list of integers with associated strings More...
#include <vtkSMEnumerationDomain.h>
typedef vtkSMDomain | Superclass |
enum | IsInDomainReturnCodes { NOT_APPLICABLE = -1, NOT_IN_DOMAIN = 0, IN_DOMAIN = 1 } |
int | IsInDomain (vtkSMProperty *property) override |
Returns true if the value of the property is in the domain. More... | |
int | IsInDomain (int val, unsigned int &idx) |
Returns true if the int is in the domain. More... | |
unsigned int | GetNumberOfEntries () |
Returns the number of entries in the enumeration. More... | |
int | GetEntryValue (unsigned int idx) |
Returns the integer value of an enumeration entry. More... | |
const char * | GetEntryText (unsigned int idx) |
Returns the descriptive string of an enumeration entry. More... | |
const char * | GetEntryTextForValue (int value) |
Returns the text for an enumeration value. More... | |
int | HasEntryText (const char *text) |
Return 1 is the text is present in the enumeration, otherwise 0. More... | |
int | GetEntryValueForText (const char *text) |
Get the value for an enumeration text. More... | |
int | GetEntryValue (const char *text, int &valid) |
Given an entry text, return the integer value. More... | |
const char * | GetInfoText (unsigned int idx) |
Returns the info text for an enumeration entry. More... | |
void | AddEntry (const char *text, int value, const char *info=nullptr) |
Add a new enumeration entry. More... | |
void | RemoveAllEntries () |
Clear all entries. More... | |
void | Update (vtkSMProperty *property) override |
Update self based on the "unchecked" values of all required properties. More... | |
Is the (unchecked) value of the property in the domain? Overwritten by sub-classes. More... | |
Set the value of an element of a property from the animation editor. More... | |
A vtkSMProperty is often defined with a default value in the XML itself. More... | |
Provides access to the vtkSMProperty on which this domain is hooked up. More... | |
Helper method to get the number of input connections hence the number of available vtkPVDataInformation from input proxy connected to the required property with the given function. More... | |
Returns a given required property of the given function. More... | |
When the IsOptional flag is set, IsInDomain() always returns true. More... | |
Helper methods to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More... | |
virtual vtkPVDataInformation * | GetInputSubsetDataInformation (const char *selector, const char *assemblyName, const char *function, unsigned int index=0) |
virtual void | Modified () |
static vtkSMEnumerationDomain * | New () |
static vtkSMEnumerationDomain * | SafeDownCast (vtkObject *o) |
static vtkSMDomain * | New () |
static vtkSMDomain * | SafeDownCast (vtkObject *o) |
static vtkObject * | New () |
int | ReadXMLAttributes (vtkSMProperty *prop, vtkPVXMLElement *element) override |
Set the appropriate ivars from the xml element. More... | |
void | ChildSaveState (vtkPVXMLElement *domainElement) override |
Add the header and creates a new vtkPVXMLElement for the domain, fills it up with the common attributes. More... | |
vtkSMDomain () | |
~vtkSMDomain () override | |
Load the state of the domain from the XML. More... | |
Remove the given property from the required properties list. More... | |
Add a new required property to this domain. More... | |
void | DomainModified () |
Invokes DomainModifiedEvent. More... | |
void | InvokeModified () |
Gets the number of required properties added. More... | |
Set the domain's property. More... | |
vtkSMSessionObject () | |
vtkSMObject () | |
~vtkSMObject () override | |
vtkObject () | |
virtual | ~vtkObject () |
vtkObjectBase () | |
virtual | ~vtkObjectBase () |
int | SetDefaultValues (vtkSMProperty *, bool use_unchecked_values) override |
Overridden to ensure that the property's default value is valid for the enumeration, if not it will be set to the first enumeration value. More... | |
vtkSMEnumerationDomain () | |
~vtkSMEnumerationDomain () override | |
char * | XMLName |
bool | IsOptional |
vtkSMDomainInternals * | Internals |
vtkWeakPointer< vtkSMSession > | Session |
Identifies the session id to which this object is related. More... | |
bool | Debug |
vtkTimeStamp | MTime |
vtkSMEnumerationDomain represents an enumeration of integer values with associated descriptive strings.
A typical enumeration domain is described as follows in the servermanager configuration xmls.
Where, value
is the integral value to use to set the element on the property and text
is the descriptive text used in UI and Python script.
Starting with ParaView 5.5, the info
attribute is supported on an Entry
The value is an additional qualifier for the entry that used in UI to explain the item e.g.
If info
is specified and non-empty, then the UI will show that text in the combo-box rendered in addition to the text
. info
has no effect on the Python API i.e.
Definition at line 67 of file vtkSMEnumerationDomain.h.
Definition at line 71 of file vtkSMEnumerationDomain.h.
Reimplemented in vtkSMFieldDataDomain, and vtkSMNumberOfComponentsDomain.
The property has to be a vtkSMIntVectorProperty. If all vector values are in the domain, it returns 1. It returns 0 otherwise.
If value is in domain, it's index is return in idx.
unsigned int vtkSMEnumerationDomain::GetNumberOfEntries | ( | ) |
The return value is valid only is HasEntryText() returns 1.
Valid is set to 1 if text is defined, otherwise 0. If valid=0, return value is undefined.
Returns the info
[in] | idx | - index for the entry (not to confused with value ). |
nullptr
. Add a new enumeration entry.
text cannot be null.
void vtkSMEnumerationDomain::RemoveAllEntries | ( | ) |
Clear all entries.
overrideprotectedvirtual |
The newly created element will also be added to the parent element as a child node. Subclasses can override ChildSaveState() method to fill it up with subclass specific values.
