vtkSMCompositeTreeDomain.h
68 #ifndef vtkSMCompositeTreeDomain_h
69 #define vtkSMCompositeTreeDomain_h
70
71 #include "vtkRemotingServerManagerModule.h" //needed for exports
72 #include "vtkSMDomain.h"
73
75 class vtkSMInputProperty;
76 class vtkDataAssembly;
77
79 {
80 public:
81  static vtkSMCompositeTreeDomain* New();
83  void PrintSelf(ostream& os, vtkIndent indent) override;
84
90  void Update(vtkSMProperty* input) override;
91
93
97  vtkGetObjectMacro(Information, vtkPVDataInformation);
99
103  vtkDataAssembly* GetHierarchy() const;
104
109  int IsInDomain(vtkSMProperty* vtkNotUsed(property)) override { return 1; }
110
112
117  vtkGetMacro(Mode, int);
118  vtkSetMacro(Mode, int);
120
121  enum
122  {
123  ALL = 0,
124  LEAVES = 1,
125  NON_LEAVES = 2,
126  NONE = 3,
127  AMR = 4,
128  };
129
131  {
132  DEFAULT = 0,
133  NONEMPTY_LEAF = 1
134  };
135
137
143  vtkGetMacro(DefaultMode, int);
144  vtkSetMacro(DefaultMode, int);
146
157  int SetDefaultValues(vtkSMProperty*, bool use_unchecked_values) override;
158
159 protected:
161  ~vtkSMCompositeTreeDomain() override;
162
163  int ReadXMLAttributes(vtkSMProperty* prop, vtkPVXMLElement* element) override;
164  void SetInformation(vtkPVDataInformation*);
165
167  int Mode;
169
170 private:
172  void operator=(const vtkSMCompositeTreeDomain&) = delete;
173
174  // Used to determine if the domain has really changed.
175  vtkMTimeType DataInformationTimeStamp;
176 };
177
178 #endif
provides meta data about a vtkDataObject subclass.
virtual void Update(vtkSMProperty *requestingProperty)
Update self based on the "unchecked" values of all required properties.
vtkTypeUInt64 vtkMTimeType
virtual int SetDefaultValues(vtkSMProperty *, bool vtkNotUsed(use_unchecked_values))
Definition: vtkSMDomain.h:91
const int NONE
represents the possible values a property can have
Definition: vtkSMDomain.h:37
virtual int ReadXMLAttributes(vtkSMProperty *prop, vtkPVXMLElement *elem)
vtkPVDataInformation * Information
static vtkSMDomain * New()
int IsInDomain(vtkSMProperty *vtkNotUsed(property)) override
Is the (unchecked) value of the property in the domain? Overwritten by sub-classes.
domain used to restrict an vtkSMIntVectorProperty values to valid flat-index for a vtkCompositeDataSe...
proxy representing inputs to a filter
