vtkSMSourceProxy.h
21 #ifndef vtkSMSourceProxy_h
22 #define vtkSMSourceProxy_h
23
24 #include "vtkRemotingServerManagerModule.h" //needed for exports
25 #include "vtkSMProxy.h"
26
30
31 struct vtkSMSourceProxyInternals;
32
33 class vtkSMOutputPort;
34 class vtkSMProperty;
36
38 {
39 public:
40  static vtkSMSourceProxy* New();
41  vtkTypeMacro(vtkSMSourceProxy, vtkSMProxy);
42  void PrintSelf(ostream& os, vtkIndent indent) override;
43
47  void UpdatePipelineInformation() override;
48
53  virtual void UpdatePipeline();
54
59  virtual void UpdatePipeline(double time);
60
62
65  vtkGetMacro(OutputPortsCreated, int);
67
71  virtual unsigned int GetNumberOfOutputPorts();
72
76  virtual vtkSMOutputPort* GetOutputPort(unsigned int idx);
77
84  virtual vtkSMOutputPort* GetOutputPort(const char* portname);
85
94  virtual unsigned int GetOutputPortIndex(const char* portname);
95
102  virtual const char* GetOutputPortName(unsigned int index);
103
105
111  vtkSMDocumentation* GetOutputPortDocumentation(unsigned int index);
112  vtkSMDocumentation* GetOutputPortDocumentation(const char* portname);
114
120  virtual void CreateOutputPorts();
121
123
130  vtkPVDataInformation* GetDataInformation(unsigned int outputIdx);
132
134
147  vtkPVDataInformation* GetSubsetDataInformation(
148  unsigned int outputIdx, const char* selector, const char* assemblyName = nullptr);
150
155  vtkPVDataInformation* GetSubsetDataInformation(
156  unsigned int outputIdx, unsigned int compositeIndex);
157
159
163  {
164  return this->GetRankDataInformation(0u, rank);
165  }
166  vtkPVDataInformation* GetRankDataInformation(unsigned int outputIdx, int rank);
168
173  virtual void CreateSelectionProxies();
174
180  void SetSelectionInput(unsigned int portIndex, vtkSMSourceProxy* input, unsigned int outputPort);
181
183
186  vtkSMSourceProxy* GetSelectionInput(unsigned int portIndex);
187  unsigned int GetSelectionInputPort(unsigned int portIndex);
189
193  void CleanSelectionInputs(unsigned int portIndex);
194
199  vtkSMSourceProxy* GetSelectionOutput(unsigned int portIndex);
200
202
211  vtkGetMacro(ProcessSupport, int);
213
215
220  vtkGetMacro(MPIRequired, bool);
222
226  unsigned int GetNumberOfAlgorithmOutputPorts();
227
232  virtual unsigned int GetNumberOfAlgorithmRequiredInputPorts();
233
237  vtkTypeUInt32 GetGlobalID() override;
238
240  {
243  BOTH
244  };
245
249  void MarkDirty(vtkSMProxy* modifiedProxy) override;
250
251 protected:
253  ~vtkSMSourceProxy() override;
254
255  friend class vtkSMInputProperty;
256  friend class vtkSMOutputPort;
257
259
262
266  virtual void InvalidateDataInformation();
267
272  void CreateVTKObjects() override;
273
275  vtkSetStringMacro(ExecutiveName);
276
280  int ReadXMLAttributes(vtkSMSessionProxyManager* pm, vtkPVXMLElement* element) override;
281
283
288  void SetOutputPort(
289  unsigned int index, const char* name, vtkSMOutputPort* port, vtkSMDocumentation* doc);
290  void RemoveAllOutputPorts();
291  void SetExtractSelectionProxy(unsigned int index, vtkSMSourceProxy* proxy);
292  void RemoveAllExtractSelectionProxies();
294
298  void PostUpdateData(bool) override;
299
303  void SetLogNameInternal(
304  const char* name, bool propagate_to_subproxies, bool propagate_to_proxylistdomains) override;
305
306  // flag used to avoid creation of extract selection proxies for this source
307  // proxy.
310
311 private:
312  vtkSMSourceProxyInternals* PInternals;
313
314  // used by GetNumberOfAlgorithmOutputPorts to cache the value to avoid
315  // unnecessary information gathers.
316  unsigned int NumberOfAlgorithmOutputPorts;
317  unsigned int NumberOfAlgorithmRequiredInputPorts;
318
319  vtkSMSourceProxy(const vtkSMSourceProxy&) = delete;
320  void operator=(const vtkSMSourceProxy&) = delete;
321 };
322
323 #endif
virtual void PostUpdateData(bool using_cache)
This method is called after the algorithm(s) (if any) associated with this proxy execute.
virtual void UpdatePipelineInformation()
This method simply iterates over subproxies and calls UpdatePipelineInformation() on them...
friend class vtkSMSourceProxy
These classes have been declared as friends to minimize the public interface exposed by vtkSMProxy...
Definition: vtkSMProxy.h:698
provides meta data about a vtkDataObject subclass.
virtual int ReadXMLAttributes(vtkSMSessionProxyManager *pm, vtkPVXMLElement *element)
Read attributes from an XML element.
Mark data information as invalid.
virtual void MarkDirty(vtkSMProxy *modifiedProxy)
Dirty means this algorithm will execute during next update.
virtual void SetLogNameInternal(const char *name, bool propagate_to_subproxies, bool propagate_to_proxylistdomains)
Internal method used by SetLogName
vtkPVDataInformation * GetRankDataInformation(int rank)
Get rank-specific data information.
proxy for a VTK source on a server
The vtkSMSessionProxyManager is esponsible for creating and managing proxies for a given session...
vtkPVDataInformation * GetDataInformation()
DataInformation is used by the source proxy to obtain information on the output(s) from the server...
static vtkSMProxy * New()
virtual void CreateVTKObjects()
Given a class name (by setting VTKClassName) and server ids (by setting ServerIDs), this methods instantiates the objects on the server(s)
Definition: vtkSMProxy.h:140
provides meta data about arrays.
reference for an output port of a vtkAlgorithm.
class providing access to the documentation for a vtkSMProxy.
void operator=(const vtkSMProxy &)=delete
virtual vtkTypeUInt32 GetGlobalID()
Get the global unique id for this object.
proxy representing inputs to a filter
