4 #ifndef pqServerManagerModel_h 5 #define pqServerManagerModel_h 55 typedef QObject Superclass;
92 void beginRemoveServer(
pqServer* server);
93 void endRemoveServer();
111 return ::pqFindItem<T>(
this, proxy);
121 return ::pqFindItem<T>(
this, id);
130 return ::pqFindItems<T>(
this);
139 return ::pqGetNumberOfItems<T>(
this);
150 return ::pqGetItemAtIndex<T>(
this, index);
160 return ::pqFindItems<T>(
this, server);
172 return ::pqFindItem<T>(
this, name);
179 QList<void*>* list,
pqServer* server =
nullptr);
223 void aboutToRemoveServer(
pqServer* server);
228 void finishedRemovingServer();
246 void preProxyRemoved(
pqProxy*);
264 void preViewAdded(
pqView* view);
265 void viewAdded(
pqView* view);
270 void preViewRemoved(
pqView*);
271 void viewRemoved(
pqView*);
314 void preConnectionRemoved(
335 virtual void onProxyRegistered(
const QString& group,
const QString& name,
vtkSMProxy* proxy);
340 virtual void onProxyUnRegistered(
vtkSMProxy* proxy);
345 virtual void onConnectionCreated(
vtkIdType id);
350 virtual void onConnectionClosed(
vtkIdType id);
365 void updateSettingsFromQSettings(
pqServer* server);
368 pqInternal* Internal;
377 model, ((T)0)->staticMetaObject,
reinterpret_cast<QList<void*>*
>(&list),
nullptr);
387 model, ((T)0)->staticMetaObject,
>(&list), server);
395 return qobject_cast<T>(
410 return qobject_cast<T>(
418 return pqFindItems<T>(model).
size();
425 QList<T> items = pqFindItems<T>(model);
426 if (index < items.size())
QList< T > pqFindItems(const pqServerManagerModel *model)
static void findItemsHelper(const pqServerManagerModel *model, const QMetaObject &mo, QList< void *> *list, pqServer *server=nullptr)
Internal method.
vtkSMSession is the default ParaView session.
This is PQ representation for a single representation.
pqServerManagerModelItem is a element maintained by pqServerManagerModel.
This is a PQ abstraction of a generic view module.
T findItem(const QString &name) const
Returns an item with the given name.
T findItem(vtkTypeUInt32 id) const
Given the global id for a proxy, locates a pqServerManagerModelItem subclass for the proxy...
This is a vtkSMProxyManager observer.
T pqGetItemAtIndex(const pqServerManagerModel *model, int index)
T pqFindItem(const pqServerManagerModel *model, const QString &name)
QList< T > findItems() const
Returns a list of pqServerManagerModelItem of the given type.
T findItem(vtkSMProxy *proxy) const
Given a proxy, locates a pqServerManagerModelItem subclass for the given proxy.
This class represents any registered Server Manager proxy.
pqServerManagerModel is the model for the Server Manager.
int getNumberOfItems() const
Returns the number of items of the given type.
static pqServerManagerModelItem * findItemHelper(const pqServerManagerModel *model, const QMetaObject &mo, vtkSMProxy *proxy)
Internal method.
int pqGetNumberOfItems(const pqServerManagerModel *model)
PQ representation for a vtkSMProxy that can be involved in a pipeline.
vtkSession defines a session i.e.
T getItemAtIndex(int index) const
Returns the item of the given type and the given index.
QList< T > findItems(pqServer *server) const
Same as findItems<T>() except that this returns only those items that are on the indicated server...
pqServerResource encapsulates a resource in ParaView.
pqServer (should be renamed to pqSession) is a pqServerManagerModelItem subclass that represents a vt...
