Major changes made since ParaView 5.12.1 are listed in this document. The full list of issues addressed by this release is available here.
You can now import all or a subset of meshes from a GLTF 2.0 file into ParaView as well as the material properties supported in VTK and textures.
Example of a GLTF scene loaded into and rendered in ParaView.
Use the import options dialog to make a selection of meshes that will be imported.
The GLTF importer's mesh selection dialog.
The previously supported fullscreen mode sets the tabbed multi-view widget fullscreen, that is, all views are maximized, including separators and decoration.
ParaView now has a new fullscreen mode showing only the current active view in fullscreen (shortcut: Ctrl + F11). The new mode is intended to be closer to a "classical" fullscreen mode.
This is in part motivated by the need of some hardware (like the zSpace Inspire) to have a strict fullscreen mode in order to display the rendered scene correctly.
ParaView's RenderView now has a new selection action called "Select Blocks Through". This action allows you to select all blocks that are inside the selected frustum. This is useful for selecting blocks that are hidden behind other blocks.
In the previous version of ParaView, MultiBlock Inspector supported changing only the following block properties:
All properties were previously set through controls in the multiblock tree.
Now, the MultiBlock Inspector supports changing the following the block properties:
With the exception of the Visibility property, all the properties in the new inspector are set in a small block color property panel below the multiblock tree. The Visibility property is set via a checkbox in the multiblock tree.
Each property has a state indicator and can be reset to the default value. All block selectors also have a state and a reset button for all of the properties of a block or parent of blocks.
To change a property of a block/blocks, the select the blocks in the MultiBlock Inspector and then change the desired property in the block color property panel. The change will be applied to all selected blocks.
The revised MultiBlock Inspector enables setting additional per-block properties by controls in the block color property panel.
A VTKHDF writer and extractor are now available in ParaView.
Currently, this writer supports writing Unstructured Grid and Polygonal Meshes, with time series support, as well as composite types Partitioned Dataset Collection and Multi-block Dataset, without time series support. This writer can also write compressed data to save storage space.
The VTKHDF exporter writes time-dependent data as file series, not using the time series support in the VTKHDF writer.
pvserver socket bind addressAdd the --bind-address command-line option to pvserver. This option allows changing the address bound to the server socket, so that it is not necessarily exposed on all interfaces using INADDR_ANY (0.0.0.0).
Settings are now supported for pvserver, pvrenderserver and pvdataserver.
These executables parse a file named ParaViewServer-UserSettings.json and look for settings named according to pvserver command-line connection options.
This file is expected to look like this:
The name of the setting is the "long" version of the option, without the two leading dashes.
only connection options are supported.
Geometry representations can now compute surface cell and point normals by enabling the new Compute Point Normals property. This can be a convenience to avoid the need to add an Extract Surface filter followed by a Generate Surface Normals filter. This option is available for the Surface, Surface with Edges, and the Surface LIC representations.
ParaView now uses a cache to save time when computing surfaces to display. If the surface mesh is unchanged since the last time it was extracted and caching is enabled, the extraction step simply uses the cached result, saving significant work in the steps leading up to the first render after a change is made.
This feature is not available in distributed execution.
RenderView**s now have a new annotation available: the **Polar Grid.
Similar to the Polar Axes already existing the Representation level, the Polar Grid can display axes and arcs, annotated with polar coordinates.
Like the Legend Grid, this new annotation is drawn in the screen space. Thus, it is only available when Camera Parallel Projection is enabled.
Example of a Polar Grid annotation
ParaView now has new block coloring capabilities thanks to additional block-specific properties and Python functions that apply to representations. New Python functions including ColorBlocksBy() and GetBlockColorTransferFunction() are also available to script block coloring options. An example can be found in Clients/ParaView/Testing/Python/ColorBlockBy.py test in ParaView's source code.
The new Texture Transform property has been added to translate, rotate, and scale texture coordinates when a texture is applied to an object. Since this transform can flip a texture by using a negative scale factor, the Flip Textures property has been deprecated.
You can now configure a custom maximum radius for the Polar Axes. Note that by default the custom maximum radius is off and therefore it is automatically computed relative to the pole position.
Before this feature, you could disable the lighting only for a whole view using the Light Kit checkbox inside the Light Inspector. This change allows you to disable lighting for a single source with a new display property named Disable Lighting.
The zSpace plugin now uses a dedicated render window class to support the specific rendering mode of the latest zSpace hardware. Unlike previous models, the zSpace Inspire does not rely on quad buffering to display stereo content. It uses its dedicated stereo display instead to perform stereo rendering. In order to have a working stereo effect, the current active view should be shown in fullscreen. Note that the zSpace Stereo Core Compatibility API should be used with this display.
The Axis-Aligned Slice filter is now available in ParaView.
This filter produces axis-aligned slices of the input data. The output data type is the same as the input, effectively reducing the dimensionality of the input data by one.
For now, this filter supports Hyper-tree Grids and Overlapping AMR Datasets as input data, and Axis-Aligned plane as cut function. In the case of Hyper-tree Grids, it also supports producing multiple slices at once.
This filter also supports composite datasets of Hyper-tree Grids. In such cases, it will iterate over each Hyper-tree Grid and generate a new hierarchy with added nodes containing the slices.
Please note that usages of Axis-Aligned plane in the Slice and Slice With Plane filters are deprecated in favor of this new dedicated filter.
Results showing multiple axis-aligned slices from a Hyper-tree Grid.
Introduce a new filter, named Force Static Mesh, that explicitly advertises that a mesh has not been modified. This information can be exploited by subsequent filters like the Surface Filter for performance and memory optimizations.
You can now apply the Feature Edges filter in ParaView to Hyper-tree Grids. The Feature Edges representation now works correctly with Hyper-tree Grids as well.
Feature Edges filter available for Hyper-tree Grids.
A new Hyper-tree Grid utility filter is available: HyperTreeGrid Visible Leaves Size. This filter creates two new cell fields:
ValidCell has a (double) value of 1.0 for visible (not ghost, non masked) leaf cells, and 0.0 for the others.CellSize's value corresponds to the volume of the cell in 3D, or area in 2D.Following data generation filters now support Hyper-tree Grids as input:
Note that only cell data can be generated for Hyper-tree Grids.
You can now generate a mask for the Hyper Tree Grid (Random) source, it can be controlled by the property Masked Fraction that controls the spatial proportion of the Hyper-tree Grid that will be masked. This value is a target and the actual masked fraction of the generated Hyper-tree Grid can differ up to an error margin, depending on the number of trees and the branching factor. Which means a masked fraction with a value near 1 can lead to a not completely masked Hyper-tree Grid, since the error margin still applies for this value.
Mask generation for the Hyper Tree Grid (Random) source
The Slice filter can now generate mutliple slices at once when the input is a Hyper-tree Grid.
Please note that this feature is not available when the Axis Aligned Plane is selected as the cut function, since this option is deprecated in the Slice filter. You can now use the dedicated Axis-Aligned Slice filter to do so.
The Extract Ghost Cells and Remove Ghost Cells filters can now be used for Hyper-tree Grids. Note that these filters mask cells and do not impact the number of cells of the input Hyper-tree Grids.
Given an input that changes over time, the Critical Time filter generates a new data array containing time step values. These values correspond to the time at which a specified threshold criterion has been met for a given point/cell array (at each point/cell respectively).
To do so, the filter needs to process all available timesteps. The output of the filter is not temporal.
Like in the Threshold filter, the threshold criterion can take three forms:
ParaView now has a Temporal Smoothing filter that smooths point and cell data from a temporal source by averaging the values over a temporal window defined by the filter's Temporal Window Half Width.
The Decimate Polyline filter now support multiple decimation strategies through a Decimation Strategy property:
DecimationAngleStrategy: use the angle between three consecutive points as error metricDecimationDistanceStrategy (default, identical to previous versions): use the distance between consecutive points as error metricDecimationCustomFieldStrategy: use values stored in a custom PointData array to compute the error between three consecutive points. The name of this array must be defined using the Field Name property.You can now read ERF HDF5 files into ParaView. The reader supports version 1.2 of the ERF HDF5 spec, specifically:
The output of the reader is a Partitioned Dataset Collection composed of multiple Unstructured Grids for the 'constant' or 'singlestate' groups.
The IOSS Reader now has a Caching property. When enabled, the reader will cache the mesh data in memory across multiple time steps. Previously, when the option was not present, the reader would always cache data, which could lead to excessive memory usage. Now, the default behavior is to not cache.
The openPMD format allows storage of multidimensional arrays (meshes) in either Fortran or C data orders with arbitrary axis labeling. Based on the data order, it may be necessary to transpose the data so that ParaView can correctly interpret the meshes.
C data order, the VTK axis ordering is expected to be (x, y, z)F data order, the VTK axis ordering is expected to be (z, y, x)Transposes are necessary if there is a mismatch in the expected axis ordering. This also fixes problems with 1D/2D meshes that require handling the transposes differently than 3D meshes.
In files with unitSI equal to 1.0, avoid scaling meshes. This is often the case for non-floating point records and unintentionally casts their type to double when we mean to stay in integer or unsigned integer (e.g., particle id) scales. Thus, this fixes issues with the latter and avoids unnecessary operations on large data sets.
The FDS reader now correctly supports reading slice and boundaries files (.sf & .bf), for both point and cell-centered data. Before these changes, only point data for slices was correctly parsed.
A new property has been added to the GLTF Exporter. Save NaN Value controls whether the exporter should save the NaN color in the exported texture. If enabled, the NaN color is saved as a second row in the color map texture which might affect how the texture is processed by the application that loads it.
You can now choose which arrays should be loaded with the Fides reader. The arrays available to load must still be specified in the JSON data model file, but you can now enable/disable loading those arrays through the GUI.
In in effort to improve ParaView's usability, a number of filters have been renamed to be more concise and meaningful. The list of filters whose names have changed is provided below.
| Previous name | New name |
| Ghost Cells Generator | Ghost Cells |
| Add Field Arrays | Field Arrays From File |
| Append Arc Length | Polyline Length |
| Append Location Attributes | Coordinates |
| Block Scalars | Block Ids |
| Compute Connected Surface Properties | Connected Surface Properties |
| Generate Global Ids | Global Point And Cell Ids |
| Generate Ids | Point And Cell Ids |
| Generate Process Ids | Process Ids |
| Generate Spatio Temporal Harmonics | Spatio Temporal Harmonics |
| Generate Surface Normals | Surface Normals |
| Generate Surface Tangents | Surface Tangents |
| Level Scalars (OverlappingAMR) | Overlapping AMR Level Ids |
Searching for the old names will continue to work for ParaView 5.13.0, and full backwards compatibility with state files and Python scripts from versions of ParaView before version 5.13.0 has been provided.
The ParaView Filters menu organizes filters into a list of categories. Those submenus can now be customized!
Go to the Tools -> Configure Categories dialog to create your own tree of categories. There you can create and rename categories, move filters around, set up icons, and event create toolbar from an existing category.
Some predefined categories have a specific meaning (and thus cannot be deleted):
Alphabetical category lists as usual every filter.Miscellaneous section contains filters that are not part of any other category.Favorites is now its own category, so you can configure it the same way.![]()
The categories configuration dialog.
To add filters, sources, and extractors, you can use ParaView's quick launch window (ctrl + space). In this window you can now see the documentation for the selected filter and the requirements on types of input for the selected filter. Moreover, you no longer need to know the filter actual name - the window also suggests filters based on search matches in their documentation.
The quick launch window now presents more information about filters, sources, and extractors.
Edit Macros dialogYou can now edit the names and tooltip text of a Python macro in the Edit Macros dialog. You can also open up the Python script associated with a macro in the code editor by clicking on the button at the end of the macro name column.
The Edit Macros dialog allows assignment of icons, renaming, and adding tooltip text to macros.
ParaView now offers an interface to select an icon for Macro buttons in the user interface. You can import your own image file or reuse one that ParaView already provides. ParaView stores the imported images under a new Icons directory, under your user directory.
The Icon browser dialog.
The prompt text argument of a call to the input function from a Python script is now displayed in the dialog that accepts user input. Prior to this change, the argument was only printed to the Output Messages window.
Dialog shown when `input('Enter Scattering Angle in degrees:')` is invoked in Python.
--venv command-line argument to specify a virtual environmentAll ParaView executables have a new --venv command-line argument for ParaView builds where Python is enabled. The path supplied for this argument is the path to a virtual environment that will be activated for the Python environment in these programs.
Usage example:
where my_awesome_module is installed in the Python environment that is loaded.
The virtual environment will be available in Programmable Source, Programmable Filter, and the Python Shell.
divvy, lite and visualizer are not bundled with ParaView anymore but distributed as separate web applications from these repositories:
ParaView would crash on startup if a file was opened with a semicolon ";" in the filename. The Recent Files menu and saved settings uses ";" as a record separator, and hash "#" as a server name indicator. These characters are now encoded in the settings file to avoid incorrect interpretation.
Updates listed below refer to ParaView's Catalyst 2 implementation.
Support for which Catalyst pipelines to execute has been added. This includes Python script pipelines as well as precompiled pipelines. The Python script pipelines are configured with:
where aname is the name of the pipeline. Precompiled pipelines are configure with:
where 0 is the name of the pipeline.
Pipelines can be selected by listing them under the catalyst/state/pipelines node such as
Note that the value of the node (aname) is what matters and not the name of the node (0). It is possible to turn off all of the pipelines by making pipelines a leaf node such as:
If catalyst/state/pipelines does not exist, Catalyst will, by default, execute all pipelines.
catalyst_results in Catalyst scriptsYou can now define custom catalyst_results(info) functions in Catalyst scripts which will be executed when the simulation calls catalyst_results. The Conduit node passed as input to the call from the simulation side is available via info.catalyst_params.
The input parameters of catalyst_execute are now accessible as a read-only Conduit node inside a catalyst script. You can now perform any kind of analysis directly on the data passed by the simulation.
Catalyst's "steering" capabilities can send data back to the simulation in order to "steer" it. In order to use the steering, the simulation used to send an XML file specifying a vtkSteeringDataGenerator proxy and properties to be filled by Paraview Catalyst.
While this still works, we introduce Catalyst steering extractors, a new kind of extractor acting as "sinks" in the visualization pipeline. Calling catalyst_results from the simulation will trigger these sinks, and their input dataset will be serialized to Conduit's mesh blueprint and sent back to the simulation in the results Conduit node. This special kind of extractor needs to be created in the Catalyst Python pipeline script. They are not associated to a trigger and a writer like other extractors are. They are created by the extracts controller but managed externally by the in situ helper.
Example Catalyst pipeline script:
This script is executed as usual when catalyst_execute is called, but the extraction happens only when the simulation calls catalyst_results. This feature can be used to perform a reduction on input data, for example, and get the result in the simulation directly.
SetStopOnUnrecognizedArgument was behaving in an inverted way according to its name and documentation. This was fixed and documentation was clarified.
Now, vtkCLIOptions::SetStopOnUnrecognizedArgument(true) will indeed stop the parsing on unrecognized arguments.
See https://github.com/CLIUtils/CLI11/issues/1052 for more info.
Support has been added for compiling against and using an external VTK. The version (git hash) of the external VTK has to match the version of the VTK sub-module included in the version of ParaView being compiled. While this is not enforced, it is likely that you would get a compilation error or a crash if you try to use ParaView with a differnet version of VTK than the one it was tested with (the version of the VTK submodule).
This feature is enabled with the PARAVIEW_USE_EXTERNAL_VTK CMake option enabled. VTK_DIR can be used to specify the location for the config file of the VTK install, such as: <vtk_install_dir>/lib/cmake/vtk-9.3.
Depending on what is enabled in ParaView, certain features need to be provided by the external VTK. The features required by ParaView but not provided by the VTK install, would be printed by CMake at configure time in a format that can be copied and pasted in a VTK reconfigure command that would compile those features in VTK.
This change propogates build flags from ParaView to VTK and affects how accelerated filters are built using VisKores (previously VTK-m). It does away with the requirement of using flags like PARAVIEW_USE_HIP when VTK-m is built with the necessary Kokkos backend. This also future-proofs the specification for backends. Two new flags are introduced PARAVIEW_USE_KOKKOS and PARAVIEW_KOKKOS_BACKEND – the first flag is considered ON automatically if the backend flag is provided.
Here is how you can build with different backends
PARAVIEW_USE_CUDA – use the native CUDA support from VTK-mPARAVIEW_USE_KOKKOS + PARAVIEW_KOKKOS_BACKEND=CUDA or PARAVIEW_KOKKOS_BACKEND=CUDA will use Kokkos with CUDA backendPARAVIEW_USE_KOKKOS + PARAVIEW_KOKKOS_BACKEND=SYCL or PARAVIEW_KOKKOS_BACKEND=SYCL will use Kokkos with SYCL backendPARAVIEW_USE_KOKKOS + PARAVIEW_KOKKOS_BACKEND=HIP or PARAVIEW_KOKKOS_BACKEND=HIP will use Kokkos with HIP backendPARAVIEW_USE_KOKKOS will use Kokkos with Serial backendFull proxy deprecation is now possible, thanks to improvement in the Python backward compatibility module. (see _backwardscompatibilityhelper.get_deprecated_proxies()). This mechanism is useful for renaming proxies, for example.
You can now serialize and deserialize VTK objects using the VTK Object Manager API. You can enable this feature by turning on PARAVIEW_USE_SERIALIZATION setting in CMake.
A new mechanism has been added to the plugin configuration files. It is now supported to load plugins only when needed by a proxy. See the specification of this mechanism in the PluginHowTo.md.
WarnOnPropertyChange string property widget hintYou can now display a warning message box when a StringVectorProperty has been changed using a hint. Set the onlyonce attribute to only show the message on the first property change. The Text tag specifies the message box title and body text.
For example:
pqAddToFavoritesReaction has been deprecated in favor of the new Categories mechanism. See pqProxyCategory.pqCategoryToolbarsBehavior, the protected prepareForTest() slot has been deprecated as it was mostly unused.pqColorMapEditor, the protected member function setDataRepresentation(pqDataRepresentation* repr, bool forceUpdate = false) has been deprecated in favor of setRepresentation(pqDataRepresentation* repr, bool forceUpdate = false) in the same class.pqDataAssemblyPropertyWidget, the selectorColors, compositeIndexColors, selectorOpacities, compositeIndexOpacities properties and their associated setters (setSelectorColors(), setCompositeIndexColors(), setSelectorOpacities(), and setCompositeIndexOpacities()), variant list getters (selectorColorsAsVariantList, compositeIndexColorsAsVariantList, selectorOpacitiesAsVariantList, and compositeIndexOpacitiesAsVariantList), and notification signals (colorsChanged, and opacitiesChanged) are no longer used.pqLiveSourceBehavior, the pause(), resume(), and isPaused() static member functions are deprecated in favor of non-static member functions of the same name in pqLiveSourceManager.pqManageFavoritesReaction has been deprecated in favor of the new Categories mechanism. See pqConfigureCategories instead.pqProxyGroupMenuManager, vtkSMProxy* getPrototype(QAction* action) const has been deprecated in favor of static vtkSMProxy* GetProxyPrototype(QAction*), bool hideForTests(const QString&) const and void setEnabled(bool) have been deprecated because they were mostly unused, void populateFavoritesMenu(), void loadFavoritesItems(), and QAction* getAddToFavoritesAction(const QString& path) have been deprecated because favorites are now a category configurable like other categories, and the protected Enabled member variable has been deprecated because it is unused.pqFavoritesDialog has been replaced by the new Categories mechanism. See pqConfigureCategories instead.pqQuickLaunchDialog has been deprecated. Use pqQuickLaunchDialogExtended instead.pqWaitCursor has been deprecated. Use pqScopedOverrideCursor(Qt::WaitCursor) instead.vtkInitializationHelper, static bool InitializeMiscellaneous(int type) has been deprecated. Use InitializeSettings and InitializeOthers instead.vtkGeometryRepresentation, void SetFlipTextures(bool) has been deprecated. Use SetTextureTransform(vtkTransform*) instead.vtkPolarAxesRepresentation, void SetEnableCustomRadius() and bool GetEnableCustomRadius() have been removed. Use void SetEnableCustomMinRadius(bool) and bool GetEnableCustomMinRadius() instead.vtkSMColorMapEditorHelper, static vtkSMProxy* GetLUTProxy(vtkSMProxy* proxy, vtkSMProxy* view) has been deprecated. Use static vtkSMProxy* GetLookupTable(vtkSMProxy* proxy, vtkSMProxy* view) instead.vtkSMPVRepresentationProxy, SetLastLUTProxy(vtkSMProxy* proxy), vtkSMProxy* GetLastLUTProxy(), and vtkSMProxy* GetLUTProxy(vtkSMProxy* view) have been deprecated. Use void SetLastLookupTable(vtkSMProxy* proxy), vtkSMProxy* GetLastLookupTable(), and vtkSMProxy* GetLUTProxy(vtkSMProxy* view), respectively, instead.vtkPVPlaneCutter), the "Axis-Aligned" plane cut function is deprecated. Use the Axis-Aligned Slice filter (VTK class vtkAxisAlignedCutter) instead.vtkPVGeometryFilter, the information keys POINT_OFFSETS(), VERTS_OFFSETS(), LINES_OFFSETS(), POLYS_OFFSETS(), and STRIPS_OFFSETS() have been deprecated. They are not used anymore.SurfaceLIC plugin has been removed (deprecated in 5.11). The Surface LIC representation is still available in ParaView.pqAnimationManager, the beginPlay() and endPlay() argument-less signals have been removed (deprecated in 5.11). Use the variants with vtkCallback APIs instead.pqAnimationManager, the onBeginPlay() and onEndPlay() argument-less slots have been removed (deprecated in 5.11). the variants with vtkCallback APIs instead.pqPropertiesPanel, the setAutoApply() and autoApply() methods have been removed (deprecated in 5.11). Use the methods on vtkPVGeneralSettings instead.pqPropertiesPanel, the setAutoApplyDelay() and autoApplyDelay() methods have been removed (deprecated in 5.11). Use the methods on pqApplyBehavior instead.pqVCRController::playing(bool) signal has been removed (deprecated in 5.11). Use the ::playing(bool, bool) signal instead.pqAnimationScene, the beginPlay() and endPlay() signals have been removed (deprecated in 5.11). Use the variants with vtkCallback APIs instead.pqRenderView, the selectOnSurface() method has been removed in favor of selectCellsOnSurface and selectFrustum in favor of selectFrustumCells (deprecated in 5.11).pqServerResource::sessionServer() and ::setSessionServer() methods have been removed (deprecated in 5.11). Any calls should just be removed and the resource used directly instead.pqTimelineScrollbar (deprecated in 5.11). Use pqTimeInspectorWidget instead.vtkPVPluginsInformation::PluginRequirementsSatisfied() method (deprecated in 5.11). Use vtkSMProxyManager::SatisfyPluginRequirements() instead.vtkPVRenderView VolumeAnisotropy methods (deprecated in 5.11). Use vtkVolumeProperty's ScatteringAnisotropy methods instead.vtkPVGeometryFilter UseStrips and ForceUseStripsOn methods (deprecated in 5.11).paraview.simple, remove the Show3DWidgets and Hide3DWidgets functions (deprecated in 5.11). Use ShowInteractiveWidgets and HideInteractiveWidgets instead.USE_FILE_SETS optionThe paraview_plugin_build CMake API now supports the USE_FILE_SETS argument to use file sets when building internal modules.
Plugins can make use of Qt classes and resources without using ParaView Qt modules. This can be the case for instance in a module using Qt core features. The module should be built even if ParaView was not built with Qt support. This is typically the case on the server side, where the graphical interface is not enabled.
A new plugin example named ServerSideQt now illustrates how to make use of this new capability.
vtkPVVersionMost of the version macros have been relocated to vtkPVVersionQuick.h. The new PARAVIEW_VERSION_EPOCH macro is defined as the actual PARAVIEW_VERSION_PATCH value for release-track development and a "high" value for future ParaView release development (i.e., the next minor version bump). The actual patch number, and PARAVIEW_VERSION_FULL values are available in vtkPVVersion.h. A new PARAVIEW_VERSION_NUMBER_QUICK macro provides the ParaView version as a comparable value with PARAVIEW_VERSION_CHECK using the PARAVIEW_VERSION_EPOCH instead of PARAVIEW_VERSION_PATCH. The intent is to reduce the rebuild frequency needed for the nightly build version bump for the in-development source.
vtkWrapClientServer warningsThe vtk_module_wrap_client_server CMake API now supports adding warning flags when wrapping. Currently supported is -Wempty to warn when a wrapping generates no usable code.
QComboBoxYou can now specify WidgetHeight hints on properties that use a QComboBox such as EnumerationDomain, ProxyListDomains or StringListDomain. This hint will control the maximum allowed number of items in the combobox before a scroll bar appears.
LiveSource capabilities have been expanded with a new emulated time algorithm.
Once you've inherited your temporal algorithm from vtkEmulatedTimeAlgorithm, you can use the LiveSource concept to synchronize the algorithm's timesteps on a "Real Time" interval (in seconds). It will skip frames if the pipeline processing does not keep up.
An example scenario for this algorithm would be to replay a LiveSource stream from a recorded file while maintaining the original conditions and playback speed.
To implement this behavior, inherit your algorithm from vtkEmulatedTimeAlgorithm and define the proxy as a LiveSource with the emulated_time attribute.
The vtkPVGeometryFilter can now produce vtkPartitionedDataSetCollection as output. This is useful when the input is a vtkPartitionedDataSet, vtkUniformGridAMR, or vtkPartitionedDataSetCollection.
hide_for_tests option removedThe hide_for_tests attribute in Category XML is no longer supported.
1.8.13 on Sun Dec 14 2025
