domain to ensure that input has required types of arrays. More...
#include <vtkSMInputArrayDomain.h>
enum | AttributeTypes { POINT = vtkDataObject::POINT, CELL = vtkDataObject::CELL, FIELD = vtkDataObject::FIELD, ANY_EXCEPT_FIELD = vtkDataObject::POINT_THEN_CELL, VERTEX = vtkDataObject::VERTEX, EDGE = vtkDataObject::EDGE, ROW = vtkDataObject::ROW, ANY = vtkDataObject::NUMBER_OF_ATTRIBUTE_TYPES, NUMBER_OF_ATTRIBUTE_TYPES = ANY + 1 } |
typedef vtkSMDomain | Superclass |
enum | IsInDomainReturnCodes { NOT_APPLICABLE = -1, NOT_IN_DOMAIN = 0, IN_DOMAIN = 1 } |
int | IsInDomain (vtkSMProperty *property) override |
Returns true if the value of the property is in the domain. More... | |
int | IsInDomain (vtkSMSourceProxy *proxy, unsigned int outputport=0) |
Returns true if input has one or more arrays that match the requirements on the given output port. More... | |
std::vector< int > | GetAcceptableNumbersOfComponents () const |
Get the AcceptableNumberOfComponents vector Empty or containing a zero means no check. More... | |
bool | GetAutoConvertProperties () |
Get the auto convert property for this specific domain. More... | |
int | IsArrayAcceptable (vtkPVArrayInformation *arrayInfo) |
This method will check if the arrayInfo contain info about an acceptable array, by checking its number of components against this domain acceptable numbers of components. More... | |
virtual int | GetAttributeType () |
Get the attribute type. More... | |
const char * | GetAttributeTypeAsString () |
Is the (unchecked) value of the property in the domain? Overwritten by sub-classes. More... | |
virtual void | Update (vtkSMProperty *requestingProperty) |
Update self based on the "unchecked" values of all required properties. More... | |
Set the value of an element of a property from the animation editor. More... | |
A vtkSMProperty is often defined with a default value in the XML itself. More... | |
Provides access to the vtkSMProperty on which this domain is hooked up. More... | |
Helper method to get the number of input connections hence the number of available vtkPVDataInformation from input proxy connected to the required property with the given function. More... | |
Returns a given required property of the given function. More... | |
When the IsOptional flag is set, IsInDomain() always returns true. More... | |
Helper methods to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More... | |
virtual vtkPVDataInformation * | GetInputSubsetDataInformation (const char *selector, const char *assemblyName, const char *function, unsigned int index=0) |
virtual void | Modified () |
static vtkSMInputArrayDomain * | New () |
static vtkSMInputArrayDomain * | SafeDownCast (vtkObject *o) |
static vtkSMInputArrayDomain * | FindApplicableDomain (vtkSMProperty *property) |
Helper method find the first vtkSMInputArrayDomain on the property that is acceptable based on the value of the property. More... | |
static void | SetAutomaticPropertyConversion (bool) |
Get/Set the application wide setting for automatic conversion of properties. More... | |
static bool | GetAutomaticPropertyConversion () |
static bool | IsAttributeTypeAcceptable (int required_type, int attribute_type, int *acceptable_as_type=nullptr) |
Method to check if a particular attribute-type (attribute_type ) will be accepted by this domain with a required attribute type (required_type ). More... | |
static bool | IsAttributeTypeAcceptable (int required_type, int attribute_type, int *acceptable_as_type, bool autoconvert) |
static vtkSMDomain * | New () |
static vtkSMDomain * | SafeDownCast (vtkObject *o) |
static vtkObject * | New () |
vtkSMInputArrayDomain () | |
~vtkSMInputArrayDomain () override | |
virtual void | SetAttributeType (int) |
void | SetAttributeType (const char *type) |
int | ReadXMLAttributes (vtkSMProperty *prop, vtkPVXMLElement *element) override |
Set the appropriate ivars from the xml element. More... | |
bool | IsAttributeTypeAcceptable (int attributeType) |
Returns true if based on this->AttributeType, the specified attributeType is acceptable to this domain. More... | |
bool | HasAcceptableArray (vtkPVDataSetAttributesInformation *attrInfo) |
Returns true if based on this->AutomaticPropertyConversion and this->NumberOfComponents, an acceptable array can be found in the attrInfo. More... | |
vtkSMDomain () | |
~vtkSMDomain () override | |
Load the state of the domain from the XML. More... | |
Remove the given property from the required properties list. More... | |
Add a new required property to this domain. More... | |
void | DomainModified () |
Invokes DomainModifiedEvent. More... | |
void | InvokeModified () |
Gets the number of required properties added. More... | |
Set the domain's property. More... | |
Add the header and creates a new vtkPVXMLElement for the domain, fills it up with the common attributes. More... | |
virtual void | ChildSaveState (vtkPVXMLElement *domainElement) |
vtkSMSessionObject () | |
vtkSMObject () | |
~vtkSMObject () override | |
vtkObject () | |
virtual | ~vtkObject () |
vtkObjectBase () | |
virtual | ~vtkObjectBase () |
Protected Attributes | |
int | AttributeType |
std::vector< int > | AcceptableNumbersOfComponents |
std::string | DataType |
char * | XMLName |
bool | IsOptional |
vtkSMDomainInternals * | Internals |
vtkWeakPointer< vtkSMSession > | Session |
Identifies the session id to which this object is related. More... | |
bool | Debug |
vtkTimeStamp | MTime |
vtkSMInputArrayDomain is a domain that can be used on a vtkSMInputProperty to check if the pipeline input provides attribute arrays of the required types e.g. if a filter can only work if the input data set has cell data arrays, then one can use this domain.
vtkSMInputArrayDomain also provides a mechanism to check if the attribute arrays have a certain number of components.
When enabled, ParaView supports automatic array conversion i.e. extracting components or converting cell data to point data and vice-versa is done implicitly. In that case, vtkSMInputArrayDomain's behavior also changes as appropriate.
Supported XML attributes:
attribute_type
: (optional) value can be 'point', 'cell', 'field', 'vertex', 'edge', 'row', 'none', 'any-except-field', 'any'. If not specified, 'any-except-field' is assumed. This indicates the attribute type for acceptable arrays. number_of_components
: (optional) Indicates the number of components required in arrays that are considered acceptable. 0 (default) indicates any number of components is acceptable. A comma-separated list (e.g., "1" or "1,3,4") of component counts limits acceptable arrays to those with a number of components that appear in the list. data_type:
(optional) when specified must be the class name for data type that this domain is applicable to. This is useful when adding multiple input-array-domains a property with different requirements based on the type (see ("filters", "Contour")
filter, for example). auto_convert_association:
(optional) Indicates if an automatic attribute type conversion can be applied to the input arrays to match the attribute_type criteria.This domain doesn't support any required properties (to help clean old code, we print a warning if any required properties are specified).
Definition at line 70 of file vtkSMInputArrayDomain.h.
Definition at line 74 of file vtkSMInputArrayDomain.h.
Enumerator | |
POINT | |
CELL | |
FIELD | |
ANY_EXCEPT_FIELD | |
VERTEX | |
EDGE | |
ROW | |
ANY | |
NUMBER_OF_ATTRIBUTE_TYPES |
Definition at line 122 of file vtkSMInputArrayDomain.h.
The property has to be a vtkSMProxyProperty which points to a vtkSMSourceProxy. The input has to have one or more arrays that match the requirements.
int vtkSMInputArrayDomain::IsInDomain | ( | vtkSMSourceProxy * | proxy, |
unsigned int | outputport = 0 |
Valid values are defined in AttributeTypes which map to vtkDataObject::AttributeTypes.
const char* vtkSMInputArrayDomain::GetAttributeTypeAsString | ( | ) |
std::vector<int> vtkSMInputArrayDomain::GetAcceptableNumbersOfComponents | ( | ) | const |
Automatic conversion of properties allows conversion between cell and point based properties, and the extraction of vector components as scalar properties
bool vtkSMInputArrayDomain::GetAutoConvertProperties | ( | ) |
This returns true if either application settings or local value is true.
This takes into consideration the state of AutomaticePropertyConversion flag. If a particular attribute_type is acceptable only because AutomaticPropertyConversion is true, acceptable_as_type
value will be set to the attribute type that the particular attribute was automatically converted to. e.g. is required_type = POINT and attribute_type is CELL and AutomaticPropertyConversion is true, this method will return true and acceptable_as_type will be set to POINT. In other cases, acceptable_as_type is simply set to attribute_type.
int vtkSMInputArrayDomain::IsArrayAcceptable | ( | vtkPVArrayInformation * | arrayInfo | ) |
Note that it takes into account property conversion This method return the accepted number of components to use.
on the property
The property is typically vtkSMInputProperty
. If none of the domains applicable, this will simply return the first vtkSMInputArrayDomain that is found.
protectedvirtual |
overrideprotectedvirtual |
Definition at line 196 of file vtkSMInputArrayDomain.h.
Definition at line 197 of file vtkSMInputArrayDomain.h.
Definition at line 198 of file vtkSMInputArrayDomain.h.
