaultValues(). More... | |
virtual void | SetDefaultMode (int) |
Set the value of an element of a property from the animation editor. More... | |
Provides access to the vtkSMProperty on which this domain is hooked up. More... | |
Helper method to get the number of input connections hence the number of available vtkPVDataInformation from input proxy connected to the required property with the given function. More... | |
Returns a given required property of the given function. More... | |
When the IsOptional flag is set, IsInDomain() always returns true. More... | |
Helper methods to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More... | |
virtual vtkPVDataInformation * | GetInputSubsetDataInformation (const char *selector, const char *assemblyName, const char *function, unsigned int index=0) |
virtual void | Modified () |
static vtkSMCompositeTreeDomain * | New () |
static vtkSMCompositeTreeDomain * | SafeDownCast (vtkObject *o) |
static vtkSMDomain * | New () |
static vtkSMDomain * | SafeDownCast (vtkObject *o) |
static vtkObject * | New () |
vtkSMCompositeTreeDomain () | |
~vtkSMCompositeTreeDomain () override | |
int | ReadXMLAttributes (vtkSMProperty *prop, vtkPVXMLElement *element) override |
Set the appropriate ivars from the xml element. More... | |
void | SetInformation (vtkPVDataInformation *) |
vtkSMDomain () | |
~vtkSMDomain () override | |
Load the state of the domain from the XML. More... | |
Remove the given property from the required properties list. More... | |
Add a new required property to this domain. More... | |
void | DomainModified () |
Invokes DomainModifiedEvent. More... | |
void | InvokeModified () |
Gets the number of required properties added. More... | |
Set the domain's property. More... | |
Add the header and creates a new vtkPVXMLElement for the domain, fills it up with the common attributes. More... | |
virtual void | ChildSaveState (vtkPVXMLElement *domainElement) |
vtkSMSessionObject () | |
vtkSMObject () | |
~vtkSMObject () override | |
vtkObject () | |
virtual | ~vtkObject () |
vtkObjectBase () | |
virtual | ~vtkObjectBase () |
Protected Attributes | |
vtkPVDataInformation * | Information |
int | Mode |
int | DefaultMode |
char * | XMLName |
bool | IsOptional |
vtkSMDomainInternals * | Internals |
vtkWeakPointer< vtkSMSession > | Session |
Identifies the session id to which this object is related. More... | |
bool | Debug |
vtkTimeStamp | MTime |
vtkSMCompositeTreeDomain should be considered deprecated. New code should no longer use this domain. Developers are encouraged to update filters to not rely on composite-index and instead use selectors to select blocks. See vtkSMDataAssemblyDomain.
vtkSMCompositeTreeDomain can be added to a vtkSMIntVectorProperty. This domain requires a vtkSMInputProperty which is used to provide the input to the filter. This domain obtains data information from the input selected on the required input property and then decides the range for values the property can have.
Broadly speaking, there are two ways of identifying unique node in a composite dataset: flat-index
(also called composite-index
) and level-block-index
. flat-index
applies to all types of composite datasets while level-block-index
(or just level-index
) applies only to AMR datasets. flat-index
for any node in an arbitrary composite-dataset is simply the index of that node in a pre-order traversal of the tree with the root composite-dataset getting the index 0. level-index
for an AMR dataset is the AMR level number while level-block-index
is a pair of the AMR level number and block number for the node in that level.
The type of index the property expects, is defined by the domain's mode. Supported modes are:
flat-index
and can accept index for any node (leaf or non-leaf). This can be specified in XML using the mode="all"
.flat-index
however can only accept flat-indices for leaf-nodes. This can be specified in XML using the mode="leaves"
.level-index
i.e. AMR level number or level-block-index
. If the property has 2 elements (or for repeatable properties, if number of elements per command is 2) then level-block-index
is used, otherwise simply the level-index
is used. This only makes sense for filters dealing with AMR datasets. This can be specified in XML using the mode="amr"
.mode="non-leaves"
.vtkSMCompositeTreeDomain also provides ability to set default value on the property. If mode is LEAVES, then the default value selected is the first non-null leaf node. If mode is ALL, the same behaviour for default value is possible by using default_mode="nonempty-leaf"
in XML. e.g.
Definition at line 78 of file vtkSMCompositeTreeDomain.h.
Definition at line 82 of file vtkSMCompositeTreeDomain.h.
anonymous enum |
Enumerator | |
ALL | |
LEAVES | |
NON_LEAVES | |
NONE | |
AMR |
Definition at line 121 of file vtkSMCompositeTreeDomain.h.
Enumerator | |
DEFAULT | |
NONEMPTY_LEAF |
Definition at line 130 of file vtkSMCompositeTreeDomain.h.
The property must be a vtkSMInputProperty. This will obtain the composite data information for the input source and then determine the valid range for the flat-index.
vtkDataAssembly* vtkSMCompositeTreeDomain::GetHierarchy | ( | ) | const |
inlineoverridevirtual |
Definition at line 109 of file vtkSMCompositeTreeDomain.h.
Can be configured in XML using the "mode" attribute. Values can be "all", "leaves", "non-leaves". Default is all nodes.
DEFAULT implies the default value is picked based on the default strategy for the selected Mode. NONEMPTY_LEAF indicates that the first non-empty leaf node is set as the default value, if possible.
However, many times, the default value must be determined at run time. To facilitate this, domains can override this method to compute and set the default value for the property. Note that unlike the compile-time default values, the application must explicitly call this method to initialize the property. Returns 1 if the domain updated the property.
overrideprotectedvirtual |
Definition at line 166 of file vtkSMCompositeTreeDomain.h.
Definition at line 167 of file vtkSMCompositeTreeDomain.h.
Definition at line 168 of file vtkSMCompositeTreeDomain.h.
