void | Update (vtkSMProperty *prop) override |
| Updates the range based on the scalar range of the currently selected array. More...
Public Member Functions inherited from vtkSMEnumerationDomain |
int | IsInDomain (vtkSMProperty *property) override |
| Returns true if the value of the property is in the domain. More...
int | IsInDomain (int val, unsigned int &idx) |
| Returns true if the int is in the domain. More...
unsigned int | GetNumberOfEntries () |
| Returns the number of entries in the enumeration. More...
int | GetEntryValue (unsigned int idx) |
| Returns the integer value of an enumeration entry. More...
const char * | GetEntryText (unsigned int idx) |
| Returns the descriptive string of an enumeration entry. More...
const char * | GetEntryTextForValue (int value) |
| Returns the text for an enumeration value. More...
int | HasEntryText (const char *text) |
| Return 1 is the text is present in the enumeration, otherwise 0. More...
int | GetEntryValueForText (const char *text) |
| Get the value for an enumeration text. More...
int | GetEntryValue (const char *text, int &valid) |
| Given an entry text, return the integer value. More...
const char * | GetInfoText (unsigned int idx) |
| Returns the info text for an enumeration entry. More...
void | AddEntry (const char *text, int value, const char *info=nullptr) |
| Add a new enumeration entry. More...
void | RemoveAllEntries () |
| Clear all entries. More...
int | SetDefaultValues (vtkSMProperty *, bool use_unchecked_values) override |
| Overridden to ensure that the property's default value is valid for the enumeration, if not it will be set to the first enumeration value. More...
| Is the (unchecked) value of the property in the domain? Overwritten by sub-classes. More...
| Set the value of an element of a property from the animation editor. More...
| A vtkSMProperty is often defined with a default value in the XML itself. More...
| Provides access to the vtkSMProperty on which this domain is hooked up. More...
| Helper method to get the number of input connections hence the number of available vtkPVDataInformation from input proxy connected to the required property with the given function. More...
| Returns a given required property of the given function. More...
| When the IsOptional flag is set, IsInDomain() always returns true. More...
| Helper methods to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More...
virtual vtkPVDataInformation * | GetInputSubsetDataInformation (const char *selector, const char *assemblyName, const char *function, unsigned int index=0) |
virtual void | Modified () |
