vtkSMInputArrayDomain.h
49 #ifndef vtkSMInputArrayDomain_h
50 #define vtkSMInputArrayDomain_h
51
52 #include "vtkDataObject.h" // needed for vtkDataObject::AttributeTypes
53 #include "vtkRemotingServerManagerModule.h" //needed for exports
54 #include "vtkSMDomain.h"
55
56 #include <vector> // Needed for vector
57
58 // Needed to get around some header defining ANY as a macro
59 #ifdef ANY
60 #undef ANY
61 #endif
62
65 class vtkSMSourceProxy;
66
68 {
69 public:
70  static vtkSMInputArrayDomain* New();
72  void PrintSelf(ostream& os, vtkIndent indent) override;
73
80  int IsInDomain(vtkSMProperty* property) override;
81
86  int IsInDomain(vtkSMSourceProxy* proxy, unsigned int outputport = 0);
87
89
93  vtkGetMacro(AttributeType, int);
94  const char* GetAttributeTypeAsString();
96
101  std::vector<int> GetAcceptableNumbersOfComponents() const;
102
106  static void SetAutomaticPropertyConversion(bool);
107  static bool GetAutomaticPropertyConversion();
108
110  {
114  ANY_EXCEPT_FIELD = vtkDataObject::POINT_THEN_CELL,
119  NUMBER_OF_ATTRIBUTE_TYPES = ANY + 1,
120  };
121
134  static bool IsAttributeTypeAcceptable(
135  int required_type, int attribute_type, int* acceptable_as_type = nullptr);
136
143  int IsArrayAcceptable(vtkPVArrayInformation* arrayInfo);
144
151  static vtkSMInputArrayDomain* FindApplicableDomain(vtkSMProperty* property);
152
153 protected:
155  ~vtkSMInputArrayDomain() override;
156
157  vtkSetMacro(AttributeType, int);
158  void SetAttributeType(const char* type);
159
164  int ReadXMLAttributes(vtkSMProperty* prop, vtkPVXMLElement* element) override;
165
170  bool IsAttributeTypeAcceptable(int attributeType);
171
176  bool HasAcceptableArray(vtkPVDataSetAttributesInformation* attrInfo);
177
180  std::string DataType;
181
182 private:
183  static bool AutomaticPropertyConversion;
185  void operator=(const vtkSMInputArrayDomain&) = delete;
186 };
187
188 #endif
#define FIELD
std::vector< int > AcceptableNumbersOfComponents
domain to ensure that input has required types of arrays.
represents the possible values a property can have
Definition: vtkSMDomain.h:37
virtual int ReadXMLAttributes(vtkSMProperty *prop, vtkPVXMLElement *elem)
virtual int IsInDomain(vtkSMProperty *vtkNotUsed(property))
Is the (unchecked) value of the property in the domain? Overwritten by sub-classes.
Definition: vtkSMDomain.h:64
proxy for a VTK source on a server
provides meta data about arrays.
static vtkSMDomain * New()
